PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 12th August 2017, 09:34 PM   #8831
yannig is offline yannig  France
Originally Posted by remy1961 View Post
Hi. For those on OSX there is an application that turns any web page to a real mac app. It makes moode audio look even better. There is a free version for everyone to try at Fluid - Turn Your Favorite Web Apps into Real Mac Apps.
Remy
looks like a nice application !
And now, I want to have the same thing to an Android app.
Old 12th August 2017, 09:41 PM   #8832
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by Skip Pack View Post
Installing 3.8 I've hit a snag. I set the I2S to Allo Boss, set and rebooted, then reset the time zone -- all good. I then went to hook up my NAS NFS share and probably mis-entered the path, getting the red report. After several additional tries, I can't get any choice (not just "Sources") on the configure menu to work. A window pops up on the bottom of the browser saying "Waiting for 192.168.120", the correct IP, and a spinner starts on the Moode browser tab. It probably will spin forever. I can kill it with a refresh. The system and audio info reports look right. I can play a radio station. I can also ssh and login with putty. I imagine reimaging is my next step, but I'm curious to know if there are other checks I could perform.
thanks,
Skip
Hi Skip,
Thats odd. Try removing the NAS source and then creating a new one.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 12th August 2017, 09:46 PM   #8833
Skip Pack is online now Skip Pack  United States
Hi Tim,
That's precisely what I was trying to do. I'd created the bad entry, and when, after a reboot, I went to correct/redefine the entry, I got the spinner before the "Sources" menu came up. Like I said, I'll reimage and start afresh later today.
Skip
Old 13th August 2017, 12:39 AM   #8834
TimCurtis's Avatar
Hi Skip,
I'll check into this. Something similar has been reported before but I've not been able to repro it yet.
-Tim
Enjoy the Music!
Old 13th August 2017, 11:24 AM   #8835
SawboStu is offline SawboStu  United Kingdom
Default Feature Request
Hi Tim
Here's a feature request that might chime with absent-minded types like me.
As Moode has moved through releases to 3.8, every upgrade has been smooth apart from my repeated “oh nuts” moment when I realise that yet again I have forgotten to preserve my custom radio stations and playlists. I'm thinking it might be useful if there were a UI switch that gives the option to force Moode to save these items offboard on an attached USB device rather than the SD card. That way they would survive the reimaging process. Nothing complex, maybe just a couple of standard folders in USB root called MyPlaylists and MyRadios.
Anyone else want to +1 this idea.
Great work on Moode Tim.
Stu
Old 13th August 2017, 01:29 PM   #8836
TimCurtis's Avatar
Upcoming moOde 3.8.2 release will contain a nice Latency Level setting for the Advanced-LL (Low Latency) kernel :-)
-Tim
Enjoy the Music!
Old 13th August 2017, 01:39 PM   #8837
dewdrop is offline dewdrop  Singapore
-Tim
This is why MoOde has a huge following! Great job Tim. Can't wait to lay hands on it.
Ed
Old 13th August 2017, 05:08 PM   #8838
Vhond is offline Vhond  Netherlands
Just an FYI that I'm testing a nice tuning param for the Advanced-LL (Low Latency) kernel that will allow one of three Latency Levels to be selected. The levels correspond to the frequency of the kernel timer interrupt, which in turn determines how often the task scheduler does its work and thus determines the overall latency of the system.
-Tim
Sounds good
Old 13th August 2017, 05:12 PM   #8839
burmar is offline burmar  Italy
-Tim
This is a great idea... the conjunction ring between RT and LL? is it?
Marco
Old 13th August 2017, 05:26 PM   #8840
IM35461 is offline IM35461  United Kingdom
Not sure if this is a Chrome thing, UK character set or something else issue.
Anyway, now the file data rate is displayed, for an mp3 one it displays ?/44.1 (see attached).
I also have one mp3 album which all but one track, MoOde seems to ignore the genre just saying Unknown (track 10 behaves okay and updates, all the tracks play okay).
I have changed the genre of all tracks using MediaMonkey (which I use for my 18,000 tracks) but still after an update, those tracks are still unknown (All of my music is on the same nas and I am pretty sure in the earlier release it was not a problem).
Any thoughts, anyone got the same problem?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2017 diyAudio
