PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 12th April 2015, 12:08 AM   #41
Skip Pack is offline Skip Pack  United States
Originally Posted by tppc View Post
In lower right of Library panel, are there any totals (numbers) for tracks, hours, minutes?TC
It says 0 tracks and nothing more.
Skip
Old 12th April 2015, 12:31 AM   #42
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi Skip,
The following may provide a clue. From a terminal session, connect to MPD and drill into its database.
telnet moode 6600
lsinfo "NAS/...." where ... is the directory path to an album directory. The double quotes are necessary.
Ex: lsinfo "NAS/Music/George Benson/Giblet Gravy" produces the following list for one of my albums:
file: NAS/Music/George Benson/Giblet Gravy/01 Along Comes Mary.m4a
Last-Modified: 2015-04-11T01:43:37Z
Time: 182
Artist: George Benson
Album: Giblet Gravy
Title: Along Comes Mary
Track: 1/12
Genre: Jazz
Date: 1968
Composer: Tandyn Almer
Disc: 1/1
AlbumArtist: George Benson
file: NAS/Music/George Benson/Giblet Gravy/02 Sunny.m4a
Last-Modified: 2015-04-11T01:43:39Z
Time: 176
Album: Giblet Gravy
Title: Sunny
Track: 2/12
Genre: Jazz
Date: 1968
Composer: Bobby Hebb
Disc: 1/1
file: NAS/Music/George Benson/Giblet Gravy/03 What's New_.m4a
Last-Modified: 2015-04-11T01:43:42Z
Time: 333
Album: Giblet Gravy
Title: What's New?
Track: 3/12
Genre: Jazz
Date: 1968
Composer: Robert Haggart/Johnny Burke
Disc: 1/1
Old 12th April 2015, 02:16 AM   #43
Tim,
I couldn't get a clean telnet session going diectly via Putty. It would kill the connection when I entered the lsinfo command. I then logged in via SSH using Putty and manually entered the telnet session inside that login. I got the return line:
OK MPD 0.19.0
and then carefully entered:
lsinfo "NAS/Music/Oflac/Albert Collins/Frostbite"
and got:
ACK [50@0] {lsinfo} not found
I don't know if that's meaningful or just an indication that my telnet session is not quite right. I'll try it tomorrow from a linux session where I bet the low-level stuff like telnet is cleaner than from Windows.
Skip
Old 12th April 2015, 02:26 PM   #44
TimCurtis's Avatar
Originally Posted by Skip Pack View Post
Tim,
OK MPD 0.19.0
and got:
Skip
Hi Skip,
When ssh root@moode, try telnet localhost 6600 then enter the MPD commands below to help troubleshoot the "Blank Library Panel" issue. Here is link to MPD command reference:
Chapter*3.*Command reference
stats
It will print total #artists, albums and songs in the database.
also you can try drilling in with multiple lsinfo commands. The path has to be double quoted if it contains spaces. Ex:
lsinfo
lsinfo NAS
lsinfo NAS/Music
lsinfo NAS/Music/Oflac
lsinfo "NAS/Music/Oflac/Albert Collins"
TC
Old 12th April 2015, 02:45 PM   #45
TimCurtis's Avatar
Here's a brief update on release 1.8 (late April) There may be a Test Release #2 before the final release.
The attached screen shots show a prototype of the new Playback panel layout with integrated playlist and unified control bar, new System config page with comprehensive name change and timezone select features and a streamlined Sources page.
Enjoy!
See release notes below for details.
tcmods.org
MoodeAudio Twitter Feed
TC
1.8 Release 2015-04-DD
New features
- NEW: Playback panel with integrated playlist
- NEW: Change Player and network service names
- NEW: Select local timezone
- NEW: Choose Theme color from Customize popup
Media
- NEW: Czech Radio Classical (FLAC)
- NEW: EuropaRadioJazz - 883 SmoothJazz
- NEW: EuropaRadioJazz - Smoothjazz HD Audiophile
- NEW: EuropaRadioJazz - TheSoundOfJazz
Updates
- UPD: Improve performance of Library for large collections
- UPD: Streamline layout of Sources, Network and System config pages
- UPD: Add audio device descriptions to Customize popup (21 devices, 11 new)
- UPD: RaspyPlay4 DAC added to I2S audio device dropdown
- UPD: Add friendly names for Audio output on MPD config page
- UPD: Replace btn-cmd code in scripts-configuration.js with same from scripts-playback.js
- UPD: Show/hide userid and password fields on mount screen based on CIFS or NFS selected
Bug fixes
- FIX: Incorrect metadata parsing for radio stations that do not transmit a name element
- FIX: Wrong selector id on "for=" for kernelver label on System config page
- FIX: System config page not updating certain form fields after selection change
- FIX: Toggle control for CMedia not working on System config page
Old 12th April 2015, 05:34 PM   #46
Default Database drilling
Good Morning Tim,
The SD card was trashed last night, so I have partially rebuilt this morning. I used Internet Explorer, and all the strange defaults did not appear, so that part of it does seem related to Chrome being little to helpful.
