PC Based Computer music servers, crossovers, and equalization
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoder
Old 17th May 2016, 12:59 PM   #11
Abartels1965 is offline Abartels1965  Netherlands
Hi Ian,
Count me in too please, btw, still have troubles with FIFO II, could be a psu problem,
(oscillating), will try BP first.
Old 18th May 2016, 07:36 AM   #12
soundcheck is offline soundcheck  Germany
Can other PI HAT DACs be put on top of it??
Or at least would there be a "plug-in" option for a small DAC chip as used by HifiBerry IQaudio asf.
I understand that the main intention behind this project is to provide external I2S DACs
with a quality streaming interface.
However. There is huge number of users out there using and loving HAT DACs because of their simplicity. Usually price/performance ratio is outstanding with these DACs too.
Beside that they are very easy to implement.
I know that your solutions or better, solutions around your high quality gadgets, are usually all but easy to implement. "Easy" in terms of not fiddling around with numerous other boards, regulators, power supplies , cables ...
At least from my perspective it would be nice to have a simple stack and forget "transparency layer" that cleans up the mess between my PI and my HAT DAC.
I do have the feeling though that this project won't supply such a solution.
Perhaps a simple "plug-in" DAC daughter board could be developed.
Old 19th May 2016, 01:50 PM   #13
iancanada is offline iancanada  Canada
iancanada's Avatar
Hi soundcheck,
That's a very good point. I have same idea with you.
Yes, this Rpi isolator HAT is originally designed as "transparency layer". That measns all current DAC HAT, such as HifiBerry DAC, DAC+ and DAC Pro, and meany others, will work with this isolator as if there is without this isolator. No any additional overlay or software support will be needed.
By following foundation's HAT specification, all DAC can be stacked on top of my RPi isolator. Because all GPIO connectors and dimensions are as same as a RPi.
So, all RPi DAC users can enjoy this isolator by just simple stacking it over a Raspberry Pi, then their DAC HAT.
It's "easy". Just hope you are happy with it.
Ian
Old 19th May 2016, 03:04 PM   #14
jonners is offline jonners  United Kingdom
jonners's Avatar
Ian
Sounds great to me , I'm very interested.
Old 19th May 2016, 10:34 PM   #15
supra is offline supra  Australia
But still applicable for those of us who want to use FIFO,iso,double clock,PCm board with Odroid?
Old 20th May 2016, 05:47 AM   #16
Thx Ian.
Great that you clarified the subject.
That makes it a very interesting project.
Beside that those or new HAT DACs can be made much less sophisticated since you'd cover that part.
Is your board available?
Old 20th May 2016, 08:14 AM   #17
simon dart is offline simon dart  United Kingdom
simon dart's Avatar
Fantastic Ian! Thanks for sharing this with us. Subscribed!
Bill Bryson: It is no longer permitted to be stupid and slow. You must choose one or the other.
Old 20th May 2016, 09:13 AM   #18
gwikse is offline gwikse  Norway
Great project. Following with interest. Will you offer these boards as bare pcb`s or fully/partially populated pcb`s ?
JRMC (PC) / ROON (RPI-ROONbridge) | .... DIY ..... | Nordost Heimdall | AP Virgo V
Old 20th May 2016, 10:47 AM   #19
simon dart's Avatar
Hi Ian,
Excuse me if I'm being dim but I'm unclear from your block diagram. Will both the 3.3v and the 5v feeds to the stacked Rpi HAT DAC be isolated from the Rpi and fed regulated power from your isolator?
Old 20th May 2016, 11:41 AM   #20
I had the same question in mind.
e.g. My HifiBerry DAC+ Pro uses the poor 3.3V (both pins) from RPI to power VDD and the clocks. And that's hardwired.
As far as I understood Ians blockdiagramm there'll be a clean 5V and 3.3V made available.
That seems to cover my situation.
But then I'm asking myself what supply voltage would be required for the board on the
clean side. Obviously something >5V e.g. 7V minimum DC would be needed.
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoderHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 120 14th November 2017 07:25 AM
Raspberry Pi: I2S Fundamental issues! diyinhh Digital Line Level 24 4th January 2016 11:59 PM
Raspberry Pi I2S question LinuxGeek PC Based 1 6th October 2015 09:21 PM
Raspberry Pi I2S output as Asynchronous USB-to-I2S Tinco Digital Line Level 26 27th September 2013 02:18 AM
How to connect PMD-100 chip with Sony's CDX 2750Q Dsd decoder soundofvoid Digital Source 1 12th April 2007 09:15 PM
