PC Based Computer music servers, crossovers, and equalization
i2s connection - Orange/Dac
Old 2nd October 2017, 05:31 PM   #101
cu6apum is offline cu6apum  Russian Federation
Anybody made it in slave i2s mode yet? Mclk from dac side.
Old 30th November 2017, 10:51 AM   #102
ua3nbw is offline ua3nbw
I2S slave on mainline 4.13
Russian page I2S slave на mainline ядре OrangePi
Old 30th November 2017, 11:42 AM   #103
Dimdim is offline Dimdim  Greece
This is very interesting! I suppose that your patch will work on any OrangePi board, as long as it is based on the Allwinner H3?
http://www.dimdim.gr
Old 30th November 2017, 12:53 PM   #104
Yes H2/H3/H5
Old 3rd December 2017, 06:43 PM   #105
wealas is offline wealas
Any chance you can add support for DSD and 768K Pcm? I would like to drive a ESS9038PRO from a NanoPi NEO2 without additional USB-to-I2S converter. If I understand correctly it should just be a matter of bumping up the supported frequencies and adding logic for the correct clock divider.
Old 3rd December 2017, 08:36 PM   #106
NanoPi-NEO ALSA-Add-rate-defines-for-352k8-and-384k
NanoPi-NEO/NanoPi-NEO-i2s.txt at master * takobozu/NanoPi-NEO * GitHub
Old 11th December 2017, 07:33 PM   #107
I cannot find out how the external clock is fed into the board, there is no input on defined? Do I need to modify the board somehow?
Old 11th December 2017, 08:45 PM   #108
Nevermind, it's not using an MLCK but expects BCLK and LRCK as input thus the need for not only clock selection but divider selection as well. Now I have to figure out how to make it work with Ian's McFIFO.
i2s connection - Orange/DacHide this!Advertise here!
What are You using for an I2S Connection? Magz Digital Line Level 10 27th November 2014 02:20 AM
I2S connection problem. Teralink X-2 and Javs Dac-2 March. mikone Digital Line Level 1 21st October 2010 07:13 PM
i2s connection question stephan-schulz Digital Line Level 2 25th March 2009 04:23 PM
I2s connection for cdpro2 and pcm1704 joekjtam Digital Source 2 20th May 2006 12:13 PM
Audio Alchemy I2S connection? quantran Digital Source 4 3rd October 2004 12:46 AM
