Moode Audio Player for Raspberry Pi
Thanks!
So far looking solid as a rock 🙂
My 6 Pi's are on 7/24 and never a need to power cycle.
What are the symptoms that result in having to power cycle?
The DAC being off, i. e. the power led is off. One has a HifiBerry DAC+, the other a HifiBerry Digi +. I noticed yesterday that the Digi + doesn't happen all the time. I was able to use it without power cycling. That was the first time in a week. The DAC+ is in my bathroom and I've been power cycling it every morning.
Otherwise I like v 4.0. The changes to the UI are useful and the build script works very well.
Just installed v 4.0 on 2 devices, both r pi 3. I've noticed that I have to power cycle the r pi when it's been inactive overnight. Is this working as designed? I'm used to leaving the r pi powered on all the time and not having to reboot. It's not a huge deal but it's a surprise. It might be better for the hardware in the long run.
@hudsonwoodbridge
I have a first-generation HiFiBerry DAC+ Pro on an RPi2B which is power-cycled only when I try a new release of moOde, otherwise on 24/7. Hasn't ever been a problem. (Listening to it now on moODe 4.0: Cannonball Adderley jamming with "Jay Jay" Johnson).
I also has a HiFiBerry DAC+ which sometimes resides on an RPi3B but is often off as I test various things. It hasn't logged the same amount of on-time but it hasn't given me any problem like you describe.
Are you confident of your power chain?
Kent
Thanks!
Lovin' it, Tim.
A minor nit: the Image Builder knows what release of moOde is being built (it's embedded in the rel-stretch-rxx.zip file name in the mosbuild.properties file which is downloaded by mosbuild.sh).
Could the builder echo the release tag to the mosbuild.log (and possibly to the mosbrief output as well) so we know up front what it's working on for the next hour or 3?
Kent
Tim, you said, ”Symptom suggests an issue external to moOde software. Post in the diyAudio moOde thread with more details including contents of System info and I'll have a look”, in response to my comment about webUI being very slow to load. What do I need to post here?
Unable to start players
Hi, Until now I have always used moode with squeezelite. I wanted to give other players a go. I have configured my NAS and scanned the music library. Everytime I click on "Players", it redirects me to 127.0.0.1, which fails to display (unable to connect). So I presume it can't play, because there is no default player selected. Any suggestions on how could I make it play through MPD from a NAS stored library? Thank you for your good work, btw!
Just use Browse or Library to add some songs to the Playlist and then press the PLAY button.
The "Players >>" feature simply connects to the UI of other moOde players on your network. It has bug that causes it to display "self" which ends up being 127.0.0.1 :-0 This is fixed in 4.1
Output of the System info utility. Menu, Configure, System then Menu, System info
Browser (IE, Firefox, Safari, Chrome)
Type of client (Android, IOS)
UI response has not come up as an issue with moOde 4, in fact just the opposite, its more responsive than any prior moOde release, thus your particular issue would suggest something external to moOde software for example network issue or possibly a client/Browser issue, maybe even a broken build.
S Y S T E M P A R A M E T E R S Date and time = 2018-02-28 20:53:52 System uptime = up 23 hours, 52 minutes Timezone = Europe/Berlin moOde = Release 4.0 2018-01-26 Host name = iqaudiodac ETH0 IP = unassigned ETH0 MAC = b8:27:eb:95:68:ff WLAN0 IP = 192.168.0.158 WLAN0 MAC = b8:27:eb:c0:3d:aa HDWR REV = Pi-3B 1GB v1.2 SoC = BCM2835 CORES = 4 ARCH = armv7l KERNEL = 4.9.79-v7+ KTIMER FREQ = 100 Hz USB BOOT = not enabled Warranty = OK ROOT size = 15G ROOT used = 15% ROOT avail = 12G FS expand = expanded MEM free = 195 MB MEM used = 97 MB Temperature = 49.9°C CPU GOV = ondemand MPD SCHDPOL = TS P3-WIFI = On P3-BT = Off HDMI = Off ETH0 CHECK = On MAX USB CUR = Off UAC2 FIX = Off SSH server = On LED0 = on LED1 = on C O R E S E R V E R S PHP-FPM = 7.0.27 NGINX = 1.10.3 SQLite = 3.16.2 Bluetooth = 5.43 C P U L O A D CPU %usr %sys %idle all 0.00 0.00 100.00 0 0.00 0.00 100.00 1 0.00 0.00 100.00 2 0.00 0.00 100.00 3 0.00 0.00 100.00 P R O C E S S L O A D PRI RTPRIO COMMAND %MEM PSR %CPU 19 - sysinfo.sh 0.2 2 2.0 19 - sudo 0.3 0 0.6 90 50 irq/92-mmc1 0.0 0 0.5 19 - worker.php 1.0 0 0.3 39 - kworker/0:1H 0.0 0 0.3 39 - kworker/2:1H 0.0 2 0.1 29 - mpd 3.4 1 0.1 19 - systemd 0.4 0 0.0 19 - kthreadd 0.0 3 0.0 C L O C K F R E Q U E N C I E S arm = 600 MHz pwm = 0 MHz core = 250 MHz emmc = 249 MHz h264 = 250 MHz pixel = 0 MHz isp = 250 MHz vec = 0 MHz v3d = 250 MHz hdmi = 0 MHz uart = 47 MHz dpi = 0 MHz SD card = 50 MHz S Y S T E M V O L T A G E S core = 1.2500V sdram controller = 1.2000V sdram I/O = 