PC Based Computer music servers, crossovers, and equalization
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
Old 12th February 2018, 08:40 PM   #241
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
Originally Posted by Onvinyl View Post
Would the player recognize a usb-drive with music files on it on the fly to use with lms, btw?
Hi Onvinyl,
No. Generally speaking, the LMS database needs to be updated first.
Are you familiar with the Logitech Squeezebox/LMS environment?
regards
Greg
Greg Erskine
Old 12th February 2018, 08:50 PM   #242
No, as i said, that didn‘t do it...
Hi Onvinyl,
If ever you happen to start again from a fresh SD card image, can you please capture a screen shot of the [ Main Page ] without the [ Mode ] buttons at the bottom. I would like it for debugging purposes.
BTW: What version of pCP are you using?
regards
Greg Erskine
Old 12th February 2018, 08:55 PM   #243
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Ja, i have a lms on my main computer (gentoo linux) which feeds the picoreplayer. I thought maybe i could plug the piplayer in some friends hifi gear and have my music-on-a-stick inserted. Populating the lms‘s database shouldnt take that long, or can do it at home. (have lms installed on piplayer as well)
I guess, my question boils down to: is a usb-drive automagically mounted when i plug it in or not?
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 12th February 2018, 08:57 PM   #244
Onvinyl's Avatar
If i come across it again will surly do. Perhaps it was some cache issue, the same ip was previously used by a moode player.
Old 12th February 2018, 09:13 PM   #245
piCorePlayer works just like the genuine Logitech Squeezebox player, it requires LMS.
No, using the latest pCP it is not automatically mounted.
You can have pCP and LMS on the same RPi with a USB drive attached. It does require some effort to setup.
regards
Greg Erskine
Old 17th February 2018, 12:31 PM   #246
Onvinyl's Avatar
Is it possible to switch the wifi in AP-mode? I do not see this option in the web-ui
Old 17th February 2018, 07:44 PM   #247
Wireless access point on piCorePlayer?
Greg Erskine
Old 17th February 2018, 07:58 PM   #248
Onvinyl's Avatar
Thx!
Old 23rd February 2018, 09:15 PM   #249
fccn75 is offline fccn75  United States
Just tried picoreplayer (optimized audio version 3.22) with LMS 7.7.5 and all is great. It recognizes even the Schiit Eitr transport that Daphile cannot play.
However, while the majority of the flac files I have shows up and play flawlessly, there are some foreign language files, namely Japanese files that shows up as empty.
Scouring the web brought a post regarding enabling 8.3 file format on where the music files are and recopying post enabling.
Is there a consensus that this is necessary? I tried a nightly build version 7.9 as of a few days ago, still the empty folders show up for these Japanese music files.
Can someone point me to solutions if any, thanks.
Old 23rd February 2018, 09:53 PM   #250
ianrt is offline ianrt  Australia
Check permissions on the files/directories not showing. LMS is sensitive to this.
Ian
piCorePlayer = piCore Linux + Raspberry Pi + SqueezeliteHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Another Raspberry Pi Radio rpi PC Based 17 17th June 2015 02:29 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Raspberry Pi & accessories Nikitas Swap Meet 5 5th July 2013 11:47 AM
