PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 15th June 2017, 02:16 PM   #8171
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by trung224 View Post
Hi Tim,
I have a question about Squeezelite renderer on Moode. I am using Logitech Media Server streaming flac (native, no transcoding) to Moode 3.7. Problem is, Squeezelite renderer cannot output stream at native rate. For example, if I don't choose anything about bit depth in Configure squeelite>ALSA params, the output stream is always in 32 bit.
If I choose 24bit, the output stream is 24bit regardless my input stream (16bit FLAC or 24bit FLAC) is.
So I want to ask if you could add imprementation about native output stream on squeezelite renderer.
Best regards,
trung224
I ran a quick test and am also getting 32 bit when playing 16/44.1 FLAC. Below is output log debug showing "format: any" setting :: and "using format: S32_LE".
I'll have to investigate whether Squeezelite actually supports native bit depth pass-thru or whether it always zero-pads to 24 or 32 bits.
/usr/local/bin/squeezelite-armv7l -n RP3 -o hw:0,0 -a 80:4::1 -b 40000:100000 -p 45 -c flac,pcm,mp3,ogg,aac,alac,dsd -W -D 500 -R E -f /home/pi/sl.txt -d output=debug
[09:30:39.500691] output_init_alsa:873 init output
[09:30:39.501690] output_init_alsa:902 requested alsa_buffer: 80 alsa_period: 4 format: any mmap: 1
[09:30:39.502103] output_init_common:347 outputbuf size: 102400000
[09:30:39.502519] output_init_common:371 idle timeout: 0
[09:30:39.512732] output_init_common:411 supported rates: 192000 176400 96000 88200 48000 44100 32000 16000 11025 8000
[09:30:39.738899] output_init_alsa:928 memory locked
[09:30:39.743085] output_thread:621 open output device: hw:0,0
[09:30:39.743116] output_init_alsa:951 set output sched fifo rt: 45
[09:30:39.743587] alsa_open:338 opening device at: 44100
[09:30:39.744505] alsa_open:389 opened device hw:0,0 using format: S32_LE sample rate: 44100 mmap: 1
[09:30:39.744679] alsa_open:468 buffer: 80 period: 4 -> buffer size: 3528 period size: 882
[09:30:39.933986] output_flush:424 flush output buffer
[09:30:39.942729] output_flush:424 flush output buffer
[09:30:39.943174] set_volume:229 setting internal gain left: 0 right: 0
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 15th June 2017, 04:34 PM   #8172
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Originally Posted by TimCurtis View Post
Hi Rafa,
If DAC supports DoP protocol then turn this on in MPD config.
-Tim
Thanks for the quick answer. Success! ... well sort of!
Without the DoP activated, MPD defaults to PCM decoding. Direct DSD is not supported. With DoP, it works with my DAC with DSD64 and DSD128. DSD256 (at least the 2 bit samples I found) don't work and they get back to the DSD -> PCM pipeline, but at that point the RPi3 processor goes all the way up to 100% CPU ussage and there is more silence than there is music.
So, bottom line, DSD throuhg DoP good up to 128 (dsd 5.6) with the Rpi3 and my DAC, but I believe this is a limitation of MPD and DoP (perhaps the 24bit / 352.8 bandwith cannot carry more?) and then the transcoding issue is a limitation of the Rpi3 processor.
So, all in all, I can play DSD files (recognized as DSD files by the DAC) correctly, just need to be sure to stay on 64 and 128 for the time being.
Thanks!
Rafa.
Old 15th June 2017, 07:19 PM   #8173
TimCurtis's Avatar
Hi Rafa,
AFAIK to do DSD256 using DoP requires a 24 bit 705.6 kHz output stream. Do you know if the USB receiver in your DAC accepts this rate?
Not surprised that on-the-fly conversion of DSD256 to PCM pegs the CPU.
As I recall, native DSD bitstream support requires ALSA version >= 1.0.29. Send me an email and I'll provide a download link to moOde 3.8 test build that I'm working on. This build has new OS, kernel, MPD, ALSA 1.1.3, etc.
-Tim
Enjoy the Music!
Old 15th June 2017, 09:22 PM   #8174
TimCurtis's Avatar
Just a brief update on upcomming moOde audio player release 3.8.
This release is running on new moodeOS 3.0 platform which is based on the latest releases of Raspbian Jessie Lite, Linux 4.9.y kernel, MPD 0.20.x compiled with FFMPEG-only codecs and ALSA and SoX releases from Raspbian Stretch :-)
Release 3.8 also includes various UI improvements and support for some excellent new I2S audio devices including Allo DigiOne and MiniBoss, Denafrips Pontus R2R DAC and DIAL-DAC.
No timeframe yet for the release and due to the new OS platform it will be image-only.
-Tim
Enjoy the Music!