I then followed your instructions as captured here:
root@moode:~# telnet localhost 6600
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
OK MPD 0.19.0
stats
uptime: 2201
playtime: 0
artists: 2300
albums: 1303
songs: 17894
db_playtime: 4577741
db_update: 1428858266
OK
lsinfo
directory: NAS
Last-Modified: 2015-04-12T16:41:36Z
directory: WEBRADIO
Last-Modified: 2015-03-26T00:23:20Z
OK
lsinfo NAS
directory: NAS/Sy112aud
Last-Modified: 2015-04-05T02:54:45Z
OK
lsinfo NAS/Music
ACK [50@0] {lsinfo} Not found
It appears it could not look below the NAS "name" level. The Browse panel does look down and the files play.
Skip
Old 12th April 2015, 05:50 PM   #47
phofman is offline phofman  Czech Republic
Code:
lsinfo NAS
OK
Apparently the directory name is Sy112aud instead of the expected Music. Or the Music dir is not readable by the user which MPD is running under (mpd?).
Old 12th April 2015, 07:09 PM   #48
TimCurtis's Avatar
@Skip - see ^ above post from phofman and use NAS/Sy112aud as the starting point for lsinfo commands. Sy112aud must be what you entered in the "Source name" field on the Source screen, correct?
I'm interested in seeing the lsinfo output for a directory containing song files. This will show the metadata tags in the files.
Also, the results of the stats command confirm the MPD database is not empty. Given this and the fact that you can use the Browse tab to navigate through directory structure indicate the MPD Database Update was successful.
The blank Library tab plus no stats in the lower right suggests the Library load module exited before loading even a single tag!
TC
Old 12th April 2015, 08:40 PM   #49
Default Finally
Here's what I believe you want to see:
root@moode:~# telnet 192.168.1.102 6600
Trying 192.168.1.102...
Connected to 192.168.1.102.
OK MPD 0.19.0
lsinfo "NAS/Sy112aud/Albert Collins/Frostbite"
file: NAS/Sy112aud/Albert Collins/Frostbite/01_-_If You Love Me Like You Say_-_Albert_Collins.flac
Last-Modified: 2012-11-05T05:59:36Z
Time: 248
Composer: Little Johnny Taylor
Artist: Albert Collins
Title: If You Love Me Like You Say
Album: Frostbite
Genre: Blues
Date: 1980
AlbumArtist: Albert Collins
Track: 1
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/02_-_Blue Monday Hangover_-_Albert_C ollins.flac
Last-Modified: 2012-11-05T05:59:38Z
Time: 335
Composer: Gilbert Caples
Composer: Deadric Malone
Composer: Joe Jonas
Title: Blue Monday Hangover
Album: Frostbite
Genre: Blues
Date: 1980
Track: 2
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/03_-_I Got a Problem_-_Albert_Collin s.flac
Last-Modified: 2012-11-05T05:59:42Z
Time: 275
Title: I Got a Problem
Album: Frostbite
Genre: Blues
Date: 1980
Track: 3
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/04_-_Highway Is Like a Woman_-_Alber t_Collins.flac
Last-Modified: 2012-11-05T05:59:44Z
Time: 303
Title: Highway Is Like a Woman
Album: Frostbite
Genre: Blues
Date: 1980
Track: 4
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/05_-_Brick_-_Albert_Collins.flac
Last-Modified: 2012-11-05T05:59:48Z
Time: 276
Title: Brick
Album: Frostbite
Genre: Blues
Date: 1980
Track: 5
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/06_-_Don't Go Reaching Across My Pla te_-_Albert_Collins.flac
Last-Modified: 2012-11-05T05:59:50Z
Time: 225
Title: Don't Go Reaching Across My Plate
Album: Frostbite
Genre: Blues
Date: 1980
Track: 6
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/07_-_Give Me My Blues_-_Albert_Colli ns.flac
Last-Modified: 2012-11-05T05:59:54Z
Time: 255
Title: Give Me My Blues
Album: Frostbite
Genre: Blues
Date: 1980
Track: 7
Disc: 1
file: NAS/Sy112aud/Albert Collins/Frostbite/08_-_Snowed In_-_Albert_Collins.flac
Last-Modified: 2012-11-05T05:59:58Z
Time: 551
Title: Snowed In
Album: Frostbite
Genre: Blues
Date: 1980
Track: 8
Disc: 1
OK
________________________________
I was looking for a relatively short example. Would you lilke a more complex tag set?
Skip
Old 12th April 2015, 09:14 PM   #50
TimCurtis's Avatar
Hi Skip,
Thanks, the tags look ok.
I'd like to test a couple of the files and see if I can reproduce the issue.
Could you zip 2 of them and then either email the zip file to me via my email address on the "Contact Tim Curtis" link at tcmods.org, or put it on a site and email me the download link?
TC
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
