PC Based Computer music servers, crossovers, and equalization
Computer case with good EMI shielding
Old 24th October 2017, 01:59 AM   #1
Andyroid is offline Andyroid
Default Computer case with good EMI shielding
At the moment my recording studio computer emits so much EMI that I can not use single coil guitar pickups. The noise is awful. I've been looking at ways to improve/create a faraday cage but decided to buy a new case because there are a few on the market now that also have acoustic dampening for silent operation. That is a 'must have' for my recording studio.
So, do any of you know of a silent case that also has excellent EMI shielding? Ideally I would like to pay less than 100, also my CPU cooler (Cooler Master Hyper 212 EVO) stands about 159mm tall.
Thanks,
Andy
Old 24th October 2017, 11:50 AM   #2
Zootalaws is offline Zootalaws  New Zealand
Have you thought of earthing your current case?
A Mac Mini makes an almost silent studio PC. We’ve been using them since forever for recording. Cheap, too.
Old 24th October 2017, 11:57 AM   #3
levistubby is offline levistubby  United Kingdom
PC cases are designed to accommodate particular mother board form factors and so you need to say what the form factor of your MOBO is.
Old 24th October 2017, 12:11 PM   #4
Good point, it's ATX (30.5cm x 22.9cm).
Andy
Old 24th October 2017, 12:16 PM   #5
Zootalaws, I've tried scraping away paint to make good metal to metal contact but it seems to have made no difference. Also as I mentioned in my original post, acoustic dampening is important to me as it is in a recording studio, so I might as well buy a new case and kill two birds with one stone. And I don't want to go down the Mac route, not right now.
Thanks,
Andy
Old 24th October 2017, 12:36 PM   #6
woody is offline woody
I had a computer like that and found in my case it was rf radiating back through the ac power lines. I found just using an isolation transformer solved my problem. Later I found that my computer power supply didn't have the rf filter components installed -- oh there was a place for the hash filter components on the pc board but the components had been left out .
Old 24th October 2017, 12:48 PM   #7
phofman is offline phofman  Czech Republic
What kind of performance do you need for your recording? There are fanless PCs with external adapters which can be placed somewhere else.
Old 24th October 2017, 12:50 PM   #8
Thanks,
Andy
I used to work on Tempest-rated computer gear - spook stuff, designed to be invisible to emf snoopers.
The inside of the cases was lined with copper foil, a bit like those fancy CD players.
The hard drives were shielded with a sandwich of copper and plastic, earthed. As were the big ASICS, plug-in cards, etc.
The biggest culprit is the vga card and cable. Very noisy.
You can buy adhesive copper foil on AliExpress.
Old 24th October 2017, 12:51 PM   #9
Oh 20 years ago I ran across a pc hardened against RF . The cover was secured with 27 screws used to provide a uniform pressure to the metal mesh between the cover and case. And then there was the hash filter on the ac input. While most hash filters might use a pair of caps and a common mode choke or even 2 pairs of caps and a coppon mode choke this computer used a 3 pairs of caps and 2 common mode chokes in a C L C L C hash filter .
Old 24th October 2017, 01:15 PM   #10
Thanks Woody, I hadn't considered noise on the power cord. The noise stops momentarily I I move the mouse or press a button on the keyboard. I've tried turning the computer on without them plugged in but the noise is still there, I suspect it is coming from the MOBO. Also my PSU isn't cheap, I'm not sure but I think it's a Corsair energy efficient 600W. I have a few ferrite rings somewhere and a filtered 6A IEC input, it's probably too big to fit inside the PSU if they haven't deliberately left space for one.
I had considered using copper foil, but knowing my luck it would eventually peel off and short something out, so I'd rather not try it. But if it comes to it, I may have no choice.
Recording electric guitars often involves so much signal gain that the guitar sound distorts. This also brings up the noise floor. Most guitarists are familiar with the problem. There is often a sweet-spot, with the guitar at the right angle, in the right place, the noise is at a minimum. My room is so small that even the sweet spot is too noisy.
Computer case with good EMI shieldingHide this!Advertise here!
mini ITX computer case for Gainclone Chassis? dakku Chip Amps 2 27th May 2014 08:41 AM
Good Case for simple chip-amps lhwidget Chip Amps 3 10th October 2010 07:17 PM
FS: KRK 6000 passive studio monitors & BNIB Antec P160 computer case Spasticteapot Swap Meet 0 10th July 2009 07:41 PM
Anti-Wave Guide Computer Case ? Suggestions ? musicphile Everything Else 6 4th February 2007 01:51 PM
Computer installed in CD player case, need opinions... SkinnyBoy Everything Else 25 3rd August 2003 12:27 PM
