PC Based Computer music servers, crossovers, and equalization
Need suggestion for best slim optical disk drive
Old 28th November 2017, 04:59 PM   #1
sbelyo is offline sbelyo  United States
Default Need suggestion for best slim optical disk drive
I need to purchase a SATA slim ODD for a slim HTPC case. I'll need DVD, CD, and Blu-Ray read support (best accuracy is what I'm looking for). Write support is not as important but CDR, DVDR would be needed at least. I'm really looking for the best slim ODD to finish ripping my CD, DVD, Blu-Ray collection to storage.
Old 28th November 2017, 05:37 PM   #2
levistubby is offline levistubby  United Kingdom
I needed a slim ODD for my 1U HTPC case. Easy I thought, but then I found that it was hard to find one to fit the 15.5mm x 130.6mm slot in the front panel. I currently use an external USB drive.
What are the dimensions of the slot in your case?
Old 28th November 2017, 06:23 PM   #3
The manual doesn't say
This is the case SilverStone Technology Co., Ltd.INTRODUCTION:PT12
Here's the dimensions of one that fits
128 x 129 x 12.7 mm ( W x D x H )
5.04" x 5.08" x 0.5" ( W x D x H )
Old 28th November 2017, 08:20 PM   #4
Also open to full size drives since slim might not be as reliable. I can put it in an enclosure
Lite-On DVD Burner Black SATA Model iHAS124-14 was reported as the most accurate as of 2016
Old 28th November 2017, 08:31 PM   #5
Tromperie is offline Tromperie  Australia
Why not use your normal PC for ripping and any format conversions, then transfer the files to storage?
Anyway, any DVD drive will do as it is only ripping. Any decent ripping program will integrity check the files.
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 28th November 2017, 08:34 PM   #6
The machine that I use is my regular desktop. I don't like the external full size one I have and was looking to replace it. I was hoping to ditch the external altogether but it looks like that's the way to go performance wise
Old 28th November 2017, 08:35 PM   #7
"128 x 129 x 12.7 mm ( W x D x H )"
That seems to be the standard size. For some reason, my case has a bigger than standard front panel slot.
Old 28th November 2017, 09:47 PM   #8
Everything I've seen says 9 mm with 12.7 mm faceplace or just 12.7mm
I would think that's standard
Do you have a link to your case?
Old 29th November 2017, 09:18 AM   #9
My case is the now no longer available In-Win Ultratop K1.
K1_K1_Corporation IN WIN | ULTRATOP
I am currently using an external USB slot load drive to rip CDs.
Old 29th November 2017, 05:47 PM   #10
I see what you're talking about. It looks like the hard drive and slim ODD go into their own cradle and then slide in the front. Can you take a close up pic of that cradle and faceplate
Need suggestion for best slim optical disk driveHide this!Advertise here!
slim fullrange speaker suggestion for newbie viodea Full Range 36 7th October 2016 03:55 PM
Output transformer in reverse to drive a piezo disk haakok Analog Line Level 0 6th May 2011 11:51 AM
Optical output Denon DVD-2900 Suggestion d052057 Digital Source 5 2nd November 2010 12:53 AM
need hard disk drive schematic foret66 Analogue Source 1 15th July 2004 01:40 PM
Hard Disk Drive Speakers??? seangoesbonk Multi-Way 0 13th August 2002 07:05 AM
