This Taobao board (USB input) coupled to a pair of home-made transformers (its output is balanced, needs step down too) kicks the *** of plenty of much more expensive DAC+amp combinations for driving headphones up to 600ohm impedance. Transformers I'm using are PQ50/50 ferrite cores, you'll also need a supply, a laptop brick @ 19V will do fine.
https://item.taobao.com/item.htm?spm=a230r.1.14.47.T66APU&id=526018865372&ns=1&abbucket=13#detail
