PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 10th September 2015, 05:43 AM   #601
challenge is offline challenge  Italy
Yeah a remote is essential IMHO, it made the experience so much better.
I used the remote from my old A/V receiver, so it has a lot of buttons (fm tuner, cd,dvd aux etc).
I also mapped the tuner numeric keys to stations like this:
Code:
begin
    prog = irexec
    button = KEY_8
    config = mpc clear; mpc add http://bbcmedia.ic.llnwd.net/stream/bbcmedia_6music_mf_p; mpc play
    repeat = 0
end
so I just hit the number and it loads the station, just like the old hi-fi I had.
User experience with the remote is very similar as before but sound quality and features are way improved.
To have lirc running I really hadn't a lot to do.
- Wire the TSOP, note the gpio pin.
- add this to your boot/config.txt
Code:
dtoverlay=lirc-rpi,gpio_in_pin=25
change 25 to your gpio number. Note it's gpio number, not pin number.
Then it's just a matter of following the usual instructions of
- installing lirc
- using irrecord to record the remote and generate a config file
- copy that config file to /etc/lirc/lircd.conf.
- create a /etc/lirc/lircrc which will store the irexec mpc binds
- sudo /etc/init.d/lirc start
you then can use irw command to see if your binds are getting received
I'm pretty sure I've seen quite a few detailed guides on volumio forum, showing all the commands.
If you don't add that line to boot/config.txt it will never work.
the only problem is that on the same moode partition I also have kodi running on another remote and other tools. Add all that custom configuration and the moode upgrades are becoming a little troublesome to update by hand.
Is there a plan to make it upgrade in a way we don't lose all the tweaked things and files?
Maybe starting with a stripped raspbian and then adding moode as a combination of packages from a repo and git cloning?
This way one would just upgrade the packages without starting from scratch every time?
otherwise I have to find a way to apply all my modded files and conf automatically every time I update... diff and patch maybe?
Old 10th September 2015, 08:26 AM   #602
DRONE7 is offline DRONE7  New Zealand
Thanks challenge ! I will give it a try
That station mapping is just what I am looking for ! Gold !
Old 10th September 2015, 10:45 AM   #603
hoze99 is offline hoze99  New Zealand
Originally Posted by challenge View Post
About the knob.sh script and remotes (lirc)...
I remember the UI updated in realtime time ago, now I've just read it's handled by the knob.sh script.
Well.. long story short: the webUI volume wasn't updating with remote presses... it adjusted the alsa volume but not the ui. (because I was using mpc commands)
Also using alsa commands or using alsamixer doesn't update the webUI. But I don't care about that now.
Premise: I'm not a coder nor programmer, first time with bash done with 10 mins of googling and some trial and error, so don't trust this if you don't know what you're doing.
Your raspberry, your ears or your window glasses could explode
I wanted that hitting volume buttons in the remote would update the webUI too in realtime, not only the alsa volume.
I tried the usual way (binding mpc or alsa commands) but the webUi wasn't updating in real time... a manual refresh was needed.
So I had to add a bit of code to knob.sh.
This allows me to bind easy commands in lircrc AND the knob updates in realtime.
The original script worked by feeding it a volume number to set e.g.: "./knob.sh 35"
I modded it to have also "./knob.sh volup" (or voldown / mute).
To give you an idea (using steps of 3 in this example):
Code:
if [ "$1" = "volup" ]; then
        actual=$(sed -n -e 's/^.*volume_knob_setting: //p' /var/www/tcmods.conf)
        newvol=$(echo $((actual+3)))
        # update knob setting
        sed -i '/volume_knob_setting:/c\volume_knob_setting: '$newvol /var/www/tcmods.conf
        # update ALSA volume
        if [ "$VOLTYPE" = "volume_curve_logarithmic: Yes" ]; then
                amixer set Digital -M $newvol% > /dev/null
        else
                amixer set Digital $newvol% > /dev/null
        fi
        exit
fi
if [ "$1" = "voldown" ]; then
        newvol=$(echo $((actual-3)))
        else
        fi
        exit
fi
if [ "$1" = "mute" ]; then
        sed -i '/volume_knob_setting:/c\volume_knob_setting: '0 /var/www/tcmods.conf
                amixer set Digital -M 0% > /dev/null
        else
                amixer set Digital 0% > /dev/null
        fi
        exit
fi
e.g. in lircrc now I just use the new commands:
Code:
begin
    prog = irexec
    button = KEY_VOLUMEUP
    config = /var/www/knob.sh volup
    repeat = 4
end
begin
    prog = irexec
    button = KEY_VOLUMEDOWN
    config = /var/www/knob.sh voldown
    repeat = 4
end
begin
    prog = irexec
    button = KEY_MUTE
    config = /var/www/knob.sh mute
    repeat = 4
end
It works. I'll have to fix the mute to effectively mute and unmute instead of setting the volume to 0, but I was in a hurry and tired when I did this.
