PC Based Computer music servers, crossovers, and equalization
Mezzanine Power board for Raspberry Pi
Old 21st January 2018, 01:31 PM   #11
oxothuk is offline oxothuk  United Arab Emirates
Originally Posted by anhton82 View Post
Thanks for your help. I want to supply power for Pi saperate as picture bellow, so is this modules is better than it?. Pin 2,4 of PI GPIO is supply 5V for DigiOne. I think module C1 (1A) is ok for it.
http://www.hdvietnam.com/attachments/basic-png.260416/http://www.hdvietnam.com/attachments/basic-png.260416/
C1+C2 to power Pi and DigiOne (top and bottom rails connected)
D to power PI 3.3V rail
E to power PI 1.8V
(need to remove PI DC/DC converter for D/E)
6VDC IN (Single, 1.5A+)
Ultra Low Noise Power Solutions.
www.ldovr.com
Old 22nd January 2018, 01:35 AM   #12
anhton82 is offline anhton82  Viet Nam
E to power PI 1.8V
Many thanks. But I just put this board on top of Pi or I have to connect to Pi by wire?
Old 22nd January 2018, 08:41 AM   #13
only 1.8V need to be soldered by wire (PP9)
5V and 3.3V connected to PI by GPIO
www.ldovr.com
Old 22nd January 2018, 02:47 PM   #14
Sorry again, If I use B replace for C1+C2 OK, because I don't know B and C supply for which pin on GPIO! I need 2A for USB, HDD connect to Pi.
Old 23rd January 2018, 07:21 AM   #15
Module B connected to PIN 2&4 (PI Side)
Module(s) C1(1+2) connected to PIN 2&4 (HAT Side)
5V PI and 5V HAT rails can be connected together (need to solder small bridge), means either B or C can power both HAT and PI, but with modules current limitation.
If you need to have 2A - use Module B for PI power
www.ldovr.com
Old 23rd January 2018, 05:00 PM   #16
Thank you so much. Pls give me a voucher for discount. I will order this modules.
Old 26th January 2018, 04:44 PM   #17
Hi Mr oxothuk, I sent email to you. Pls give me a voucher. Thanks !
Old 30th January 2018, 08:44 AM   #18
potstip is online now potstip  Turkey
Default Doubts
I have 2 doubts here;
Pre regulator is also generate RMS noise which is much higher that LT3045 so what is the point here to use Low noise regulator. Do you think LT3045 eliminate the RMS noise generated by LT3086?
Second; even you power pri from GPIO, The on board PAM2306AYPKE shunt regulator still continue to generate lots of noise. Unless you desolder it from pcb and power up pcb with shortcut cables instead of GPIO. What do you think?
Old 30th January 2018, 09:32 AM   #19
it will reduce ripples from external PSU and LT/TPS clean up remaining noise
i mentioned before - you need to remove DC/DC converter if want to feed pi with external 1.8/3.3V.
Please note that some DAC require 3.3V (from PI), in this case Mod D can be used to feed HAT only.
www.ldovr.com
Mezzanine Power board for Raspberry PiHide this!Advertise here!
Z-turn board, a single board computer like raspberry pi? jeepcoon Vendor's Bazaar 0 16th June 2017 06:45 AM
Single power supply for multiple (raspberry pi+amplifier) devices? Geeyoff Power Supplies 1 19th January 2017 09:16 PM
Raspberry pi digipi+ board linear power supply digipi DIY HiFi Supply 0 30th March 2016 09:14 PM
Building power supply for O2/ODAC & Raspberry Pi Sarion Power Supplies 18 2nd February 2016 10:19 PM
Linear power supply for DAC/Raspberry Pi etc. jean-paul Digital Source 0 30th April 2015 11:56 AM
Resources saved on this page: MySQL 13.04%
