Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
PC Based Computer music servers, crossovers, and equalization |
#81 |
Thanks - when can we try this ?
#82 |
Your project is quite interesting, and I do not see too many people inquiring about it, but I hope you will not be discouraged (it does not seem so)!
#83 |
Thanks for your interest. I am currently re-organizing and writing the code. Then there must be a period of testing and listening as well as some commenting and code cleanup. It will probably be another month or more, but it's coming along.
#84 |
I am certainly watching. No current need, but possible future needs....
#85 | |
I have the concept figured out and snippets of code written. I now will begin the process of integrating this code into the existing larger application followed by debugging and testing. Last edited by CharlieLaub; 9th March 2018 at 01:37 AM. |
#86 |
Charlie, when you started this is was "bash script". Is it still the case, or is there lower level code or kernel mods?
#87 | |
The previous version is still available for download here: GSASysCon - A bash-script-based streaming audio system controller |
#88 |
UPDATE - I see light at the end of the programming tunnel!
After a lot of planning, and coding, and debugging over the past week I am happy to say the code is finally coming together. The hurdle of getting the script to function and to produce the correct gstreamer pipeline now seems to be overcome. There is still some ground to cover while the code is further tested, audio output listened to, things are cleaned up, and so on. This will probably take another couple of weeks on account of some travel plans, but so far this is very encouraging. This new upgraded version of GSASysCon will replace my go-to audio filtering/crossover/processing tool, Ecasound. It can also serve as a software-based replacement for hardware IIR DSPs like the miniDSP, but with additional features like streaming, multiple clients, and centralization of code and crossover commands on the server-side. Hopefully this will gain some interest from the DIY loudspeaker community. Spread the word! |
#89 |
Congratulations on your progress!
#90 |
... and just when I started using ecasound, you've obsoleted it.
What's providing the LADSPA host for the plugins? and can other plugins be used? P.S. thanks Charlie for the many previous trouble shooting posts on getting ecasound running. Too many to reference. ![]() |
Thread | Thread Starter | Forum | Replies | Last Post |
New BeagleBone based Audio System | dogrocket | Vendor's Bazaar | 3 | 1st April 2016 04:02 AM |
XMOS audio streaming controller GB interest | heartwinter | Group Buys | 12 | 13th July 2015 04:30 PM |
USB streaming controller | arjunm009 | Digital Line Level | 2 | 12th May 2015 04:38 AM |
First audio project, Wall controller for room audio system, looking for guidance, | Chrisdvip | Construction Tips | 2 | 10th June 2013 05:47 AM |
Audio System Controller | happyboy | Analog Line Level | 9 | 12th September 2012 09:12 AM |
New To Site? | Need Help? |
