PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 13th September 2017, 12:50 PM   #9601
Zootalaws is offline Zootalaws  New Zealand
If there's a Raspbian driver for it, sure.
Are you anticipating shifting a huge amount of data? Because that's the only reason I can see for using something other than the inbuilt Ethernet NIC - unless you're using a Zero, in which case 100BT is probably all the poor little bugger can handle.
And, every time you reimage a system, you will have to ensure the driver is loaded, if t isn't available in the kernel.
Old 13th September 2017, 01:14 PM   #9602
SonofThor is offline SonofThor  United Kingdom
This may not be the correct place for this, but I'll ask anyway... I'm using an RPi 3B, powered with an RPi wall-wart PSU and Allo Kali powered by Ifi iPower and Piano 2.1 DAC. I'm wondering if a linear PSU for the Kali/DAC will provide any noticable improvement in SQ and if so, what should I go for (given that my DIY skills are OK up to point of plugging boards together/getting software running and not soldering? What are you guys using?
Old 13th September 2017, 01:49 PM   #9603
metalrob is offline metalrob
Hi All!
Just wanted to add a line in /boot/config.txt in order to disable Pi3's Bluetooth part of the WIFI/BT implementation. I entered the distro via putty-ssh. When I tried storing the change I unfortunately got a 'permission denied'- message. So I assume, that the 'pi' login instead of 'root' is responsible for that fact. Is there a simple way to succeed in this case?
Thanx, Robert
Old 13th September 2017, 02:27 PM   #9604
TheOldPresbyope is offline TheOldPresbyope  United States
@Zootalaws
@Serverbaboon
It's all I can do to keep from chiming in on the networking discussion to show I have some considerable networking chops of my own at every level in the stack from bare wire/radio to API and have configured and run every networking service at one time or another.
But really, guys, this isn't the point. I'm trying to test moOde 4.0b1 "as if" I know sod all about the technology. A newbie expects to plug it in and listen to the music. If there's a feature offered in the configuration panels, I'm going to punch it to see what happens. I'll grant the need on the part of the user for some basic computer literacy and the ability to find and read "how to's" on the Internet (not to mention Tim's Setup Guide!).
But I do love the tech-head discussion
Kent
Old 13th September 2017, 02:36 PM   #9605
Originally Posted by metalrob View Post
Hi All!
Thanx, Robert
Hi, Robert.
Yes, if you're logged into moodeOS, you'll need to modify files in /boot as superuser (aka root).
e.g.,
Code:
:~ $ sudo nano /boot/config.txt
Kent
Old 13th September 2017, 02:50 PM   #9606
Thanx Kent! That was it;-)
Greetingz, Robert
Old 13th September 2017, 03:06 PM   #9607
Originally Posted by Zootalaws View Post
Further to the above rant, is one of you android users willing to try a change to your router to solve the mDNS issue with Android devices?
It seems that mDNS is supported in the various flavours of Android OS, but they have hard-coded 8.8.8.8 and 8.8.4.4 (google's DNS servers) and ignore any local DNS your router supplies with the DHCP lease.
So, your device is capable of resolving mDNS addresses (.local, .station, etc) if the query actually got to your local DNS server.
You could manually enter your local DNS address on your phone, but that is both a short-term fix and causes problems when you leave your local wifi. A better solution is to redirect requests to 8.8.8.8 and 8.8.4.4 to your local DNS.
If you're willing to try, let me know what make and model of router and I will tell you how to accomplish the hack.
@Zootalaws
The DNS service on my SO's router (from her ISP, Verizon) maps unqualified hostnames into its own domain .fios-router.home so with a few extra finger presses Android is happy. Not as clean as your hack but less likely to frighten the horses.
Kent
Old 13th September 2017, 03:21 PM   #9608
Originally Posted by Serverbaboon View Post
@TheOldPresbyope
Will do some packet captures tonight to make sure but I think part of the issue is how the playback panel PHP code decides whether it calls uplexplorer or not.
The last time I looked if the artist/Title was blank in the MPD current track status then the playback panel classed it as a Radio stream and did not call upexplorer.
Interesting observation but moOde is displaying artist/Title while playing Tidal streams proxied by BubbleUPnP. If currentsong.txt is enabled, I see the same phenomenon I reported for upexplorer, namely with moOde 3.8.4, the coverurl line contains a single URL entry, with moOde 4.0b1, the coverurl line contains a list of two (identical) URLs.
If lists are legit, then an easy fix is to take the first item and ignore the rest.
Checking proxying through Bubble of my Qobuz subscription and two artwork urls are returned because it looks like Bubble publishes two different artwork size options (for Qobuz at least). I wonder if the earlier version only got the first. I will email the upmpdcli developer and ask.
That agrees with my mental conjecture about a UPnP media server possibly returning a collection (list) of artwork URLs.
However I take your point about significant others, my wife refuses to acknowledge any interface, web or otherwise if its not the Sonos client and has demanded a STOP button, a Radio Paradise button and a nice nicer box.
As if this were our only bone of contention
Kent
Old 13th September 2017, 05:48 PM   #9609
jonners is offline jonners  United Kingdom
jonners's Avatar
Some people think the iFi is at least as good as a linear supply there, so you might do better to spend your money on an isolator.
The sound does improve if you supply the DAC and Kali separately, though this entails a mod - described by Greg Stewart in the 'New Dac for RPi' thread. Soldering required though!
Old 13th September 2017, 05:56 PM   #9610
jrocker is offline jrocker
I would suggest you try powering the RPi3 with the iFi power supply and the Kali and Piano DAC with the RPi wall-wart and listen for a change in the sound...
Will be able to advise from there.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
