NVMe?
Right, will my:
Asus strix z270g Intel lga 1151 ROG MB
Intel® Core™ i7-6700K 6700K - 4GHz Quad-Core 6th Gen. Socket 1151 Processor
Patriot Viper 4 16GB Dual Ch. DDR4 3000MHz PC4-24000 DIMM PV416G300C6K
Fully Support the: Samsung 960 Pro 512GB M.2 NVMe PCIe Solid State Drive/SSD MZ-V6P512BW ?
RAMCACHE II
SPEED YOUR **** LOADS
Uniquely intelligent technology that effectively caches entire storage devices so that favorite apps launch at breakneck speeds, getting to work the moment it's activated. RAMCache II turns milliseconds into microseconds to boost load times - and of course it's compatible with the latest NVM Express storage options!
ROG STRIX Z270G GAMING | Motherboards | ASUS United Kingdom
The Samsung 960 Pro M.2 NVMe PCIe SSD MZ-V6P512BW manual says:
Mainboard (System) Intel Haswell Refresh or later client chipset based main board with free
(unallocated) PCIe Gen. 3 x 4 lanes.
Processor 64-bit processor (recommended) single, dual or higher number of processors
can be used.
Memory More than 2 GB DRAM.
Connector Requires M.2 (‘M’ Key) or use third party adapter (AIC) to connect to PCIe connector.
Form-Factor Space for a single sided M.2 2280 (SSD with dimensions 22 mm x 80 mm) or
Power 25 W compatible PCIe slot.