Old 16th June 2017, 12:17 AM   #8175
remy1961 is offline remy1961  Canada
Does your system behave normally without the power switch device connected?
By "inaccessible" do you mean that its not possible to get an ssh session?
-Tim
I tried again today, this is what i discovered: once you install the pi supply switch script, you need to connect the pi supply switch device in order for you to use moode audio. The mistake i was making was after installing the script, i would run moode audio without actually connecting the device because i was testing different configurations. Now i know that once the script is installed i should not run moode audio if the device is not connected. Every thing is good now. Thanks for your assistance, it's actually your question that sent me test every thing again.
Old 16th June 2017, 05:04 AM   #8176
TomWoB is offline TomWoB  Switzerland
Hi Tim,
quick comment to upcoming release 3.8:
If there is a new image necessary, I think it's better to use a new major Version: 4.0
Minor versions: update is possible
Major versions: new image is necessary
Tom
Old 16th June 2017, 11:08 AM   #8177
FizzyTea is offline FizzyTea
Firstly, Tim, great work, I really love moOde. I'm using v3.1 (advanced kernel) on a rpi3 & currently tinkering with v3.7 (std kernel) on a rpi2. Each have a Pifi Dac + 2.0, the chinese hifiberry clone,.
I have had no success installing either of the two advanced kernels on v3.7 on rpi2 (rev1.1).
I have attempted to install both type, and block have led to reflashing my sd card.
After install and reboot on the playback panel it is blank save for upper "playback cirle" and the skip, play/pause, skip bar beneath it, No vol, no playlist, no moode logo or other details. The library panel says everything is undefined, and the browse panel is completely blank. The system is sluggish and configure panel is unresponsive and often hangs. Interesting I discovered mpd was not running and when I started via command line it complains it has no config file. It starts if point it towards the config but on reboot it i not running. Reinstating the standard kernel has no effect, the system remains dysfunctional. I would like to use advanced kernels if possible. Has anybody reported similar occurrences?
Separately, I have had good success adding ir remote using the dac's built-in receiver, lirc and irexec. I have mapped my most commonly used controls, can jump to set volumes and if I press number 6, BBC 6 Music leaps onto the top of my playlist and starts playing. A wonderful thing about great software like moOde is they encourage curious amateurs to have a go at some scripting, providing a good way to learn. Since adding the second player I decided I need a script to fetch and load the playlist from the other player and obviously I want it work with my remote control. Good news is my bash script seems to work well from the command line. It however does not work with the remote control. I believe the problem is I need to use sudo to mv the playlist into /var/lib/mpd/playlists and I think irexec is not able/allowed to gain root privileges. irexec runs under user pi, with the lirrc file in the /home/pi folder. I also have my playlist transfer script in /home/pi. I have tried some ideas like the button running sudo myscript.sh but thus far nothing has worked. Perhaps somebody has experience on irexec and sudo in scripts? I will include my script but be kind, I am learning!
As regards moOde itself I do have a feature request. I would really find very very useful an "ADD NEXT" option on songs and folders. This would improve my usage vastly. However as it is present on volumio and rune I wonder if maybe there is not a technical reason it is absent from moOde? Anyway I think it would be valuable addition which would improve my user experience greatly.
Thanks for all the great work though!
Code:
#!/bin/bash
# Script to transfer playlist of other moOde player to current player #
if [ "nc -z moode.local 22 &> /dev/null" ];
then
        ssh pi@moode.local 'if [ -e /var/lib/mpd/playlists/moodelist.m3u ]; then mpc rm moodelist; fi;
                                mpc save moodelist; cp /var/lib/mpd/playlists/moodelist.m3u /home/pi;';
        scp pi@moode.local:/home/pi/moodelist.m3u /home/pi &> /dev/null;
        sudo mv moodelist.m3u /var/lib/mpd/playlists && mpc load moodelist &> /dev/null;
        exit 0;
else
        exit 1;
fi
Old 16th June 2017, 11:22 AM   #8178
TimCurtis's Avatar
Hi Tim,
Best regards,
trung224
-Tim
From what I understand after investigating, when bit depth format is not specified Squeezelite chooses an output bit depth that it thinks is best for the audio device. If this bit depth is > than input bit depth then only zero-padding occurs and the original bits are not altered, i.e., still bit-perfect.
-Tim
Enjoy the Music!
Old 16th June 2017, 11:41 AM   #8179
TimCurtis's Avatar
Originally Posted by TomWoB View Post
Hi Tim,
Tom
Hi Tom,
I try not to put too much intelligence in the release version numbering other than minor version updates are FREE, major version updates are $10 maybe two of these per year, and sometimes version numbers are skipped i.e., could go from 3.8 -> 4.0.
-Tim
Enjoy the Music!
Old 16th June 2017, 11:56 AM   #8180
terry22 is offline terry22
Hi Tim,
Do you plan to add driver for st4000 in future versions?
thank you
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
