Voltage on audio line. - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 18th April 2015, 03:16 PM   #1
Default Voltage on audio line.
Hello there audio pro and mavin people!
I have this primitive hobby project, where an Arduino micro-controller board communicates with a smartphone, via the phone audio jack. The phone plays these Audio files and the Arduino samples the voltage on the audio line, in order to discern between high voltage, low voltage and no voltage. It's a simple project and it already works OK without any amplification and that is how i want it to stay for that project (without amplification).
But i have a suspicion that it could work even better, if i had a bit more knowledge about the types of sounds that produce various levels of voltage on an audio line. What i am using now is a sound of a siren, that i recorded with such a gain, that it is full of distortion. i think distortion is good for my case since it seems to be decoded by the Arduino as a high voltage signal most of the time, but when i installed a primitive sound editor software on my computer and set the graphic view of the sound file in a certain way, i saw that actually only small portions of that sound file, actually raises the sound magnitude to the maximum possible. My conclusion was that it must be surly possible to create a sound file, that produces even a higher voltage on the audio line.
So my question is, what kind of sound sample would produce the highest voltage on an audio line?
Thanks.
Old 19th April 2015, 12:28 AM   #2
kevinkr's Avatar
The tubes / Valves forum is really not the right place for this thread. Moving to a more appropriate forum.
Edit: Based on the question PC Based seems like a reasonable choice.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 19th April 2015, 05:49 AM   #3
wwenze is offline wwenze  Singapore
Check Arduino datasheet for what it wants for high/low/no(?) voltage levels.
Then check your phone what is the full-scale output level.
The rest can use audacity to make whatever voltage you want.
Help High Line voltage HarryOOOO Tubes / Valves 14 21st July 2012 06:12 AM
What about FETs for Cellular Base Stations in Audio Cascode Voltage Gain Stage (line tiefbassuebertr Solid State 8 23rd August 2009 02:53 AM
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
No Voltage on AC 12v line!! tripathdude Car Audio 4 28th March 2007 07:01 AM
line voltage level metebalci Tubes / Valves 2 1st March 2004 12:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
