looping recording: diy cable - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 17th August 2015, 01:49 AM   #1
lane101 is offline lane101  Malaysia
Default looping recording: diy cable
I am going to diy a cable for looping recording.
I have read that using the right ohm of cable is important.
Is it right to use 110 ohm cable with 3.5mm headphone jack on the both end?
Does different type of 3.5mm headphone jack use different ohm of cable?
Old 17th August 2015, 03:09 AM   #2
benb is online now benb  United States
This is an audio signal, and the characteristic impedance (the "110 ohm" value) of the cable doesn't matter:
Transmission line impedance is critical in some applications, and not so critical in others. In analog audio, particularly, impedance is basically a nonfactor--because at the relatively low frequencies involved in analog audio, and at anything approaching ordinary lengths, any reasonably designed cable will effectively "pass through" the impedance of the devices at either end--and the input and output impedances of line-level analog audio devices themselves are usually not critical. For analog audio cables, other design considerations like shielding and capacitance may be very important, but impedance really is not.
What is Impedance, Anyway? -- Blue Jeans Cable
You can use just about any shielded cable as long as you wire it correctly.
Old 18th August 2015, 05:52 AM   #3
Good to hear. Thank you.
Can you recommend me a shielded cable?
PC recording : Choosing cable lane101 Everything Else 2 14th August 2015 04:22 AM
Recording Console DIY gfergy Introductions 6 23rd February 2014 01:37 PM
diy rca cable with Vagus 3way teflon insulated cable umut1001 Parts 5 29th August 2012 01:00 PM
Recording, playbackís poor relation? Post a DIY recording. wakibaki The Lounge 4 2nd December 2010 04:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
