PC Based Computer music servers, crossovers, and equalization
Ecasound DSP startup difficulties
Old 10th January 2018, 05:27 PM   #11
taita is offline taita  Netherlands
Originally Posted by CharlieLaub View Post
If you use the option "-ddd" with ecasound it will produce the maximum amount of debug and error messages. It might help you figure out the problem.
It is very possible that your 2-channel soundcard includes a 5.1 channel surround mode as part of the ALSA interface, however, if you actually try to play audio using that it may only produce an error because of the mismatch in the channel count.
I received my 5.1 soundcard today and tested it with different scripts but nothing works. I am getting the bus error and resources seem to be locked. Even the simple ecasound sound.wav failed. I think I have broken the environment with my attempts to solve things.
So I plan to do it all over again and install a fresh iso. One important question comes to my mind. What do I have to do in advance of installing the libraries. Do I have to do this in root mode (sudo su) or can I just do this under the initial user?
The steps to install things on linux seem easy but just for confirmation I repeat them. In terminal enter:
Code:
sudo apt-get install alsa alsa-base alsa-utils alsa-tools libasound2-plugins
sudo apt-get install ecasound
sudo apt-get install ladspa-sdk
For the filters I use the instructions on Richard Taylors page Richard Taylor -- Thompson Rivers University
This should be sufficient to set up the environment and get sound out of my soundcard?
Old 10th January 2018, 05:56 PM   #12
CharlieLaub is offline CharlieLaub  United States
Code:
OK, we can help you. Please post the output of the following commands:
Code:
aplay -l
That is a lower case "L" in the command, above. Make sure your new soundcard is connected before running the command.
Code:
ecasound --version
Code:
echo $LADSPA_PATH
Code:
listplugins
The output will help us to check that everything is installed and configured properly.
Also, please post the ecasound commands that you are trying to run, and the output. I am sure we can get it working for you. You are very likely doing something wrong.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 10th January 2018, 06:01 PM   #13
Code:
aplay -l
Code:
ecasound --version
Code:
echo $LADSPA_PATH
Code:
listplugins
Thanks for your quick respons. Do you want me to do the commands in the old version or do I have to install a new iso first? Are root right needed or can I do the commonds just with my active user?
Old 10th January 2018, 06:18 PM   #14
Run the commands as a regular user. Root level privilege should not be needed for any of this stuff and could possibly be the source of your problem. I will explain later.
Do this for whatever setup you want to investigate.
Old 10th January 2018, 06:34 PM   #15
Code:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
  Subdevices: 1/1
card 1: Device [USB Sound Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
ecasound --version
ecasound v2.9.1
Copyright (C) 1997-2014 Kai Vehmanen and others.
Ecasound comes with ABSOLUTELY NO WARRANTY.
You may redistribute copies of ecasound under the terms of the GNU
General Public License. For more information about these matters, see
the file named COPYING.
echo $LADSPA_PATH
listplugins
Warning: You do not have a LADSPA_PATH environment variable set.
/usr/lib/ladspa/amp.so:
    Mono Amplifier (1048/amp_mono)
    Stereo Amplifier (1049/amp_stereo)
/usr/lib/ladspa/delay.so:
    Simple Delay Line (1043/delay_5s)
/usr/lib/ladspa/sine.so:
    Sine Oscillator (Freq:audio, Amp:audio) (1044/sine_faaa)
    Sine Oscillator (Freq:audio, Amp:control) (1045/sine_faac)
    Sine Oscillator (Freq:control, Amp:audio) (1046/sine_fcaa)
    Sine Oscillator (Freq:control, Amp:control) (1047/sine_fcac)
/usr/lib/ladspa/noise.so:
    White Noise Source (1050/noise_white)
/usr/lib/ladspa/filter.so:
    Simple Low Pass Filter (1041/lpf)
    Simple High Pass Filter (1042/hpf)
echo $LADSPA_PATH gives no result.
I know I can use export LADSPA_PATH=/usr/local/lib/ladspa:/usr/lib/ladspa to store the path. But for some or another reason I have to do this every time after a rebooth.
When I do export the path and I try again to play something I get
Code:
speaker-test -D surround51:Device -c 6 -t wav
speaker-test 1.1.0
Playback device is surround51:Device
Stream parameters are 48000Hz, S16_LE, 6 channels
WAV file(s)
Playback open error: -16,Device or resource busy
Well I hope this gives the information for the right root cause.
