PC Based Computer music servers, crossovers, and equalization
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
Old 22nd October 2017, 03:43 PM   #221
Henderson is offline Henderson
Banned
Hi there,
One more PicorePlayer (the last 3.22) is playing
Datas were left on an old Synology 210J (800 MHz/128 Mo ram)
LMS with cache are on the Pi3 ; power supply is a Tecknet portable battery for Smartphone.
Datas comes through the provider box hub via a cat5 non folded and non pairs shielded cable (the most basic one can find: U/UTP)
PicorePlayer is not tweaked (Advanced menu) by switching off some functionalities (wifi, etc)
As the Pi3 is streaming through the I2S pin header via Iancanada GPIO header to I2S plugs adapter I chose in the Picore menu for this output : RPI-DAC output !
....And it worked at the first try
Very reliable development and product : bravo and many thanks to the PcP team.
Old 9th November 2017, 10:20 AM   #222
Jackybrown is offline Jackybrown
Default Can't save Squeezelite settings - "Match the requested format"
Hi Greg,
I have been using pcp v1.19 for quite a while on my Pi2 and everything runs like a dream. Thank you and the team's effort for developing such a great software!
I just bought a new Pi3 and tried the latest v3.22 pcp, but I am experiencing an issue that I can't save the Squeezelite settings if I put the "-D" as the "Device supports DoP" parameter, a "Match the requested format" pops up when I press the "save" button. (pls see the attached screen capture)
In my existing Pi2/pcp1.19, the same setting works fine. I tried to did some research on google but no luck.
Could you please advice what the issue could be? Thanks.
By the way, I tried both normal version and audio version, same issue.
File Type: png Screen Shot 2017-11-09 at 10.03.05 PM.png (136.1 KB, 295 views)
Old 9th November 2017, 10:04 PM   #223
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
hi Jackybrown,
You need to add a number not -D, the -D is added automatically.
Before you where effectively adding "-D -D".
As we develop the software we have been adding code to prevent incorrect input.
The "Various input" field is free format (I think).
regards
Greg Erskine
Old 10th November 2017, 02:45 AM   #224
Originally Posted by Greg Erskine View Post
hi Jackybrown,
regards
Thank you for your prompt response, that solves the problem!
Maybe for other newbie's benefit, just to clarify here:
If you don't put in any values in this parameter, LMS will convert the DSD file to PCM. But if you put in a number in, such as a "0", LMS will transmit the DSD file via DoP.
Again, thanks Greg! What's a wonderful software!
Old 20th November 2017, 06:06 AM   #225
cuhulong is offline cuhulong
Hi! I have PI3b+Kali+Pinao2.1. Install piCoreplayer3.22 audio version+LMS7.9.1.Playing DSD64 music is normal, has no problem!
But it plays DSD128 misic and the LMS7.9.1 condition looks normal, but, has no sound! What’s is the problem with piCoreplayer? How to set it up playing DSD128 music?
Old 11th February 2018, 09:13 AM   #226
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Hi, as of now I'm trying the picore player on my Rpi3. Great sound so far!
I understood I could switch on shairport on the 'tweaks' subsection. However, only 'hostname' and 'timezone' are displayed. What am I missing?
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 11th February 2018, 08:07 PM   #227
hi Onvinyl,
I think this may explain it.
pCP - How-to use piCorePlayer mode settings
regards
Greg
Greg Erskine
Old 11th February 2018, 08:44 PM   #228
Onvinyl's Avatar
Well, I don‘t have these tabs ‚basic|normal|advanced‘
File Type: png Bildschirmfoto vom 2018-02-11 22-46-09.png (151.4 KB, 118 views)
Old 11th February 2018, 11:47 PM   #229
Onvinyl's Avatar
Same goes for lms — without the tabs showing up, i can‘t activate it
Old 12th February 2018, 01:55 AM   #230
ianrt is offline ianrt  Australia
From memory, the extra options tabs appear on the first page (Main Page) and, once selected, then appear on the other pages.
Ian
piCorePlayer = piCore Linux + Raspberry Pi + SqueezeliteHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Another Raspberry Pi Radio rpi PC Based 17 17th June 2015 02:29 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Raspberry Pi & accessories Nikitas Swap Meet 5 5th July 2013 11:47 AM
