Hello,For EQ, DSP, see Equalizer APO, REW and Rephase WOW!
thank you. I have tryed it and I will use it in future mainly because of crossover feature.
Hello,
Do anyone know if there is any sound enhancer better than DFX, FxSound?
The thing is that I have PA setup, but no EQ or DSP... I have tryed DFX with it and it sounds alot better. I`m just wondering if there is any program that is even better?
Thank you
I'm using Dirac with Windows (stereo version). Some people like it.
Hello.I'm using Dirac with Windows (stereo version). Some people like it.
It needs additional hardware right?
I`m looking to something similar to DFX audio enhancer. I don`t know if you are familiar with it, but in short it has few sliders / functions that makes sound more full, it`s functions are Fidelity, Ambience, 3d surround, Dynamic boost and EQ and it`s noob friendly.What are you looking for? Sound enhancer.. like what?
I`m just wondering if there is something in this stile with more functions out there.
Basically I`m trying to get the best sound from my PA speakers without buying hardware... (15inch 500w woofer and piezo horn in each of 2 boxes and zeck pt7amp )
Hello.
I've got a USB mic to take settings. Other than that it's just the software.
Grant.
Diy1995
Replace that Piezzos with real compression drivers, and Your sound will be much happier. Don't forget the crossover to cross them in the 1000-2500 Hz region or You'll blow them.
A piezo costs 2$, but a 1'' compression driver for 100W costs 100$
For example: Selenium Products | JBL Professional.
I use the 202 and the 220 and they sound beautifully.
They are compression drivers, my bad, I tought that these are the same...Diy1995
- PC Based
- Sound enhancers for Windows...