1.2000V sdram chip = 1.2250V U I C U S T O M I Z A T I O N S Theme = Standard Accent color = Emerald Alpha blend = 0.85 Adaptive background = No Background image = Yes Playback history = No Extra metadata = Yes Library = Use Artist A U D I O P A R A M E T E R S Audio device = IQaudIO Pi-DAC+ Interface = I2S Hdwr volume = 100 Mixer name = Digital Output stream = Closed ALSA version = 1.1.3-5+rpi3 SoX version = 0.1.2-2 Volume knob = 17 Volume mute = Off Volume limit = 20 Bluetooth controller = Off Airplay receiver = Off Squeezelite = Off UPnP renderer = Off DLNA server = Off Rotary encoder = Off Encoder params = 100 2 3 4 5 Crossfeed = Off Parametric EQ = Off Graphic EQ = Midrange Suppress Auto-shuffle = Off Autoplay = Off MPD crossfade = Off M P D S E T T I N G S Version = 0.20.12 Volume control = hardware ALSA device = hw:0 SoX resampling = disabled SoX quality = very high SoX multithreading = off Audio buffer (kb) = 4096 Buffer before play = 10% Output buffer size (kb) = 81920 Volume normalization = no DSD over PCM (DoP) = no Replay gain = off A I R P L A Y S E T T I N G S Version = 3.1.7 Friendly name = Moode Airplay Metadata display = Off ALSA device = hw:0 Volume mixer = auto Resume MPD after = No Output bit depth = S16 Output sample rate = 44100 Session interruption = no Session timeout (ms) = 120 Audio buffer (secs) = 0.0 S Q U E E Z E L I T E S E T T I N G S Version = 1.8.7-1020 "DSD/SRC enabled" Friendly name = IQAudIODAC ALSA device = hw:0 ALSA params = 80:4::1 Output buffers = 40000:100000 Task priority = 45 Codec list = flac,pcm,mp3,ogg,aac,wma,alac,dsd,mad,mpg Other options = -W -D 500 -R E M O O D E L O G 20180226 235717 worker: - Start 20180226 235717 worker: Successfully daemonized 20180226 235717 worker: - Init 20180226 235718 worker: Session loaded 20180226 235718 worker: Debug logging (off) 20180226 235720 worker: Host (iqaudiodac) 20180226 235720 worker: Hdwr (Pi-3B 1GB v1.2) 20180226 235720 worker: Arch (armv7l) 20180226 235720 worker: Kver (4.9.79-v7+) 20180226 235720 worker: Ktyp (Standard) 20180226 235720 worker: Gov (ondemand) 20180226 235720 worker: Rel (Moode 4.0 2018-01-26) 20180226 235720 worker: Upd (None) 20180226 235720 worker: MPD (0.20.12) 20180226 235720 worker: USB boot not enabled yet 20180226 235720 worker: File system expanded 20180226 235720 worker: HDMI port off 20180226 235720 worker: File check ok 20180226 235720 worker: - Network 20180226 235720 worker: eth0 exists 20180226 235720 worker: eth0 wait 0 for IP address 20180226 235723 worker: eth0 wait 1 for IP address 20180226 235727 worker: eth0 wait 2 for IP address 20180226 235730 worker: eth0 wait 3 for IP address 20180227 210147 worker: eth0 wait 4 for IP address 20180227 210150 worker: eth0 wait 5 for IP address 20180227 210153 worker: eth0 wait 6 for IP address 20180227 210156 worker: eth0 wait 7 for IP address 20180227 210159 worker: eth0 wait 8 for IP address 20180227 210209 worker: eth0 wait 9 for IP address 20180227 210212 worker: eth0 address not assigned 20180227 210212 worker: wlan0 exists 20180227 210212 worker: wlan0 trying SSID (Obi Wlan Kenobi) 20180227 210212 worker: wlan0 (192.168.0.158) 20180227 210212 worker: - Audio 20180227 210213 worker: ALSA outputs unmuted 20180227 210213 worker: Audio out (I2S audio device) 20180227 210213 worker: Audio dev (IQaudIO Pi-DAC+) 20180227 210213 worker: ALSA mixer name (Digital) 20180227 210213 worker: MPD volume control (software) 20180227 210214 worker: Hdwr volume controller exists 20180227 210214 worker: Chip options (Burr Brown PCM5122) 20180227 210214 worker: - Services 20180227 210216 worker: MPD started 20180227 210216 worker: MPD scheduler policy (time-share) 20180227 210216 worker: MPD output 1 ALSA default (off) 20180227 210216 worker: MPD output 2 ALSA crossfeed (off) 20180227 210216 worker: MPD output 3 ALSA parametric eq (off) 20180227 210216 worker: MPD output 4 ALSA graphic eq (on) 20180227 210216 worker: MPD crossfade (off) 20180227 210216 worker: Squeezelite renderer started 20180227 210216 worker: Shellinabox SSH server started 20180227 210216 worker: - Last 20180227 210216 worker: USB sources (none attached) 20180227 210216 worker: NAS sources (mountall initiated) 20180227 210217 worker: Volume level (3) restored 20180227 210217 worker: Maintenance interval (21600) 20180227 210217 worker: Watchdog started 20180227 210217 worker: Ready 20180227 210256 worker: Job updmpddb 20180228 030350 worker: Maintenance completed 20180228 090524 worker: Maintenance completed 20180228 150656 worker: Maintenance completed 20180228 201541 worker: Job slsvc 20180228 201748 worker: Job mpdcfg 20180228 201750 watchdog: MPD restart (check syslog for MPD errors) 20180228 201938 worker: Job alsavolume 20180228 202029 worker: Job slsvc 20180228 203113 worker: Job slsvc 20180228 203438 worker: Job setbgimage