Old 10th January 2018, 06:46 PM   #16
You either have to set the LADSPA_PATH evironmental variable each time after a reboot, or you need to put it into some file that is read/run at bootup. Try putting
at the end of your .profile file in the user home directory.
It might be that some other process is already using the soundcard or you are referring to it incorrectly. Could you please run the command:
aplay -L
This will generate more output. It is a list of all the output modes of all the soundcards. You can post all of that, or just the section for your USB soundcard.
You can also try to unplug the soundcard, wait a few seconds, and then plug it back in. This would cause any process that is using it to be terminated.
Also, what is the OS that you are using?
Old 10th January 2018, 07:02 PM   #17
Code:
aplay -L
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
sysdefault:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
dmix:CARD=ALSA,DEV=0
    Direct sample mixing device
dmix:CARD=ALSA,DEV=1
    bcm2835 ALSA, bcm2835 IEC958/HDMI
dsnoop:CARD=ALSA,DEV=0
    Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=0
    Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=0
    Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
sysdefault:CARD=Device
    USB Sound Device, USB Audio
front:CARD=Device,DEV=0
    Front speakers
surround21:CARD=Device,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Device,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Device,DEV=0
dsnoop:CARD=Device,DEV=0
hw:CARD=Device,DEV=0
plughw:CARD=Device,DEV=0
The OS is a recent version of Ubuntu mate on a RPI.
Some succes: I disconnected the soundcard and did
Code:
The test played well and I could hear the test from the soundcard. But to stop the process I used ctrl Z, but that seems not to be the right method as I got errors again.
Old 10th January 2018, 07:12 PM   #18
What happens if you try this:
Code:
ecasound -B:rt -i:tone,sine,400 -o:alsa,surround51:CARD=Device,DEV=0
Old 10th January 2018, 07:20 PM   #19
Code:
That works well, but how do I terminate the playing?
Code:
ecasound -B:rt -z:mixmode,sum -x -i:Flute.wav -f:16,2,44100 -o:alsa,plug:surround:Device
*        ecasound v2.9.1 (C) 1997-2014 Kai Vehmanen and others
(eca-chainsetup-parser) Buffering mode 'rt' selected.
(eca-chainsetup-parser) Enabling 'sum' mixmode.
(eca-chainsetup-parser) Truncating outputs (overwrite-mode).
(eca-chainsetup) Chainsetup "untitled-chainsetup"
(eca-chainsetup) "rt" buffering mode selected.
(eca-chainsetup) WARNING: Couldn't lock all memory!
(eca-chainsetup) Opened input "Flute.wav", mode "read". Format: s16_le,
... channels 2, srate 44100, interleaved (locked params).
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM surround:Device
ERROR:  Connecting chainsetup failed: "Enabling chainsetup: AUDIOIO-ALSA:
... Unable to open ALSA-device for playback; error: No such file or
... directory"
Old 10th January 2018, 07:21 PM   #20
phofman is offline phofman  Czech Republic
"Device busy" is simple - your soundcard is taken by another process. In 99.9% it is pulseaudio. IMO that is also the cause for the "bus error" of ecasound.
Run
Code:
sudo lsof /dev/snd/*
and you will see your soundcard device is open by pulseaudio process.
One-time solution - run several times the command
Code:
killall pulseaudio
untill the lsof command lists no pulseaudio processes holding your soundcards.
Permanent solution - disable the soundcard in pulseaudio:
pavucontrol -> tab Settings -> choose Off for the cards you do not want pulseaudio to touch.
[xubuntu] How to make Pulseaudio use only a specific device - Page 2
Ecasound DSP startup difficultiesHide this!Advertise here!
ecasound crossover issue with Line in Tonio79 PC Based 16 25th January 2017 01:35 AM
help with delayed (15s) audio in ecasound crossover setup Gordon C PC Based 8 25th November 2016 09:38 AM
MPD to ecasound - plays flac but not MP3 JMF11 PC Based 7 13th June 2016 08:10 PM
ecasound in MPD - problem of Device or resource busy JMF11 PC Based 7 12th June 2016 06:02 AM
PCM2902 difficulties jmar Digital Source 7 13th January 2006 09:07 PM
