PC Based Computer music servers, crossovers, and equalization
s/pdif on motherboard but no socket
Old 13th September 2017, 02:18 PM   #11
mrWagner is offline mrWagner  Hungary
Originally Posted by thyristor44 View Post
Yes I have a scope, I expect 5v signal on ttl but what would be the output if not ttl.
This pc is brand new to me so it will be some time before I contemplate removing the motherboard. I have bricked a few things in my past.
Expect 3.3V, maybe it is not TTL level, just better to describe it.
If not 0 to 3.3V, then around -0.5V to +0.5V
If you have any cable that you can connect on it, then you will not brick it.
I had some old PC speakers, cut the cable off and used if for measuring.
I only bricked a HDD before
Old 13th September 2017, 07:30 PM   #12
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Actually I think a S/PDIF signal should be around +/- 0.25V (the 0.5V is peak-to-peak).
A great resource on all things S/PDIF: epanorama.net/S/PDIF Interface.
Old 13th September 2017, 08:31 PM   #13
JeffYoung's Avatar
So it's 0 to +0.5V?
Old 13th September 2017, 08:40 PM   #14
wwenze is offline wwenze  Singapore
I deleted my previous post because I realized absolute voltage doesn't matter with a transformer.
An SPDIF receiver chip like CS8416 takes in a differential input voltage
But digital circuits don't output negative voltages.
Old 13th September 2017, 10:08 PM   #15
JeffYoung's Avatar
Ah... right, which is why the spec only states the peak-to-peak voltage.
(And given that, it would certainly be easier for the motherboard to output 0 to +0.5V.)
Old 14th September 2017, 11:20 AM   #16
thyristor44 is offline thyristor44
Thats a very useful site, thanks.
Old 14th September 2017, 03:31 PM   #17
Many times chips also handle AES signal level and that can go as high as 10Vpp.
So usually they can handle spdif with with bit higher voltages.
The link above also says spdif goes 0,5..1V.
s/pdif on motherboard but no socketHide this!Advertise here!
WTB: Motherboard for 755 socket intel CPU Jimmy154 Swap Meet 1 5th August 2013 02:38 AM
New FM-3 Motherboard denny9167 Tubes / Valves 2 26th January 2013 10:14 PM
WTT TP S/PDIF transceiver for S/PDIF 4:1 MUX/Receiver Module merlin el mago Swap Meet 0 28th June 2011 10:48 AM
S/PDIF Optical to S/PDIF RCA Replacement PrecisionAudio Digital Source 2 11th February 2007 09:35 PM
Asus Motherboard herm Everything Else 5 3rd January 2007 09:11 AM
