PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 9th April 2015, 12:23 AM   #21
Skip Pack is offline Skip Pack  United States
Originally Posted by tppc View Post
What were the defaults?
All of the defaults (in the Sources>add NAS interface) were:
Name = Synology (Actually named Sy112aud)
Protocol = NFS (correct)
IP address (I think) autocompleted correctly
Remote file offered four choices, one correct, all close having different parts of the full path, and some caps.
No entries in the NAS login and password, which I entered well before they showed up in the WLAN section, certainly before I saw them there.
These are a bit of a guess since this all happened last night and much has happened since.
Skip
Old 9th April 2015, 01:13 AM   #22
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
I can load a 1.8t1 image tomorrow and see if I can find anything odd.
I did try your nfs mount settings in the 1.8t2 release that I am currently working on and the Source screen started with all blank fields (no defaults). The mount timed out since I don't have any nfs shares but nonetheless the screens completed.
The string that the Player constructed for the NFS mount is:
mount -t nfs -o nfsvers=3,ro,noatime "192.168.1.107:/volume1/public" "/mnt/NAS/Music2"
The code does not put a userid and password in the mount string like it does for a CIFS mount. Is access to NFS shares granted in a way other than by supplying userid and password in the mount string???
Log dump.
root@rp2:~# cat /var/log/php_errors.log
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1016 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6','nfsvers=3,ro,noatime',
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1014 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6','nfsvers=3,ro,noatime',''
[09-Apr-2015 00:05:45 UTC] >>>>> values on line 1019 >>>>> 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6','nfsvers=3,ro,noatime',''
[09-Apr-2015 00:05:45 UTC] >>>>> cfgdb_write(cfg_source,dbh,'Music2','nfs','192.168 .1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6','nfsvers=3,ro,noatime','') >>>>>
INSERT INTO cfg_source VALUES (NULL, 'Music2','nfs','192.168.1.107','volume1/public','TIMUSER','TIMPASSWORD','utf8','8048','809 6','nfsvers=3,ro,noatime','')
[09-Apr-2015 00:05:45 UTC] >>>>> cfgdb_read(cfg_source,dbh,,2) >>>>>
SELECT * from cfg_source WHERE id='2'
[09-Apr-2015 00:05:45 UTC] >>>>> mount string >>>>> mount -t nfs -o nfsvers=3,ro,noatime "192.168.1.107:/volume1/public" "/mnt/NAS/Music2"
[09-Apr-2015 00:07:56 UTC]
[09-Apr-2015 00:07:56 UTC] >>>>> cfgdb_update(cfg_source,dbh,,Array) >>>>>
UPDATE cfg_source SET name='Music2', type='nfs', address='192.168.1.107', remotedir='volume1/public', username='TIMUSER', password='TIMPASSWORD', charset='utf8', rsize='8048', wsize='8096', options='nfsvers=3,ro,noatime', error='mount.nfs: Connection timed out' where id=2
root@rp2:~#
TC
Old 9th April 2015, 04:50 PM   #23
Last night I got the NAS to mount, and I think the key was making sure the NAS login and password fields were blank. I think there is an interface quirk, possibly browser and system related, that repopulates those entries when you thought you had cleared them. I will reimage and attempt to clarify the situation today.
Skip
Old 9th April 2015, 05:55 PM   #24
kolja7t is offline kolja7t  Serbia
Originally Posted by Skip Pack View Post
...I think the key was making sure the NAS login and password fields were blank...
Skip
In my moode NAS section I use Username>Guest without password...
www.kolja.biz
Old 9th April 2015, 11:02 PM   #25
TimCurtis's Avatar
Skip
Userid and password are not used in the mount string for NFS but they will be stored in the Player database along with the rest of the form fields for the mount, and are displayed when editing the mount. Removing the mount deletes the entry from the Player database.
The Sources screen should probably be modified so the userid and password fields are hidden when NFS is selected from the dropdown. I'll see what I can do.
TC
Old 9th April 2015, 11:23 PM   #26
I started again and meticulously reimaged and followed the directions without any side steps. When I was adding the NAS, The smart defaults were still there, so I got the entries in place and deleted the login name making sure to mouse off to the side once it was deleted (not down through the suggested value box).
It mounted fine and indexed. Hiding those fields sounds like a good idea if you can be sure some NAS devices sharing via NFS won't need them.
I'm using Win32DiskImager to write the SD card. When I rewrite the image to the card, can some of the files previously present remain?
thanks,
Skip
Old 10th April 2015, 12:22 AM   #27
TimCurtis's Avatar
thanks,
Skip
Hi Skip,
Glad to here that the mount worked and you are up and running
Wrt your question, writing an image to the card definitely overwrites it. There is no possibility of any previous data showing up in the Player.
Earlier, I checked the 1.8t1 image and all the mount fields were blank. As part of the 1.8t2 work I'll update the Source and mount screens and associated code and will check carefully to see if there is anything that might be auto-populating the mount fields for NFS mounts.
Tim
Old 10th April 2015, 03:22 AM   #28
As I mentioned before, i followed in readme instructions first setting the time zone, exiting from SSH, then using the web interface to add the NAS. The indexing took about 20 minutes. I have a large, but not monumentally large collection of music. I used the System tab reboot which took about 10 minutes, and browsing the library looked good. My next step was setting up to use my HiFiBerry Digi+. The interface seemed to work fine, but when I went to reboot, it did not reconnnect. I quit the web interface and power-cycled the RPI2 after about 1 hr. 15 min. After I power it up, it cannot be reached (ping,SSH, or web interface).
I cannot remove the SSID name and password which are persistently set to those for the NAS. I suspect this might be relevant though that's not well supported by evidence.
Thanks for sticking with this, and me.
Skip
Old 10th April 2015, 03:45 AM   #29
TimCurtis's Avatar
Hi Skip,
Very odd.
One way to trouble shoot would be to start with fresh image and then:
(1) Configure Hifi Berry Digi+ (System config) REBOOT
(2) Add a radio station to the playlist
(3) Verify that the station plays
If station plays then:
(4) Add your NFS mount
(5) Wait for MPD database update to complete
(6) Verify that NFS share shows up in Browse/NAS
(7) Add tracks to playlist from Browse/NAS
--OR--
(8) Press Library tab and wait for Library to be populated
(9) Add tracks from Library
Tim
Old 10th April 2015, 09:36 PM   #30
JLOP is offline JLOP  France
Very professionnel Tim, congrats ! Could you wrap somewhere the benefits compared to Runeaudio UI, and things that have been lost, if any, as well as the global configuration ?
BR
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
