PC Based Computer music servers, crossovers, and equalization
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoder
Old 2nd December 2017, 08:15 PM   #321
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by audioengr View Post
Got it. I have to investigate, but I assume I can run PiCoreplayer with Roon Bridge?
So I guess you are saying that you don't have a solution for S/PDIF output to do DSD128 using DoP?
Are all S/PDIF limited to DSD64 using DoP?
Steve N .
Hi Steve,
I guess so. For now, no spdif solution can go higher than 192KHz, so the maximal DoP would be DSD64 in this case.
But I confirmed piCorePlayer can go up to DSD128 over Pi GPIO.
Ian
Old 2nd December 2017, 08:45 PM   #322
audioengr is offline audioengr  United States
Originally Posted by iancanada View Post
Hi Steve,
Ian
Thanks for this clarification. This means that there is probably no point to doing a custom I2S to S/PDIF implementation to support DOP at 128. The off-the-shelf digital audio interfaces are sufficient.
Not sure I can use piCorePlayer. No mention of Roon in the documents.
Steve N.
The very best in computer audio
Old 2nd December 2017, 11:12 PM   #323
iancanada's Avatar
Steve N.
piCorePlayer is different from Volumio and other player, basically it needs three things:
1. RPi with piCorePlayer SD;
2. A Logitech Media Server 7.9 (LMS), I would recommend to install it on a PC
3. Install a remote control squeezebox on you cell phone
Ian
Old 3rd December 2017, 12:06 AM   #324
I need Roon, so I think I will stick with Volumio.
Steve N.
Old 3rd December 2017, 03:23 AM   #325
iancanada's Avatar
Steve N.
Volumio doesn't support 384KHz/DSD128 so far. Hope they can upgrade soon.
Ian
Old 3rd December 2017, 07:08 AM   #326
Yatsushiro is offline Yatsushiro  United Kingdom
Steve N.
You may want to have a look at Ropieee RoPieee | RoPieee: a RoonBridge ready-to-go image for Raspberry Pi
Old 5th December 2017, 08:08 PM   #327
Ian
According to Michelangelo, it does support up to 24/768 PCM. It's the drivers that do not support it.
Steve N.
Old 14th December 2017, 06:46 PM   #328
janosch simon is offline janosch simon  Germany
got the isolator pi and the dsd decoder board for my raspberry pi 3 and my soekris dam1021 and it works now perfect with volumio but only dsd64 in soekris serial output its recognized as L02M when i try dsd128 or dsd256 volumio give me and [alsa]: Failed to configure DSD-over-PCM on ALSA device "hw:1,0". error hope they can fix that
but sound is spectacular
cheers janosch
Old 25th December 2017, 03:33 PM   #329
cu6apum is offline cu6apum  Russian Federation
Hi folks.
Having tried to read this topic both from the beginning and from the end, I could not find out the way you kicked the native dsd bus out of pi. Just got overwhelmed with a lot of hat and module discussions, not much on actual info on the driver.
Would you please poke me into the right post?
Thank you.
I'm using a BBG with Botic driver, but single-core board with only half a gig sometimes seems to be not enough.
Old 25th December 2017, 04:28 PM   #330
wealas is offline wealas
There is no native DSD bus. Nobody except Miero has written the code for a SoC to push DSD native over I2S. Everybody else supports DoP which is limited to DSD64 or 128 at best.
That is why I ended up with a BBB with the Botic kernel (after 2 RPI3, and OrangePI and a NanoPi) and that handles at least 2 channel DSD512.
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoderHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 120 14th November 2017 07:25 AM
Raspberry Pi: I2S Fundamental issues! diyinhh Digital Line Level 24 4th January 2016 11:59 PM
Raspberry Pi I2S question LinuxGeek PC Based 1 6th October 2015 09:21 PM
Raspberry Pi I2S output as Asynchronous USB-to-I2S Tinco Digital Line Level 26 27th September 2013 02:18 AM
How to connect PMD-100 chip with Sony's CDX 2750Q Dsd decoder soundofvoid Digital Source 1 12th April 2007 09:15 PM
