PC Based Computer music servers, crossovers, and equalization
group delay equalization
Old 26th October 2015, 02:22 AM   #11
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Or you need more taps for increased frequency resolution, and so at low frequencies or for steep changes in the frequency of phase response, you need a lot of taps. Is that statement a little more accurate???
I just think of it as low frequencies having more samples per cycle and if you have to keep HF behaving, you'd need to have taps placed all the way through. That might not be accurate, either, though. I'm certainly no expert on FIR, more or less just a user (and a big fan - there's nothing like having omnipotence over waveform shaping!).
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 26th October 2015, 05:26 PM   #12
CharlieLaub is offline CharlieLaub  United States
I've been looking into FIR filters in a little more detail. Although you can just flatten magnitude and phase using lots of taps, I'd like to look at a "lighter" use of FIR filtering for phase linearization of the higher frequencies only. I will explain with an example below.
The first attachment shows a model of a loudspeaker frequency response. This has a 4th order HP function at 30Hz to simulate a vented box, and a steep crossover at 1kHz. The resulting group delay for the system is shown in the second attachment. The GD is characterized by a rise in the low bass region, a constant but elevated region in the woofer passband, a peak at the 1kHz crossover frequency, and then a return to near zero in the tweeter passband. This general shape is typical of a loudspeaker system.
What I would like to do is to "remove" the peak at the crossover point and bring up the group delay in the tweeter's passband to the same level as the woofer. I will not attempt to modify the GD below 200Hz. We need a filter that can create the group delay EQ curve as shown by the line in the third attachment. This "removes" delay from the system at the peak around the crossover point and "adds" delay above. The result would be "flat group delay" for the loudspeaker above about 200Hz. This is the same things as linear phase in that same frequency region. At the same time we do not want to change the magnitude of the system, which has been made sufficiently flat using IIR filters.
So, how to do this? You cannot generate this phase/group-delay correction using any number of IIR filters because the group delay must be increased at higher frequencies. Instead an FIR filter is needed.
The process of generating FIR filter coefficients for constant-amplitude phase modulation seems a little different from that of FIR magnitude filtering. If I understand the process correctly, one can first calculate the phase response that corresponds to the EQ filter group delay response that we want. This can be done by integrating upwards with a phase of 0 degrees below where the GD leaves zero, and using the definition of group delay as -d(phi)/d(omega). The amplitude response for all frequencies of our EQ filter is simple set to 1 (0dB). Next we generate the impulse response of this system. The system must be causal, so in this case we would need to shift the impulse response "later" in time - this is the same as moving the group delay of the filter "up" until there are no negative values and we could have done this to the desired filter group delay earlier. We then window/truncate the impulse response where it has sufficiently died down. This gives us our FIR filter coefficients. I think. Like I said I am still learning about the process of generating FIR filters for phase-only manipulation.
What seems attractive about this is that the filter's impulse response should be short. This is because there is nothing happening at low frequencies, and high frequency components die out faster. This means that the length of the FIR filter will not be long, perhaps a couple thousand taps at the most, and a few hundred at the least. This would make the FIR filtering calculations "light", keeping latency and computational requirements low. This is important to me.
So, this looks possible, and I need to do some modeling and simulation of everything to test out my theory. If someone with more FIR knowledge can chime in to verify or refute what I have outlined above I would appreciate it.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 26th October 2015, 06:26 PM   #13
bwaslo's Avatar
Im not the guy with lots of experience you asked for, but unless you're into it for the intellectual challenge, imo you're overthinking it. All I did was first iir the response (the OpenDRC/miniSPARC does both fir and iir) flat and then get an FRD file of the complex FR of the speaker. Remove overall delay so that phase slope was nearest zero overall, but always below zero. Then take the file to RePhase, pull the phase response flat to zero, generate the taps file, export, then import into OpenDRC. Literally took about an hour. (Though the speaker was already close to linearish in phase, except in the bass because of the reflex cabinet and high slope crossover on the subs).
For what its worth, the audible change I'm most confident of was in the bass. Might be expectation bias (that's where phase is said to be audible) or might be because that was where most of the phase changes were done -above 300Hz or so everything was already within about 30 degrees before eqing). Also some response magnitudes had been changed, too. No DBT, just the impression of more solid kick like from an object instead of from resonators.
Old 26th October 2015, 06:35 PM   #14
bwaslo's Avatar
I should qualify that a bit. EQing was about an hour, but figuring how to get rid of a very low level, but annoying, whine from the OpenDRC took a few days (if anyone is having that issue, the fix is to put about 1mH in line on the red power wire between the dsp board and the dac board. Use a low dcr iron cored crossover type inductor)
Old 26th October 2015, 07:07 PM   #15
Yes, I am in it for the intellectual challenge! 100% in, in fact.
Learning the how and why, and doing it myself, is what motivates me to get up in the morning. This is why I DIY.
Old 26th October 2015, 10:12 PM   #16
This plot should show my approach a little more clearly. The un-equalized system group delay is shown in dark blue. I can equalize the group delay to the flat (linear phase above 150Hz) dashed blue line if I add group delay equal to the tan line.
To do this I will calculate the phase that corresponds to the tan line using the definition of group delay and integrating up from zero. I will then set amplitude =1 for all frequencies. I now have (amplitude, phase) pairs for all frequencies. Using the iDFT I can generate the impulse response, which may or may not be windowed. This gives the FIR filter coefficients.
I can then calculate the FFT filter frequency and phase response while I vary the number of taps to see how few I can get away with before ringing sets in, etc.
Old 26th October 2015, 11:06 PM   #17
GDO is offline GDO
GDO's Avatar
Flattening gd >150hz will do any good to the sound? What about the gd <150?
Old 26th October 2015, 11:27 PM   #18
Yes, it helps with transients, etc.
The brain is not very sensitive (at all) to large group delay there. It is more and more difficult to "fix" at lower frequencies, and this is also where it is getting large, so I do not plan on flattening this part of the group delay response at this time.
Old 26th October 2015, 11:42 PM   #19
GDO is offline GDO
GDO's Avatar
Imho, flattening a peaking gd won't do any good because will create preresponse issues: no free lunch here so better forgetting about those monstruous high order elliptic minphase stuff.
Don't agree with gd not being a problem in itself. Correcting the gd of the acoustic high pass filter of a loudspeaker(almost flat to DC) the Michael Gerzon way sounds actually very good to my ears, and works better with a closed box than with a BR. The only issue is latency, but for home hifi use and even for video with players like JRIVER in fact it is not.
Old 27th October 2015, 12:34 AM   #20
The filter will just add more or less latency (if you like that term). I don't anticipate any pre-ringing, but I plan to check for that. I don't exactly know what to expect when I vary the number of coefficients.
No I plan to use them whether I correct the group delay, or not. I have already done so in a previous loudspeaker project.
In that case I invite you to stick to your Michael Gerzon method.
group delay equalizationHide this!Advertise here!
Group Delay pargon Subwoofers 5 29th January 2010 07:37 PM
Group Delay Question 69stingray Multi-Way 12 1st November 2005 11:27 AM
Question about the group delay of this: BAM Multi-Way 1 23rd November 2003 05:07 PM
Group Delay............When Is Too Much Too Much? OMNIFEX Multi-Way 0 14th March 2003 07:30 AM
Group Delay? Ignite Multi-Way 6 13th November 2001 05:52 AM
