PC Based Computer music servers, crossovers, and equalization
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
Old 11th December 2017, 12:23 PM   #81
pistollero is offline pistollero  Portugal
It would be nice some options for the output stage...
Tubes, transformer, discrete.
Than we could choose the one we like...balanced or single ended.
Than everyone would be happy.
Old 14th December 2017, 02:05 PM   #82
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Would be nice something that you can just stack on top of the DAC and allow for many output options. A bit like the VZaudio Modular NS OPS amplifier, it has the option of adding different IPS to it. They have several SS designs available and a Tube IPS as well. I love the modular approach!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 14th December 2017, 02:42 PM   #83
iancanada is offline iancanada  Canada
iancanada's Avatar
Do
That's really a good idea. Will do it this way.
My DAC will have raw balanced outputs to the daughter board that stacks on top of it. The interface will be open source to community members. You can even design IV/analog stage by your self. Discrete, transformer,tube,OP...everything is possible. You may have different kind of daughter boards for it. A lot of fun
I'll post more solutions later. I hope you like them.
Thank you so much.
Ian
Old 14th December 2017, 09:23 PM   #84
xaled is offline xaled
Hi Ian,
Would a raw single ended output for the daughter board be possible?
Old 14th December 2017, 11:06 PM   #85
iancanada's Avatar
Originally Posted by xaled View Post
Hi Ian,
What do you mean "ended output"?
Ian
Old 14th December 2017, 11:14 PM   #86
BryceJ is offline BryceJ  Canada
Ian
Not balanced.
Old 14th December 2017, 11:18 PM   #87
Thank you so much.
Ian
That's perfect!!!
Old 14th December 2017, 11:22 PM   #88
iancanada's Avatar
Originally Posted by BryceJ View Post
Not balanced.
Thanks,
Hi Ian,
The DAC raw out signals are balanced. It is possible to be converted to both balanced and signal ended line output signals on I/V board (daughter board).
Ian
Old 15th December 2017, 10:08 AM   #89
Thanks,
Ian
Ok, thanks.
I thought ESS DAC has both options as raw output.
Old 15th December 2017, 12:26 PM   #90
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Ok, thanks.
Yes, you can have balanced or unbalanced outputs:
- in "voltage output mode": simply use one phase of the DAC output, and feed this to a high-impedance input of a reconstruction filter. The opposite DAC phase is left open.
- in "Current output mode" (normal mode), there are various methods of single-ended output generation:
- the standard differential I→V with reconstruction filter, followed by a Differential-to-SE stage;
- or, apply a single I→V to one DAC phase, while routing the opposite phase to terminate current (example: to A_VCC, A_VCC/2, or A_GND)
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry PiHide this!Advertise here!
I/V stage for ES9028Q2M gandolf Digital Line Level 25 9th February 2018 06:04 AM
ES9028Q2M balanced output evert1 Digital Line Level 0 26th December 2017 01:30 PM
ES9018K2M: best (Raspberry)-OS/384 khz + dtoverlay sfb2 PC Based 2 30th May 2017 09:43 PM
Hats off to Mr Pass, encouragement to new members Russellc Pass Labs 10 17th May 2015 08:23 AM
Hats make better bass? xstephanx Subwoofers 11 9th February 2005 10:59 AM
