PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 9th October 2017, 12:45 AM   #9951
fishoil is offline fishoil  Hong Kong
Hi! Tim,
I am using Moode Audio 3.84. Last week, I setup three windows directory on music folder and after it get updated, the library shows 0 media file. I try to re-install the OS/ update MPD functions. Finally, I found that the library shows 0 media file after the second music folder was updated.
The library was around 26000 music files in three music folders.
Would appreciated if you could advise for any workaround on the issue?
Thanks,
Adrian
Old 9th October 2017, 12:57 AM   #9952
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi @bigbear2003,
Complex subject but the main diff is that basic Graphic EQ's are constant Q (fixed bandwidth) around a set of 10 frequency bands that are one octave apart while basic Parametric EQ's offer variable bandwidth around a set 3 or 4 variable frequency bands.
A basic parametric EQ is generally much more precise than a graphic EQ when adjusting a particular frequency band but its limited to 3 or 4 bands. Also both types of EQ produce the effect where adjustments in one frequency band affect adjacent bands. EQ is an art :-)
There are also many professional hybred EQ's that go way beyond the basics.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 9th October 2017, 06:59 AM   #9953
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by bigbear2003 View Post
What is the difference between Graphic EQ (which I know) & Parametric EQ (which I dont know)? Thx.
Originally Posted by TimCurtis View Post
Hi @bigbear2003,
-Tim
Difference Between a Graphic and a Parametric Equalizer
Old 9th October 2017, 09:47 AM   #9954
jtuncer is offline jtuncer
Hello moOdeaudio users (-:
I already posted on the computeraudiophile.com forum but it actually doesn't seem as active as this one...
My interrogation is : Is there a way to somehow control moOde Player/MPD through ssh or another type of inline commands ?
I'd like to be able to control moOde through a Jeedom domotics server which provides an efficient connexion to SSH enabled devices.
I haven't found any info on this through research but maybe I missed posts in the (996 pages of the) forum or a documentation entry. Or maybe it is simply not possible.
If someone can give me a hint on that, I'd be glad.
Old 9th October 2017, 10:10 AM   #9955
You can issue MPD line commands via ssh.
Chapter 3. Command reference
Old 9th October 2017, 10:14 AM   #9956
Thank you Zootalaws !!! Super news for me (-:
I think I simply didn't know wher to look.
Old 9th October 2017, 10:16 AM   #9957
Old 9th October 2017, 11:21 AM   #9958
sinski is offline sinski
Does moOde player is bit perfect when software volume control and alsa eq is turned off ?
Old 9th October 2017, 06:21 PM   #9959
DRONE7 is offline DRONE7  New Zealand
and for something a bit more 'graphical' you can even ssh in , install and run ncmpcpp
NCurses Music Player Client (Plus Plus) | rybczak.net
Old 9th October 2017, 07:55 PM   #9960
TimCurtis's Avatar
All DSP has to be disabled and the audio device has to accept the sample rate being sent, then "bit-perfect" to the interface of the audio device.
- Volume control
- Resampling
- Volume normalization
- Replaygain
- EQ
- Crossfeed
- Crossfade
-Tim
Enjoy the Music!
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
