hello,
i'm installing Mood Audio Player on raspberry pi 3 whit a DAC audiophonics Sabre 9023:
AUDIOPHONICS DAC Sabre ES9023 V2.2 I2S vers Analogique 24bit/192kHz - Audiophonics
I have setted the OS mood after have connected raspberry pi 3 to DAC ...
I have succeeded in controlled the raspberry remotely with diyAudio server HTTPS page (wireless)
I have succeeded in product sound by hdmi
But i am blocked when i want product sound by i2S output of the DAC ...
I have restarted the system for save the configuration many times ...
If you have ideas ... suggestions ... ?
PS= relied in Double RCA to Jack 3,5 (little jack) on my ampli
After a few days of very good performance, a similar raspberry pi dac hat stopped working.
It is powered up (red led is lit), alsacap shows the audio card, but there is no sound coming from the RCA connectors.
The DAC is this one:
https://aliexpress.com/item/32915365910.html
It is a dual ES9023. Image attached.
In volumio it was working with I2S and a "standard" Hifiberry DAC setting.
Tried new volumio installation, tried moode with similar settings, no way. Silence.
Any idea?
Any idea?
