One of the stumbling blocks for Android users of pc-based network streamers, DACs, etc. is finding the device on the network.
Users of Windows, MacOS, iOS, Linux can use the services of Zeroconf, Bonjour, etc. to find a device using a name, such as player.local, hifi.station, etc., but that sort of name resolution isn’t natively available on most Android iterations.
Melloware has a great app for browsing zeroconf and similarly-equipped d vices and it would be good to know ho many of you can find your network-attached devices.
If you’re a user of Rune, Moode, Volumio, Kodi, Openelec, Archpile, or other similar networked streamer, and you fancy taking the time to test and contributing your findings, I would be interested to see how effective this app is in resolving the ongoing dilemma Android users face in our mDNS world
Melloware indicates support for Android versions from 2.0 on up, so most mobiles, tablets, dongles and set-top boxes should work.
ZeroConf Browser - Android Apps on Google Play
If you care to tell me, the version of Android and the device you downloaded to, successful or not?
Thanks.
Thanks.
Tried with Android 8 on my configured Moode player. Displayed details for udisk-sshThanks.
And sorry, I forgot to ask, could you tell me the version of Android you are using and if you care to share, the Android device(s)?
Did it display the name - Moode.local?
I’m looking for a way that Android users can easily find headless devices like Moode, etc.
For most other OS, it’s easy because they can all use some form of mDNS resolution, but Android forces the use of Google DNS which means it doesn’t look at your local router for name resolution,
We see so many support questions of “how do I find my device”. If Melloware’s app solves the problem for Android users, that’s an easy fix, easily documented.
MotoG5 Plus
I am running android 7.0 on MotoG5. Downloaded zeroconf. I typed in moode.local/ in chrome browser did not work for me. See attached screenshots. I clear all the browser cache a few times but that did not change result.
I doubt that chrome will ever resolve mDNS addresses. This was to see if you could find the IP address easily.
Is the Zeroconf browser able to pass you along to a web browser, by selecting from Zeroconf?
Pass to Browser using Zeroconf
For me it did NOT pass me to chrome browser. It does make it easy to find IP address.
Actually, you can resolve local addresses, but it requires hacking your router to block 8.8.8.8 and 8.8.4.4.
It’s easy enough to do, but may have unintended consequences if you run a chrome cast or other set top box.
Hi Mike, there is an app that works as an interface to moode (and other players) from Android devices.
This has auto-discovery that works.
There is a free 10 day trial version.
I thought it was useful and bought it. No complaints, does as it says and the dev is most helpful and a Moode user ..
Pi Music - Android Apps on Google Play
Good feedback, thanks.
- PC Based
- Android and Zeroconf/Bonjour
