PC Based Computer music servers, crossovers, and equalization
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
Old 28th January 2017, 03:30 PM   #11
soundcheck is offline soundcheck  Germany
Don't forget the I2S reclocker/filter/isolator!!
I don't see these features showing up in your block diagram.
Good luck with your project.
Old 30th January 2017, 12:08 AM   #12
sckramer is offline sckramer  United States
sckramer's Avatar
Gotta play devil's advocate... why? An off the shelf dac chip? With your talent-- could write a Dac/Filter in an FPGA.
How about FIFO III & pi FIFO II ;P
And that awesome pi isolator??? The GB list is getting long!
Scott Kramer - AudioSystem - YouTube - Twitter
Old 4th February 2017, 05:06 PM   #13
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Subscribed...
'loving the PI as headless musicsource
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 17th February 2017, 08:13 PM   #14
BryceJ is offline BryceJ  Canada
Ian, are you going to implement the hardware volume control in this DAC?
I assume that this is the same as the 9023 chips and that it must be done through software and the I2C connection.
Old 21st April 2017, 08:48 AM   #15
SomekPoland is online now SomekPoland  Poland
I would say, that some rechecking may be a good idea, don't we all agree, that RPi generated I2S isn't too good?
Old 21st April 2017, 09:22 AM   #16
Dimdim is offline Dimdim  Greece
Knowing Ian, he's probably planning on running the 9018K2M in master mode..
http://www.dimdim.gr
Old 21st April 2017, 01:45 PM   #17
iancanada is offline iancanada  Canada
iancanada's Avatar
The highlighted part of this DAC would be playing both DSD and I2S on top of RPi.
However, everybody knows the issue of RPi, the signal quality...
Yes, to achieve higher sound quality, we have to run it in master mode. A FIFO or a master mode re-clocker will be required in this case.
I'm gonna design a FifoPi with built-in DSD decoder for it. I hope I can start very soon ...
Ian
Old 27th April 2017, 06:10 PM   #18
Eldam is offline Eldam  France
Banned
Hi Ian,
You finally never told us if you were hearing a difference with the I2S output of an Odroid C1+ vs a Pi3 as you have both ?
And ultimatly if a difference occurs (at ears) despite the Fifo+isolator+reclocker ?
Does it no make sense to deal with ESS9038 or AK chip ?
on this project : no sota ESS electrical voltage reference chip and sota ldo reg ?? NDK or similar very near of the dac chip, to stay cost low ??? Many Pi dac hats are existing already, what is the plus ?
Old 27th April 2017, 07:33 PM   #19
yoke is offline yoke  Croatia
yoke's Avatar
Subscribed
Old 15th May 2017, 01:08 PM   #20
Tomax is offline Tomax
Hi Ian,
anything new on this topic or did you discard your plans building this HAT DAC?
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry PiHide this!Advertise here!
I/V stage for ES9028Q2M gandolf Digital Line Level 25 9th February 2018 06:04 AM
ES9028Q2M balanced output evert1 Digital Line Level 0 26th December 2017 01:30 PM
ES9018K2M: best (Raspberry)-OS/384 khz + dtoverlay sfb2 PC Based 2 30th May 2017 09:43 PM
Hats off to Mr Pass, encouragement to new members Russellc Pass Labs 10 17th May 2015 08:23 AM
Hats make better bass? xstephanx Subwoofers 11 9th February 2005 10:59 AM
