Moode Audio Player for Raspberry Pi - Page 600 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 12th January 2017, 03:02 AM   #5991
RafaPolit's Avatar
Originally Posted by TimCurtis View Post
SoX multithreading working in Moode 3.2 :-)
-Tim
Great news!!!!
Old 12th January 2017, 03:24 PM   #5992
Jerms is offline Jerms  United Kingdom
Originally Posted by jonwhitear View Post
Does anyone know if a can stream via Bluetooth to Moode? I'm thinking of an Amazon Echo Dot, which can only connect via Aux or Bluetooth. I'd like to stream Spotify from the Echo Dot via my Moode player through my DAC.
I think the answer is "not easily". Though if someone tells me I'm wrong and that it is easy, well, that might be a pleasant surprise.
AIUI Linux bluetooth audio requires Pulseaudio (or similar?!?). This was not the case in the past when it interfaced to ALSA.
It may be possible to do it, though it would require some fancy dancing to get Pulseaudio to appear as an input to MPD/MoOde.
Old 13th January 2017, 12:11 AM   #5993
Jempie is offline Jempie  Indonesia
Reboot and then post output from the cmd below and I'll investigate.
cat /var/log/moode.log
-Tim
Originally Posted by Jempie View Post
sorry i'm an newbie how can i do this
thx
can anybody please help me with this im totally new with this
thx
Old 13th January 2017, 01:24 AM   #5994
rongon is offline rongon  United States
rongon's Avatar
-Tim
thx
I think Tim's asking you to SSH (remote connect) into your Raspberry Pi and run a program from the command line, using the command he gave you. You may need to take a screenshot (Alt+PrtScr in Windows) showing the text the program outputs.
If you don't have it set up already, connect your Pi to your network (probably best to use Ethernet connection). Download and install a program named PuTTy on your Windows PC.
Download PuTTY - a free SSH and telnet client for Windows
Run Putty, username = pi, password = raspberry. I think you need to put the phrase "sudo" before each command, but I'm not sure of that (being that I'm a complete newbie too).
I hope that helps get you started.
Old 13th January 2017, 01:26 AM   #5995
-Tim
thx
Find friend who understand
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 13th January 2017, 12:19 PM   #5996
barryso is offline barryso  United States
Send a message via AIM to barryso Send a message via MSN to barryso Send a message via Yahoo to barryso
Default Putty/SSH
Here's a tutorial on using putty. If this one doesn't help there are videos on Youtube that will show you how it works. Just do a search on "putty howto" or "ssh howto".
The instructions look intimidating but it's really a pretty simple process. After you do it once or twice it'll become second nature to you.
https://mediatemple.net/community/pr...-ssh-in-putty-
Old 13th January 2017, 06:04 PM   #5997
Hi, can anyone tell me of MoodeAudio has built-in support for the HiFiBerry DAC+ Pro on-board clocks? Thanks!
Old 13th January 2017, 07:31 PM   #5998
MikeyFresh's Avatar
I'm not sure exactly what you mean by "support for the on-board clocks".
I have a HiFiBerry DAC+ Pro working with Moode, and the default state that HAT board works in is Master mode, whereby the RPi is slaved to the DAC+ Pro's on-board clocks rather than vice versa.
I have seen references to various hacks that can allow the HB DAC+ Pro to work in slave mode, for instance with a Kali re-clocker or similar, but it takes some doing.
In all other cases, the HB DAC+ Pro works in Master clock mode with an RPi as slave, and yes Moode is compatible/has the I2S configuration for it.
Old 13th January 2017, 09:06 PM   #5999
Thanks for the reply. My HB DAC+ Pro hasn't arrived yet but I'm using the 3.5mm output on my Pi2 right now with Volumio. The webif is pretty glitchy so I think I'll Moode on there. It looks like Moode is more actively developed than any of the other options at the moment so I'm glad I found this.
Why would one want the DAC clocks to be slave to the Pi? It seems to me that if the DAC clocks are the ones designed for audio processing then you'd want them to be the master on a box that was dedicated to playing music.
Old 13th January 2017, 09:18 PM   #6000
ultrafi is offline ultrafi  United States
The short answer is "yes".
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright 1999-2017 diyAudio
