PC Based Computer music servers, crossovers, and equalization
Ecasound DSP startup difficulties
Old 29th January 2018, 09:25 AM   #101
phofman is offline phofman  Czech Republic
Very good :-)
Old 3rd February 2018, 08:06 AM   #102
taita is offline taita  Netherlands
Default Volume control
A point of attention with this solution is the volume control. When I develop a multichannel system with this approach I will play my music by using MPD or Spotifyd (I don't own a volume controlled player for line in). Both have an option to control the music by using hardware or software controls. My Xonar U7 soundcard has a volume button but that is disabled (I see it on the screen but it doesn't change the volume). Changing volume on the soundcard output is not possible because than you have to change it for every channel. Alsamixer probably is an option but than I have to use a screen and keyboard/mouse when I play music. So I think the only option is to use software volume control in the MPD or spotifyd client (android device). But many say that software volume control degrades the sound. Is this really true and what else options do I have?
Old 3rd February 2018, 06:48 PM   #103
CharlieLaub is offline CharlieLaub  United States
I think the main objection is that if you perform digital level control on 16 bits and dial down the level you are reducing the effective bit depth of the audio too much. The solution is to convert the 16 bit audio to 24 or 32 bits and THEN apply digital volume control. This more or less removes any problem with bit depth from the problem.
I am not 100% sure how and when MPD applies volume control to the audio stream. I know I can configure MPD to output e.g. 32 bit audio, but I do not know if the conversion from the song audio format (e.g. 16 bits) to the new format comes before or after MPD's volume control.
I would not lose any sleep of these kind of issues!
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Ecasound DSP startup difficultiesHide this!Advertise here!
ecasound crossover issue with Line in Tonio79 PC Based 16 25th January 2017 01:35 AM
help with delayed (15s) audio in ecasound crossover setup Gordon C PC Based 8 25th November 2016 09:38 AM
MPD to ecasound - plays flac but not MP3 JMF11 PC Based 7 13th June 2016 08:10 PM
ecasound in MPD - problem of Device or resource busy JMF11 PC Based 7 12th June 2016 06:02 AM
PCM2902 difficulties jmar Digital Source 7 13th January 2006 09:07 PM
