PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 4th April 2015, 01:13 PM   #11
kolja7t is offline kolja7t  Serbia
Originally Posted by tppc View Post
Hi kolja7t,
I'll add RaspyPlay4 to the DAC compatibility list. Thanks!
Its not yet in the i2s device dropdown on System config, but I would like to add it. All I need to know is which i2s device you are currently selecting.
Playlist drag/drop - I'll take a look
TC
Thanks for replay! I selected "IQaudIO PI-DAC+".
Best wishes!
www.kolja.biz
Old 8th April 2015, 01:05 PM   #12
Best wishes!
I am using now "IQaudIO PI-DAC" without "+" and everything is also OK, because of RaspyPlay4 haven't "Headphone amp" like "+" version of IQaudIO PI-DAC...
Just for your information.
www.kolja.biz
Old 8th April 2015, 01:56 PM   #13
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Thanks! I'll update the device description for RaspyPlay4 and also change to use the device overlay for iqaudio pi-dac instead of pi-dac+.
tcmods.org
http://twitter.com/MoodeAudio
TC
Old 8th April 2015, 08:46 PM   #14
Skip Pack is offline Skip Pack  United States
Default NAS Mount issues
I have an RPI2 with HiFiBerry Dac+ that I would like to use to check out Moode. I created a 1.18t1 image and got a successful boot with timezone modifications, but I have been fighting the NAS mount. I have duplicated the fstab entry from a laptop I have been using for LMS that mounts my NAS, but that fails with the following message:
Last system mount error
mount.nfs: access denied by server while mounting 192.168.1.107:/public/music
It is an NFS share and I have the permissions entry in the NAS server set for the IP address of the RPI2 with read/write permission. I can send an image of the Source page. I also noticed that the login and password for the wireless network appears to automatically been copied from the NAS information and does not match the network name and WPA password. I would prefer not to use wireless at all except for a phone interface that would be picked up by my router and feed through the LAN.
Any thoughts are most welcome.
Skip Pack
Old 8th April 2015, 10:21 PM   #15
TimCurtis's Avatar
Skip Pack
(1) Start with a fresh 1.8t1 sd card image and then ssh in and perform a manual mount to your NFS share to see if that works. I don't have a way to test NFS, but u could try something like this:
mkdir /mnt/NAS/Music
mount -t nfs .....
If u can get a manual nfs mount to work, I can compare that string to what the code is doing when it constructs an nfs mount. In the meantime, I'll examine the code to see if there are any obvious bugs in nfs mount string.
(2) I don't quite understand the bolded text above. The Source mount userid and password are separate from the Network/Wireless SSID and password. Are u seeing something odd in either the Sources or Network screens, or possibly in some OS files?
tcmods.org
TC
Old 8th April 2015, 10:40 PM   #16
TimCurtis's Avatar
You can also check the following log. The player logs the mount string defined in Sources to this file.
cat /var/log/php_errors.log
btw: if log files are getting big run this command:
/var/www/tcmods/r18/cmds/utility.sh clear-logs
TC
Old 8th April 2015, 11:20 PM   #17
The manual mount worked insofar as I can cd down into the files and do an ls with the right results. I doesn't show up in moOde interface as a monted NAS. The mount string that worked was:
mount -t nfs 192.168.1.107:/volume1/public /mnt/NAS/Music
On the wireless question, without any action on my part, SSID under the Network tab contains an entry that is actually the admin login on the NAS and the dots in the password entry look to be the length of and NAS admin password
I appreciate the help.
Skip
Old 8th April 2015, 11:34 PM   #18
TimCurtis's Avatar
Success with manual mount is good news. I'll investigate.
Wrt the Network config page, is the SSID field populated with your actual admin userid to your NAS?
If so, then has this userid/password been entered manually in any OS files?
TC
Old 8th April 2015, 11:49 PM   #19
Yes.
No, I believe it was either populated automatically or after I thrashed through a number of NAS mounting attempts under the Sources tab. What I did notice was that there were intelligent defaults suggested in the NAS mounting dialog before I had entered anything, which I did not expect. moOde acted as though it was polling the network for possibilities. After I had failed to mount the NAS, I looked under the Network tab for the first time and that login and password were entered. I attempted clear them, but they are there every time I return, in spite if reimaging the SD card twice.
mysterious.
Skip
Old 9th April 2015, 12:08 AM   #20
TimCurtis's Avatar
Yes.
mysterious.
Skip
Very odd.
What were the defaults?
TC
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
