PC Based Computer music servers, crossovers, and equalization
Raspberry Pi with Piano2.1 DAC DSP and Volumio2
Old 22nd February 2018, 08:59 PM   #51
DonVK is online now DonVK  Canada
DonVK's Avatar
Default conflicts RT filters and sine.so causing "double free error"
I trying more of RT's filters, they worked but I was getting a "double free corruption" error (see pic). Its a known issue listed in RT's site Richard Taylor -- Thompson Rivers University and the solution is to remove sine.so
Code:
 sudo -rm -f /usr/lib/ladspa/sine.so
Then you can play something like this error free.
Code:
 "ecasound -i:xylophones.wav -eadb:3 -el:RTlr4lowpass,1500 -o:alsa,hw:PianoDACPlus
File Type: jpg double free corruption from sine RT.jpg (164.8 KB, 276 views)
Old 22nd February 2018, 09:40 PM   #52
DonVK's Avatar
Default Adding loopback and ecasound script files
It seems that whenever you touch the Volumio Playback options, it will auto generate a new /etc/mpd.conf file. So anything placed in that file could be overwritten, so if you mod it, make a copy.
There are many threads like ecasound in MPD - problem of Device or resource busy and NEW: the Active Crossover Designer for ecasound/LADSPA (ACD-L) - Techtalk Speaker Building, Audio, Video Discussion Forum, most of these are sourced by Charlie Laub (CL), that recommend an ALSA loopback and that looks reasonable. The strategy being [MPD]->[Loopback]->[Ecasound]->PianoDAC.
In the edit (nano) file "/etc/modules" and add line "snd-aloop" and it should look like this. Then reboot Volumio, and you will have another sound card called "Loopback" that you can select in the Volumio Playback menu, or you can pick "Piano2.1" as before. However, the soundcard numbering has changed as shown in the pic below. It still plays as normal via the Piano2.1 at this stage.
Code:
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
i2c-dev
snd-aloop
My /etc/mpd.conf after reboot contains this. Notice the Piano2.1 is still selected but this time its soundcard#2 :
Code:
# Audio Output ################################################################
resampler {
  		plugin "soxr"
  		quality "high"
  		threads "1"
audio_output {
		type		"alsa"
		name		"alsa"
		device		"hw:2,0"
		dop			"no"
		format      "44100:16:2"
The ecasound files are getting more complex than a single line and you can put them in an executable file. These scripts exist at /usr/local/bin and must be executable (chmod 777 file). Ecasound's parser is picky, so I use windows Notepad++ editor to see all the spaces and hidden characters. A space in the wrong spot causes it to spew error messages, sometimes not related to source of the problem.
The following is a simple ecasound file. Its located at /usr/local/bin/ecatest4. It's a single chain called "test4", that bandwidth limits 20Hz-16Khz, and 3 parametric equalizers. From the command line "ecatest4" will run it and you'll hear the xylophones. It's easy to change the parameters to check that its working.
Code:
#!/bin/bash
# test file input + filters
ecasound \
	-n:test4 -a:1 \
	-f:s16_le,2,44100 \
	-i:/home/volumio/xylophones.wav \
	-el:RTlr4hipass,20 \
	-el:RTlr4lowpass,16000 \
	-el:RTparaeq,3,30,2.8 \
	-el:RTparaeq,2,1000,2.8 \
	-el:RTparaeq,-2,5000,2.8 \
	-a:1 \
	-f:s16_le,2,44100 \
	-o:alsa,hw:CARD=PianoDACPlus,DEV=0
Old 25th February 2018, 03:14 AM   #53
DonVK's Avatar
Default Connecting loopback ...... and we're stuck
I selected Loopback in Volumio playback options and checked the /etc/mpd.conf which looked what I expected. My Loopback is card#0, and Volumio takes device#0 as loopback input.
Code:
resampler {
  		plugin "soxr"
  		quality "high"
  		threads "1"
audio_output {
		type		"alsa"
		name		"alsa"
		device		"hw:0,0"
		dop			"no"
		format      "48000:32:2"
Then check the output of Volumio by capturing the loopback output with Volumio playback off, then on again. When playback is off I get a file of "nulls" , and when playback is on I get a file of random stuff. So The loopback appears to work.
Code:
arecord -f S32_LE -c2 -r48000 -v -d 5 -D hw:0,1 check.wav
Then I stopped Volumio playback, and tested access to the piano with this and it worked fine.
Code:
#!/bin/bash
ecasound \
	-n:test4 -B:rt -a:1 \
	-f:s32_le,2,48000 \
	-a:1 \
	-o:alsa,hw:PianoDACPlus,0
Then switched ecasound input to use the loopback output using this.
Code:
#!/bin/bash
ecasound \
	-ddd -n:test5c -B:rt -a:1 \
	-f:s32_le,2,48000 \
	-i:alsa,hw:Loopback,1 \
	-a:1 \
Turned on Volumio playback, started ecasound and "nothing" except an audio blip that hints of something being connected. Checked ecasound using interactive mode with debug option (-c -ddd) and there are no errors. Checked aio-status and the buffers seem to be working / moving / delay variations.
