PC Based Computer music servers, crossovers, and equalization
Sound quality of Raspberry PI 2+ I2S DAC
Old 17th September 2015, 06:40 PM   #1
bading is offline bading  Italy
Default Sound quality of Raspberry PI 2+ I2S DAC
Hi all
I want to buy a Raspberry PI 2 to play music (with volumio) but i have read and some say that 24bit are downscaled to 16 bit, when played through RPi.
It is true that 24bit / 96Khz FLAC file with the RPi and DAC are downscaled?
Thank's
Old 18th September 2015, 02:16 AM   #2
didiet78 is offline didiet78  Indonesia
It depend on your player software configuration. Try Moode http://moodeaudio.org , Moode Audio Player for Raspberry Pi
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 18th September 2015, 03:36 AM   #3
timbarnes is offline timbarnes  United States
timbarnes's Avatar
Originally Posted by bading View Post
Hi all
Thank's
No - I use Volume with Raspberry Pi and a couple of different I2S DACs, and mpd seems happy to pass through the data unmodified. I think the HDMI output may be limited to 16 bit, but I don't believe there's any reason why the I2S output should be so limited.
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Moode, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 18th September 2015, 11:15 AM   #4
Eldam is offline Eldam  France
Banned
The problem of those boards is the quality of the I2S is not good enough : you need a MCLK to reclock the I2S output of the board not to waste the quality of those sources (bit perfect source).
But a MCLK, it seems easier and at least better for the sound to use a USB (with embeded MCLK) to I2S pcb between the nano PC board and the I2S DAC ! The asynchrone clock of the USB to I2S pcb saves you from the bad nano pc board clock !
There also some solutions to save the buy of a USB to I2S board, but it's not cheaper (e.g. a MCLK + buffered clock between the RasberryPi and the I2S DAC)
Old 18th September 2015, 12:34 PM   #5
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
According to NOTE #1 (below) in this HiFiDuino article, most i2s DAC's for Pi incorporate their own MCLK.
https://hifiduino.wordpress.com/2014...-pi-version-b/
"1. Notice that the DAC chips used are the ones that can cope without a Master Clock. RPi I2S does not Master Clock, so the DACs synch on bitclock and generate their own master clock."
Virtually all user feedback I get indicates excellent SQ from any of the i2s DAC's on the list in the article.
moodeaudio.org
https://twitter.com/MoodeAudio
Tim Curtis
Old 18th September 2015, 12:48 PM   #6
TimCurtis's Avatar
Hi all
Thank's
Not true when Linux and MPD are configured for bit-perfect audio i.e., source sample rate passes through the the audio pipeline without any sample rate conversion. Moode and many other MPD based players are configured in this way.
On the hardware side, the Pi HDMI, USB and I2S interfaces support up to 24/192 and I believe up to 32/384 over USB and I2S but I would have to look back in my notes to confirm this.
Can you provide the link(s) where this information came from?
"but i have read and some say that 24bit are downscaled to 16 bit, when played through RPi."
moodeaudio.org
Tim Curtis
Old 18th September 2015, 04:48 PM   #7
Banned
moodeaudio.org
Tim Curtis
To swap a SqueezeBox, those cheapy dac boards for Rasberry are good enough ! I talked in the spirit of something better than those plug& play boards ! Certainly a good SQ/P. In my mind a nano board is just a commodity, what ever its outputs : I will use async reclock and better : fifo buffer with its own Crystal signal and isolator !
Old 18th September 2015, 06:11 PM   #8
[QUOTE=tppc;4455746]Hi,
Comments in this article:
https://volumio.org/raspberry-pi-i2s...ounds-so-good/
Thank's for all
Old 18th September 2015, 11:32 PM   #9
TimCurtis's Avatar
Thank's for all
I'm not sure whats going on in that blog but I could not find a reference link in the posts made by user "ralf" claiming that there is some sort of i2s truncation issue. That seems very odd.
I did a bit of searching on Github and was unable to find a bug report about "i2s 24 16 bit truncation". For further investigation, maybe ask question on one of the Github threads that the Linux i2s guy (Florian Meier aka "koalo") is on.
Tim
Old 20th September 2015, 03:10 PM   #10
phalanger is offline phalanger  Netherlands
I have not tried with i2s and the considerations above should be taken into account, but I have used it with a USB DAC (MusicStreamer Pro) with excellent results. It is my main music source in my setup for months now.
I have used Volumio but preferred Runeaudio (better performance). I plan to try Moode soon as it looks promising.
Sound quality of Raspberry PI 2+ I2S DACHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
Raspberry Pi: external I2S master clock (PCM_MCLK) wutzke Digital Source 28 11th January 2017 08:49 PM
Raspberry Pi DAC options recommendations?? JonesySA Digital Line Level 11 1st May 2015 11:14 AM
Opus DAC with Raspberry Pi Type B kinku Digital Line Level 8 11th April 2015 12:11 AM
Raspberry Pi I2S output as Asynchronous USB-to-I2S Tinco Digital Line Level 26 27th September 2013 02:18 AM
