PC Based Computer music servers, crossovers, and equalization
Multi-channel DAC
Multi-channel DAC
Old 25th September 2017, 03:42 AM   #21
BYRTT is offline BYRTT  Denmark
Multi-channel DAC
Originally Posted by JohnnyInBris View Post
I was looking for a not too expensive multi-channel DAC so that I could experiment with active crossovers in the digital domain using APO equaliser.
The product I purchased is an ASUS XONAR U7. This has quite good specs for a 7.1 DAC and I'm very happy with. It's USB powered and very quiet.
I've implemented a 3-way crossover using Linkwitz-Riley filters which can be implemented in APO by cascading 2nd order Butterworth filters.
The only minor downside is that being such a small device, 3.5mm stereo jacks are required to interface it.
Originally Posted by arcgotic View Post
I have Asus Xonar U7 and think of upgrade. Did you have the chance to hear also Xonar U7?
Looks u guys use ASUS U7, can i warn you if OS is Windows you should check via loopback if you on latest driver version for phase distortions.
Here is mine loopback 44,1kHz on latest driver Win7 using ASIO, absolut phase/min phase/Excess phase curves as should be are close in coherence.
Multi-channel DAC-2000-png
Here is same loopback 44,1kHz on latest driver Win7 using WDM, amplitude is overall -3dB lower plus a bump around 115Hz but it gets worse in it also has build in 1080º excess phase as was there 3 times 4th order XO points finding place. Long ago contacted their support department but all they did was clean up a bit on support page for U7 so in a way they must mean it seriously.
Multi-channel DAC-2001-png
Can't live with above performance myself so use one of the older drivers to get WDM phase follow amplitude as a real minimum phase device.
Old 29th November 2017, 02:59 AM   #22
reggieSf25 is offline reggieSf25  United States
This looks like the ticket!??, Does anyone have an idea how this would perform?
Old 9th December 2017, 06:50 AM   #23
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
I currently have a Creative Omni 5.1 USB. Would the ESI be better in comparison to the consumer grade Creative sound card?
Multi-channel DACHide this!Advertise here!
Ultimate multi-channel DAC intgenx Digital Line Level 69 14th October 2017 10:27 AM
Multi channel and multibit DAC jpak Digital Line Level 4 25th April 2017 04:19 PM
Multi channel DAC ubza1234 Digital Line Level 8 24th November 2016 07:17 PM
Multi channel DAC ubza1234 Acoustic Fun 0 23rd November 2016 10:06 PM
Multi-channel DAC Differences labjr Digital Source 2 28th August 2007 10:43 AM
