PC Based Computer music servers, crossovers, and equalization
Digital active speaker PC sound card/DAC solution
Old 8th June 2018, 10:32 AM   #1
lbstyling is offline lbstyling  United Kingdom
Default Digital active speaker PC sound card/DAC solution
Hi guys,
Looking for advice on my front end solution.
My aim is to have a flexible PC based system with digital active 2.1 for music, and 5.1 for films.
I'm currently completing a pair of digital active speakers using the crossover in JRiver and the sound is really coming together to be very good (thank god!).I have been using my PC's soundcard for testing/setup. I also have REW and a calibrated Mic. The speakers are a huge outlay for me, but this is an ultimate build attempt, so I really want to get the front end right.
I have been focusing on the speaker side of things for the last 6 years or so am out of touch with what the latest is on the software and DAC/soundcard front.
I need a solution for the soundcard/DAC part along with the software end so I can run:
Active 3 or 4 way L + R speakers (6 or 8 channels)
Passive C, Rear L and Rear R and sub speakers for 5.1.
This totals 10 or 12 channels. I know JRiver can do this, but I don't know if there are any drawbacks that I need to be aware of, or better solutions?
The thing is, I need to know that whatever soundcard or DAC I use, the sound quality must be very good, and self noise low, as my speakers have a horn mid range and are 110db at 1w/1m.
Is there a good value or DIY option for the DAC? When I last looked, MiniDSP was great on paper, but high self noise caused problems.
What would you build or buy for the front end?
What software do I want to run with JRiver to get the best out of the speakers?
Convolution? Rephrase? Are these possible for my setup?
Is there anything else I might want to know before I start buying things? (Delay issues with films and convolution etc)
Thanks.
Old 8th June 2018, 07:23 PM   #2
Default ESS 9038/pro 8 channel diy boards
Are there any diy kits that offer the ESS 9038 DAC as an 8 channel USB?
Thanks.
Old 8th June 2018, 07:30 PM   #3
jazbo8 is offline jazbo8
jazbo8's Avatar
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 8th June 2018, 07:50 PM   #4
Clueless but avid is offline Clueless but avid  Germany
At the moment I'm using my Asus Xonar D2X for active stereo speakers with subwoofer (3 channels left, 3 channels right, 2 channels subwoofer, via Equalizer APO/ peace). My thought is, when I deceide to go for 5.1 (or whatever surround), I simply install a second soundcard to configure surround on this card. So I can be sure my stereo profiles and everything that goes with it stays untouched and I can play with surround settings without causing to much colleteral damage.
Old 8th June 2018, 08:12 PM   #5
Hi Clue,
My understanding is that (at least for Jriver) running a second sound card has issues with clock time matching. Now the comments I heard were regarding running a single active speaker with 2 cards not separate speakers, but none the less.
JRiver as crossover with 2 different DACs
This would be to run the active system as a standalone, similar to the MiniDSP? .... hmm possibly. I would prefer just the DAC part so I can use my PC. powerful as a SHARC processor is, im not going to run out of power for FIR filters with my intel desktop i7 PC. What is the price? I assume this is north of $1k?
Old 15th June 2018, 01:36 PM   #6
What other high quality 8+ channel DAC kits exist?
Old 15th June 2018, 04:16 PM   #7
jiiteepee is offline jiiteepee  Finland
Pulse16 – Ferrofish-EN
Old 16th June 2018, 10:48 PM   #8
CharlieLaub is offline CharlieLaub  United States
Get a USB pro audio recording interface, e.g. Presonus 1818VSL, etc. Look for 8-channel analog outputs. If you need more channels, look for ADAT connections for more I/O.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 17th June 2018, 10:08 AM   #9
jmansion is offline jmansion  United Kingdom
Thanks.
This isn't a kit, and has ESS9028PRO.
exaSound Audio Design > e38 > e38 DAC Overview
Shame about the price!
You (also) want to build this for a fraction of the price?
Digital active speaker PC sound card/DAC solutionHide this!Advertise here!
USB sound card for active crossover Kev06 PC Based 12 12th January 2016 03:58 PM
4 way active capable sound card (TA, EQ, XO) Ceri PC Based 21 17th December 2014 11:15 PM
Digital USB Sound Card isolation - Ground looping noise removal solution sk1 Vendor's Bazaar 0 29th May 2010 07:43 PM
help to select sound card - need only digital out kyselym Digital Source 6 14th April 2006 05:08 AM
Dolby Digital 5.1 amp for Sound Card dracul Everything Else 3 29th August 2003 04:37 AM
Resources saved on this page: MySQL 65.00% / PHP 47.62%