So I'm stumped (with limited Linux knowledge) and could use another set of eyes on this and some suggestions.
Old 26th February 2018, 03:22 AM   #54
DonVK's Avatar
Default Working loopback and ecasound... fixed
I have a working solution now.
I don't understand why the syntax appears to be different for addressing the loopback and the soundcard within the script. I don't understand why ecasound didn't throw errors before and it worked for files. I don't like hardcoding card numbers but labels don't work here. Complaints aside, this script does work, and it opens a lot of possibilities with LADPSA plugins. The ecasound filters and parametric equalizers are working, no xruns. Sounds good.
I have temporarily broken the volume control on Volumio during loopback. I think its because I switched Volumio playback device = loopback, and it lacks an associated volume control (mixer) for now. So in the interm I use the alsamixer volume controls. Its also the only place I can access the subwoofer volume controls.
I added some CPU loading snaps for webradio and mp3 over NAS. Lots of capacity left.
Code:
#!/bin/bash
ecasound \
	-ddd -B:rt \
	-n:test5f -b:256\
	-f:s32_le,2,48000 \
	-i:alsahw,0,1 \
	-el:RTlr4lowpass,18000 \
	-o:alsahw,2,0
Old 27th February 2018, 10:03 PM   #55
DonVK's Avatar
Default ... adding more loopbacks
Now that ecasound is connected, I need another loopback. After much googling and reading.
The signal flow plan is [mpd] -> loopback -> [ecasound] -> loopback -> [brutefir] -> PianoDAC. The speaker is equalized using ecasound (done), then once the FR is flat, the phase (or room) is corrected using a rephase FIR filter with brutefir. I realize it can all be done in one step with the convolution engine, I just find it easier to separate the amplitude correction from the phase / room correction. It also lets me listen to incremental improvements.
It always seems that there are many places to do anything in Linux. I found that adding a line to /etc/modprobe.d/alsa-base.conf does the trick. You get the following soundcard list. I now have 2 loopback soundcards and I changed the index# to be after the physical soundcards.
Code:
options snd_aloop enable=1,1 index=2,3 id=EcaLoop,BfLoop
Old 28th February 2018, 11:52 PM   #56
DonVK's Avatar
Default ... adding Brutefir to the path
I have a working path [mpd]->loopback->[ecasound]->loopback->[brutefir]. Loopback#1 is selected via Volumio as playback device. I'm using web radio as a source.
I'm still messing with settings on Brutefir but using a known working FIR filter for phase correction. The filter is a mono 32b float, 16384 taps, at 48Khz using on both the right and left channels.
Ecasound now has 8 * para eqs + 1 * LR4 HP + 1 * LR4 LP running.
The RPI + Piano2.1 are in plastic box, cpu_temp=61C steady state. The CPU load is still reasonable, shown in the pic. There are also 4 Bitvise SSH +SFTP sessions running as I need 4 console windows to manually start and monitor at this stage.
Old 3rd March 2018, 03:39 AM   #57
DonVK's Avatar
Default Brutefir configuration
I forgot to mention the install for Brutefir. I've played a bit with the Volumio plugin Brutefir2 but had some issues with it. The Brutefir docs and other examples I based this on at :
- BruteFIR
- Setting up BruteFIR
- [Guide] High quality room correction with Raspberry Pi & Roon - Raspberry Pi - Roon Labs Community
I put everything related to Brutefir in /home/brutefir.
Code:
mkdir /home/brutefir
cd /home/brutefir
sudo apt-get install brutefir
nano brutefir_config
If you don't have a filter, or you're debugging a configuration you can use a built in filter file called "dirac pulse" in place of your filter coefficient file below. It does not affect the sound output, and uses the filter length (#taps) and sample rate specified in the config file.
