goodby Sokoris..hi Soekris
Hi , thanks for the spelling info Dimdim.... Soekris it is.
Thanks henrylarsen, dare say your right, its just i wanted to listen to good experience as i dont have that much money and wanted to get it right first time, but the Soekris and Pi is the answer i was hoping for, thank you .
regards
Johnny
regards
Johnny
This is an interesting conversation, because i'm in the same shoes.
Some comments:
- Which boards are better for media playing, than RPi? What are their advantages? Only a better USB support?
- I also would prefer a master clock based solution, and not reclocking. I feel, that the reclocking is a slightly expensive hack, instead of solving the root cause of the problem. Couldn't be a solution to have a cheap and good master clock generator (like jbonlinea college is using its DAC+ hat)?
What is about this board:
AK4118 Coaxial HiFi Sound Card DAC I2S Interface DSD 32Bit For Raspberry Pi dt55 | eBay
It has a SPDIF out + I2S out (as I saw). Does it make a proper master bus clocking?
Some comments:
If you’re considering the Kali and plan to use the RPi with no power supply modifications, I recommend budgeting for the Allo isolator as well. This makes a clear improvement between Pi and Kali in my system. To my ears it makes more of a difference than Ian’s isolator board. An isolator board might not be required if you plan to use something like Allo’s USB signature, but this is a lot more money.
