PC Based Computer music servers, crossovers, and equalization
48 K Hz internal speed of Pi & playback quality ?
Closed Thread
Old 24th October 2017, 12:35 PM   #1
Henderson is offline Henderson
Banned
Default 48 K Hz internal speed of Pi & playback quality ?
It is a problem with 44.1 materials ?
My Pi 3 is streaming in I2S via a GPIO header with uf-l cables towards IanCanada FIFO+ISOLATOR+CLOCKII
The result is less good than the previous configuration: same front end but through an USB to I2S Wave I/O board : so USB feeded via a Synology NAS
Several surprises : despite a FIFO & isolator & reclocking : the sound is changed !
What hapenned please ? Is it the 48 K Hz internal speed of the Pi3 ? Or the asynchronous reclocking of the Wave I/O board which was better ? (but all is reclocked after by the boards of IanCanada and Crystek 957 xtals ?!)
Many thanks for your inputs !
Old 25th October 2017, 04:24 PM   #2
Banned
Btw, If one use only the I2S output of the RaspBeRry Pi (so raw output: the RPi3 as Masterclock: is it good enough for a FIFO before to be reclocked or would have I some quality issues?
Anyway I have some at ears but dunno if the problem is here or elsewhere. But no doubt the previous topology with USB (Wave I/O) to I2S aysync before the whole IanCanada front end (FIFO-Isolator-Reclocker with Crystek 957 xtals) give a better result than a I2S RPi3 straight (not async) output ???
Saw most of the hat DACs are slavering the internal clock of the RPi for it to output a better I2S; i.e. not using the internal divided Frequency of the Pi clock/xtal?
Can it be the problem despite FIFO&reclcoker ? I doubt it is the distro on the RPI ! Maybe the way I powersupply the Pi : external Technet battery not as good than a regulated powersupply ?
For my the said Noisy USB from a NAS is sounding better than I2S bus with uf-l wires & connector ! Not different, but better : more dynamic, better soundstage, more détails, less thin & flat notes, asf !
Could it be the noise of the Pi on the I2S GPIO bus ? Does an isolator improve things here, despite I have already an isolator between the FIFO & the reclocker ?
thanks for your experience or ideas, for the moment the RPI3 with I2S output seems a very poor transport for audio !
Closed Thread
48 K Hz internal speed of Pi & playback quality ?Hide this!Advertise here!
High quality coaxial for internal signal wiring Rundmaus Construction Tips 8 11th November 2016 12:50 PM
Data quality: streaming via wi-fi vs internal makes any difference? murillollirum Digital Line Level 80 4th February 2015 11:06 AM
FS: PRO-JECT Speed Box II - Changes Speed and Improves SQ - Like New HiGHFLYiN9s Swap Meet 3 22nd February 2014 02:36 AM
Cheap broadcast quality video queuing and playback from a PC? freax Digital Source 3 18th November 2012 05:16 AM
Quality internal speaker wire needed harrisni Multi-Way 12 28th August 2006 02:48 AM