Code:
coeff "c-l" {
   filename: "dirac pulse";
   format: "FLOAT_LE";
Information on the accepted filter coefficient file is hard to find. I use RePhase to generate the filter file and it has multiple formats as well. After trying a few times it appears that Brutefir needs a raw file like Rephase *.bin or *.dbl formats, and they should be mono format. Even a *.wav file "might" work as long as you can get the right offset to skip the header, otherwise the header will become part of your filter.. The tap length, data format, and sample rates all must be explicitly stated. Brutefir uses floating point internally, so I give it floating point filter coefficients, the I/O s32_le are converted by Brutefir. The config file I used as follows:
Code:
## BruteFir config   ##
float_bits: 32;             # internal floating point precision, 32b or 64b
sampling_rate: 48000;       # sampling rate in Hz of audio interfaces
filter_length: 16384,4;     # length of filters, divided into 4 partions
#config_file: "~/.brutefir_config"; # standard location of main config file
overflow_warnings: true;    # echo warnings to stderr if overflow occurs
show_progress: false;       # echo filtering progress to stderr
max_dither_table_size: 0;   # maximum size in bytes of precalculated dither
allow_poll_mode: false;     # allow use of input poll mode
modules_path: ".";          # extra path where to find BruteFIR modules
monitor_rate: false;        # monitor sample rate
powersave: true;            # pause filtering when input is zero
lock_memory: true;          # try to lock memory if realtime prio is set
sdf_length: 31,9;           # sinc subsample filter half length in samples, kaiser window
safety_limit: -2;           # abort if output > safety limit, if non-zero max dB
convolver_config: "/home/brutefir/brutefir_convolver"; # location of convolver config file
logic: "cli" { port: 3030; };  # attempt to access the command line ** failed ***
## COEFF DEFAULTS ##
coeff "c-l" {
   filename: "mono48Kieee32b.bin";
   format: "FLOAT_LE";
coeff "c-r" {
   filename:"mono48Kieee32b.bin";
   format: "FLOAT_LE";
## INPUT DEFAULTS ##
input "left_in", "right_in" {
        device: "alsa" { device: "hw:3,1"; ignore_xrun: true; };
        sample: "S32_LE";
        channels: 2/0,1;
        mute: false,false;
## OUTPUT analog
output "left_out", "right_out" {
        device: "alsa" { device: "hw:1,0"; ignore_xrun: true; };
        sample: "S32_LE";
        channels: 2/0,1;
        dither: false;
## FILTER DEFAULTS ##
filter "PhaseCorr_l" {
   from_inputs: "left_in"/3;    # attenuate input -3dB
   to_outputs: "left_out";
   process: -1;                 # auto assign process load balance on multicore
   coeff: "c-l";
filter "PhaseCorr_r" {
   from_inputs: "right_in"/3;   # attenutate input -3dB
   to_outputs: "right_out";
Run "brutefir brutefir_config" in the /home/brutefir directory and it will generate a "brutefir_convolver" file specific to the RPI.
Old 8th March 2018, 09:54 PM   #58
DonVK's Avatar
Default running Brutefir and Ecasound at startup
I added brutefir and ecasound to /etc/rc.local so they run on startup. This is the /etc/rc.local file.
Code:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing
# start brutefir
cd /home/brutefir
brutefir /home/brutefir/brutefir_config5 &
# start ecasound,  must start in "-q" quiet mode, so no terminal is reqd
/usr/local/bin/ecatest7.sh &
exit 0
The /home/brutefir/brutefir_config is the same as the previous post. Note that the ecasound script now uses ecasound in "quiet" mode otherwise a terminal window will be required for its output. This is /usr/local/bin/ecatest7.sh script.
Code:
#!/bin/bash
# OmniV5 equalization, start in quiet mode for rc.local
# input from mpd via EcaLoop (#2) and output to BfLoop (#3) then to Piano
/usr/bin/ecasound \
	-q \
	-B:rt \
	-n:OmniV5eq -b:256\
	-f:s32_le,2,48000 \
	-i:alsahw,2,1 \
	-el:RTlr4hipass,18 \
	-el:RTparaeq,5,31,4.3 \
	-el:RTparaeq,3,40,4.3 \
	-el:RTparaeq,3,1000,4.3 \
	-el:RTparaeq,2,1250,4.3 \
	-el:RTparaeq,1,2500,4.3 \
	-el:RTparaeq,-2,4000,4.3 \
	-el:RTparaeq,-2.6,5000,4.3 \
	-el:RTparaeq,-2,6300,4.3 \
	-o:alsahw,3,0
exit 0
Old 18th April 2018, 12:37 AM   #59
DonVK's Avatar
Default Volumio upgrade
I'm always nervous about "updates". So after a system backup, I allowed Volumio to self update to the latest version 2.389.
Much to my relief (surprise?) all the changes that I made remained in tack, and the Volumio update worked with no ill effects.
Old 9th May 2018, 11:36 PM   #60
mfeif is offline mfeif
Default Delay in filters in on-board TI DSP
Hi folks.
I saw some smart-sounding discussion above on setting up filters in PurePath for the Piano 2.1.
I'm interested in doing an active digital crossover[1] on the DSP itself, but I saw the talk about buffer length and got worried, because one thing I need to do is to delay two of the four channels by 6ms.
I'm handy with computers, but not very good with analog sound science or digital logic, so I'm having trouble decoding the TI datasheet for the relevant DAC chip on the Piano. Do those of you who have played around with PurePath and the two PCM5142's know if what I want to do is likely to work?
I understand that a rpi or equivalent has plenty of horsepower to do this kind of thing in software, but I'm not sure how to get access to the BOTH dacs on the Piano that way. Perhaps someone who's got a Piano 2.1 can let me know if all 4 channels are available to ALSA?
Before I send in the money and get boards shipped from India, I was hoping to find out if what I want to do is possible; I know there's no guarantee :-)
1: I am making some of these and would like to skip adding the stand-alone DSP unit: LXmini Challenge
Raspberry Pi with Piano2.1 DAC DSP and Volumio2Hide this!Advertise here!
DAC for Raspberry Pi LaxAnErde Digital Line Level 24 26th April 2018 05:58 AM
Tutorial: Raspberry Pi as Music Server, DSP, and Crossover jrubins PC Based 75 6th January 2017 04:28 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Which DAC for Raspberry Pi? Miller-8 PC Based 14 10th August 2016 03:18 AM
Raspberry Pi DAC Help! pamantea Digital Source 26 8th November 2015 07:50 PM
