PC Based Computer music servers, crossovers, and equalization
wtfplay project - Linux based PC playback system
Old 26th February 2018, 07:23 AM   #161
Sligolad is offline Sligolad  Ireland
2 years this week since launch and it is still one of the great undiscovered sound quality improvements to be discovered by many so called sound quality purists!!
Hard to believe but we can be glad that we are the lucky ones to discover this great player :-)
Old 10th March 2018, 03:11 PM   #162
Smusique is offline Smusique  France
Bonjour
Merci pour votre travail , la musique c'est la vie.
Hello
Thank you for your work, music is life
Old 11th March 2018, 02:14 PM   #163
hopkins is offline hopkins  France
Hi, has anyone used this with a simple Chromebook?
Old 11th March 2018, 04:23 PM   #164
I was just wondering what the cheapest solution would be to run wtfplay. A notebook seems like the most convenient option. It seems it would not need to have too much processing power. Any recommendations would be appreciated.
Old 12th March 2018, 10:49 AM   #165
Goto is offline Goto  United Kingdom
Depends how patient you are. Fredryck has stated he is working to port to a Odroid or similar SOC type system. This will hopefully provide a nice low power, low noise and low cost option.
No idea what the release date is though.
Modern low powered Intel (e.g. Atom, Celeron) processors should work fine so a decent notebook with a usb DAC should be fine. You'll need enough ram for your largest track of course.
Old 12th March 2018, 11:48 AM   #166
Thanks.
Here is a short evaluation I wrote up on a French forum: Wtfplay
I also put the link on Computer Audiophile.
Kudos to the developer! Hope the future versions will not sacrifice SQ for the benefit of functionality....
Old 12th March 2018, 09:42 PM   #167
sempronio is online now sempronio  Italy
Confirm.
I use an old, cheap Asus EEEPC netbook powered by Atom N450, 2 gB RAM, and it works fine.
Old 16th March 2018, 02:51 PM   #168
Leon Dupuis is offline Leon Dupuis  Italy
Default i586 CPU
Hi, super noob question i guess.
I'm trying to install in an old thin client (maybe hp t5000, it's not in the original case so i don't know precisely). I think i've tried all the iso, same error:
"This kernel requires an x86-64 CPU, but only detected an i586 CPU.
Unable to boot - please use a kernel appropriate for your CPU."
Is there a solution or it's impossible to install on this device?
Regards, Marco.
Old 21st March 2018, 06:45 AM   #169
I have tried to reproduce a similar system with my sparky board (running dietpi)
I have made a very simple script that does the following:
- deactivates the network interface
- stops various programs (those I typically use for audio, and the ssh server)
- mounts an SD card where I have my music files
- creates a ram disk and copies files to the ram disk
- plays file from the ram disk with aplay (and period/buffer settings)
Obviously I do not have a working ncurses interface to allow me to make and run the playlist.
Are there additional tunings that are included in wtfplay or is this basically what wtfplay is doing?
Old 26th April 2018, 05:17 PM   #170
LEZARDO is offline LEZARDO  Europe
Default Test with DSD and FLAC files.. good
Thank you for your distribution.
With mi DAC named "iFi nano" the sound it's good.
I tested with DSD and FLAC files, with wtfplay-dsd command.
I hope you continue in this project....
Audiophile Greetings.
wtfplay project - Linux based PC playback systemHide this!Advertise here!
Linux-Based Low-Latency Multichannel Audio System henrix PC Based 8 8th September 2016 06:13 PM
My Home and Remote Linux Based System Mando Rob PC Based 6 11th June 2015 11:51 PM
Help with PC based loudspeaker system, ground up. drivemusicnow PC Based 21 7th February 2014 11:06 PM
PC based audio system questions joonze PC Based 7 2nd May 2012 08:48 PM
Need recommendation for a PC-based measuring system andy2 Multi-Way 10 23rd December 2006 10:27 AM
