PC Based Computer music servers, crossovers, and equalization
How redirect Audio from PC to Raspberry Pi
Old 22nd January 2018, 06:43 PM   #11
audioengr is offline audioengr  United States
If you only want to play 2-channel to the RPi, then install Dietpi OS and select DLNA from the menu. Then play music from Jriver on your PC. This is a DLNA endpoint. Use Ethernet or WIFI. If you want a direct connection, you can try a crossover Ethernet cable.
If you want a music server, then install Roon Server by selecting it from the Dietpi menu.
The very best in computer audio
Old 9th February 2018, 09:52 AM   #12
Maupastor is offline Maupastor  Portugal
http://www.audioinjector.net/rpi-zero
I think audio injector solves your problem and is not expensive.
Old 9th February 2018, 05:46 PM   #13
flexus is offline flexus  Austria
the main problem in a software solution is stability. with some of them you end up in a stable state. but beware shutting the box down afterwards because maybe you didnt save your configuration hell or stuff like that its often very problematic if you restart one of the boxes.
i once had some zita solution running, i think it is called zita-njbridge. it was working stable but i didnt test latency. it is a linux only jack client though.
good luck
How redirect Audio from PC to Raspberry PiHide this!Advertise here!
raspberry pi zero as audio gadget on windows thewizard240 PC Based 0 2nd November 2017 07:50 PM
VoltaStream ZERO - The Raspberry For Audio Streaming VoltaStream Vendor's Bazaar 0 29th August 2017 09:17 AM
Raspberry Pi noisey USB audio Jerms PC Based 6 3rd February 2017 09:36 AM
Advice on Raspberry Pi audio player? mattmcl Digital Source 0 16th September 2016 03:04 AM
Intercept and Redirect USB Audio Stream cukaracha Digital Line Level 10 23rd December 2014 09:24 PM
