PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 18th June 2017, 08:21 PM   #8201
markstwin is offline markstwin
I've taken my zero w to my friend's house to demonstrate the great product but I need to get it on his wireless network
What's the quickest/easiest way to do this?
I don't see the moode AP on my mobile like I did when I originally set it up...
Old 18th June 2017, 11:37 PM   #8202
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi @markstwin,
Which kernel are u using?
In moOde 3.5 - 3.7 the W integrated Wifi is only supported in Std kernel.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 19th June 2017, 12:48 AM   #8203
Zootalaws is offline Zootalaws  New Zealand
You will probably have to use Ethernet, if you already have your home AP set up in moode. Once connected via Ethernet, you can change your wifi settings via the web interface
Before taking it home, wipe the wifi settings and it will revert to moode AP
Old 19th June 2017, 05:40 AM   #8204
Hi gents
This is a zero w with 3.7 so no ethernet
Afraid I can't easily 'take it home', I'm in a different country now
Any other ideas?
Old 19th June 2017, 12:12 PM   #8205
TimCurtis's Avatar
Hi @markstwin,
If you've already set an SSID for home network and you're not at home and can't get Ethernet access at your current location then only option is to burn fresh 3.7 image on an SD card and then the W will boot up in AP mode.
-Tim
Enjoy the Music!
Old 19th June 2017, 12:25 PM   #8206
swizzle is offline swizzle  United States
Hi gents
Any other ideas?
You can try:
1. Temporarily change your friend's wifi to your home router's ssid & password and then edit things to match the original once you get access.
2. If you can read / write the micro sd card's file system then there's probably a config file you can edit but someone else will have to supply those details.
3. Flash another micro sd card with a fresh copy of moode.
Old 19th June 2017, 01:30 PM   #8207
Serverbaboon is offline Serverbaboon  United Kingdom
I have never tried this but..
Can you create a Hotspot on your phone using your home wireless settings and connect back from phone or (tablet).
Old 19th June 2017, 02:23 PM   #8208
pkdick is offline pkdick  France
Hi Tim,
As you are preparing the new Moode 3.8 version, I was wondering if it could be possible to allow the installation of Moode on a USB HDD instead of a SD card: I tried to do so many times (following some tutorials that I found on the web) without success (the first boot was always successful but then it could not start the day after) and reading this thread I think that it is not allowed by your software...
looking forward to reading your comments,
Thank you in advance
Old 19th June 2017, 02:43 PM   #8209
TimCurtis's Avatar
Hi @pkdick,
The last 3.8 build I made was based on Jessie Lite 2017-03-02 release. There is later release 2017-04-10 that indicates in the release notes:
http://downloads.raspberrypi.org/ras...ease_notes.txt
* Use PARTUUID to support USB boot
And this procedure for booting from USB drive.
https://www.raspberrypi.org/document...otmodes/msd.md
Is this what you are looking for?
-Tim
Enjoy the Music!
Old 19th June 2017, 04:30 PM   #8210
ICLlP is offline ICLlP  United Kingdom
I noticed that track 2 of a particular album didn't show in the library. I rescanned the DB and it still didn't show though it is definitely in the scanned album folder. So, I deleted the folder containing the album and rescanned. As expected the whole album was then missing. I copied the album back, from another location and scanned again. The album is back, but again it's without track 2. Any idea as to what's going on?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