Now the problem is...
Is this the best way to do it?
Or it's already implemented (to update the volume knob in realtime when using IR remotes) and I didn't notice it?
setup is raspy B+, IQaudio pidac+, moode r2.2, set to hw audio etc.
PS: also having fun with text to speech, hit a button on remote and a sweet lady voice tells me which station I'm listening to, or the song/album/artist or the volume level (dirty fix until I get a LCD )
Can I suggest a slight tweak to the knob.sh modifications to allow support for different mixer types:
In the volup and voldown code blocks, instead of:
Code:
else
fi
This should instead be:
Code:
                amixer set $MIXERNAME -M $newvol% > /dev/null
else
                amixer set $MIXERNAME $newvol% > /dev/null
fi
Cheers
Old 10th September 2015, 12:30 PM   #604
yjo is offline yjo  Japan
Thank you, Tim, for implementing knob.sh.
I installed lirc on Moode 2.3 and the volume control works well.
I wrote short scripts vol5up.sh and vol5dn.sh, and irexec calls these scripts for volume up/down.
vol5up.sh
Code:
#!/bin/sh
level=`mpc volume | awk -F":" '{print substr($2, 1, index($2, "%")-1)+5}'`
if [ $level -gt 100 ] ; then
  level=100
fi
mpc volume $level > /dev/null
/var/www/knob.sh $level > /dev/null
exit 0
vol5dn.sh
Code:
#!/bin/sh
level=`mpc volume | awk -F":" '{print substr($2, 1, index($2, "%")-1)-5}'`
if [ $level -lt 0 ] ; then
  level=0
fi
exit 0
See here.
yjo
Old 11th September 2015, 01:58 AM   #605
Hi Tim.. where is the playback history file located..? am I able to copy the history for later lookup or is that only available from a running MoOde ?
Old 11th September 2015, 02:35 AM   #606
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
vol5up.sh
Code:
#!/bin/sh
  level=100
fi
exit 0
vol5dn.sh
Code:
#!/bin/sh
  level=0
fi
exit 0
See here.
yjo
I remember that u had originally proposed an interface to the volume knob somewhere back in one of the late 1.x releases as part of your IR project so thank you for the nice idea :-)
I see u are using "mpc volume" calls so u must be using MPD Software volume control correct?
Also, thinking a bit, since mute state is similar to volume level in that both are decoupled from MPD in Moode, I should be able to add a mute interface to knob.sh.
Tim
Old 11th September 2015, 02:43 AM   #607
TimCurtis's Avatar
The playback history log path is:
/var/www/playhistory.log
it can be copied off, renamed to .html and opened in a browser. Its not pretty looking but should be functional.
Tim
Old 11th September 2015, 03:51 AM   #608
Tim,
Thank you again for implementing my proposal :-)
Right, I'm using a USB-DAC, and I didn't confirm whether it works with hardware volume control or not.
Yes, but I scarcely use mute function, and the priority of this issue is relatively low to me :-)
yjo
Old 11th September 2015, 06:53 AM   #609
shanghai2004 is offline shanghai2004  Taiwan
Default USB audio glitch while browsing library on NAS
When I play a file to an USB device (nothing heavy 44.1k/16) and I browse a library which is mostly located on a NAS, every time I click an album, the system tries to get the artwork thumbnail. During that process, there is a short but very noticeable audio glitch, which lasts longer if the system cannot find any artwork for that album.
It doesn't matter if the file that is actually playing is from USB, SDCARD or NAS. The glitch is with a Raspberry B+ and with the Raspberry 2B.
As loading the library (going to the lib page) doesn't cause any glitch, possible the CPU priority of the thumbnail reading process was set a bit too high?
I use UAC2 device with USB audio fix present. Issue is both on XMOS and CM6631A devices.
Anything I can try to help isolate this?
Old 11th September 2015, 09:24 AM   #610
f3rn4nd0d is offline f3rn4nd0d
Hi folks
I just got a Sense Hat and I was planning to use the lcd display to scroll the name of the song and artist (using a USB DAC, more precisely a FiiO E17). Could anybody give me some hints on how to get in python the name of the song and artist from MPD?
Another thing that I was considering was to also use the 8X8 led matrix to create a low res art image of the album art just for fun, but I guess that would be even more complicated and I don't know if feasible at all.
And the last thing I was thinking to do, if I have some time, is to use the Sense Hat Joystick to control the reproduction.
BR / Fernando
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
