PC Based Computer music servers, crossovers, and equalization
is that any way to make voice bold using audacity ?
Old 26th March 2018, 11:10 PM   #11
MAAC0 is offline MAAC0  Portugal
Why changing pitch ? Applying equalization doesn't help ? On DJ consoles there is a button called Beat lock for this.
Old 27th March 2018, 02:32 AM   #12
spongeman is offline spongeman  Indonesia
spongeman's Avatar
are you sure, man ?
cause i try and do not working
Old 7th April 2018, 06:30 PM   #13
spongeman's Avatar
okey , if audacity cant do it nicely then is there any other software can do it ?
Old 7th April 2018, 07:12 PM   #14
cbdb is offline cbdb  Canada
I have worked with some of the most expensive pitch change plugins. ( recording cartoon dialogue ). Non are perfect and people are so used to hearing voices it dosnt take much effect before it sounds weird. Three things I would try simultaneously. First record with a mic with proximity effect ( bass boost when your a cuople inches from the mic) with a high sampling rate, and talk fast. Then slow down the recording, this is the best way to pitch things down and is only limited by the speed of the dialogue and the sample rate. Then you can use a pitch shift algorithm to go another 10 to 20 percent. You should be able to get close to an octave of pitch drop.
is that any way to make voice bold using audacity ?Hide this!Advertise here!
Audacity effects BXC Software Tools 0 29th July 2016 06:29 PM
How do I make a speaker crossover to only hear range of human voice? yeto Solid State 16 13th May 2016 12:01 PM
24 bit input only 16 bit in Audacity rjm PC Based 11 10th May 2013 07:32 AM
on/off/on switch for bright/bold? PRNDL Tubes / Valves 3 22nd November 2007 09:53 PM
Bold problem in vB Code EC8010 Forum Problems 5 8th March 2003 02:33 AM
Resources saved on this page: MySQL 66.67% / PHP 37.11%
