PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 30th April 2018, 01:16 PM   #14891
TheOldPresbyope is offline TheOldPresbyope  United States
Default MoodeAudio Forum
Just a gentle reminder that the new forum at Moode Forum has been live for several weeks now.
This diyaudio forum has been kept open as an archive of past communications (nearly 15000 posts!) but it is no longer being monitored regularly.
Kent
Old 1st May 2018, 09:13 AM   #14892
deztiny is offline deztiny  Germany
Exactly, thats why i posted a howto for absolute beginners on mo0de installation in the new forum. Including some explanations...
Check out Easy installation guide for absolute beginners
Perhaps it is unconventional but thats simply how I am doing it :-)
And on this occasion A THOUSAND THANK YOUs to everybody who contributed their knowledge, time and effort to this forum! Like TheOldPresbyope and so many others! After nearly 1500 posts (and reads on my side) there is really some melancholy involved leaving this place ... ;-)
Old 2nd May 2018, 07:35 AM   #14893
Tutorial moved here Easy installation guide for absolute beginners
Old 10th May 2018, 06:39 AM   #14894
DRONE7 is offline DRONE7  New Zealand
Thanks sjoerdju for the beets info... most interesting and solved a drive full of orphan rips needing artwork.. :-)
I have since revisited my abcde config and setups..... The time and travails to configure for format, drive offset, artwork etc was becoming onerous with each and every os upgrade...(Ubuntu you need a rolling release ;-) )
Sooooo I downloaded and wrote to a live usb install, Daphile. (sort of MoOde for x86)
It has a ripper that is abcde base, has offset calibration, musicbrainz(s), lookup and 'accurate rip' checking all as checkbox defaults...:-)
I have an old HP t5470 thin client with 2Gb ram and 2Gb flash that just fits daphile.
Add an external cd/dvd drive and configure.
An old laptop or tower would be fine and everything can run from the Daphile live usb so just plug n play for ripping duties.
All headless and independent of main o/s and Moode player. No hit to resources on those setups... ;-)
File Type: jpeg Screenshot from 2018-05-10 17-03-30.jpeg (47.2 KB, 824 views)
File Type: jpeg Screenshot from 2018-05-10 17-21-28.jpeg (79.3 KB, 810 views)
Old 15th May 2018, 10:26 PM   #14895
rhizomusicosmos is offline rhizomusicosmos  Australia
rhizomusicosmos's Avatar
Thanks @DRONE7, I hadn't considered using Daphile for CD ripping duties. I already have it on USB stick so will look into this. Like you I find ripping with Ubuntu convoluted at times -- I generally end up using MusicBee on a Windows install for that.
Old 20th May 2018, 05:55 PM   #14896
AitchKay is offline AitchKay
Originally Posted by sinski View Post
So, now i did some more tests and i am trying to put all information about sound quality tweaking in one place.
1. This is a must - wifi off, bt off, hdmi off, volume control off, eq off, resampling off.
2. added in /boot/config.txt :
force_turbo=1
avoid_pwm_pll=1
arm_freq=333
over_voltage=-7
core_freq=166
h264_freq=166
isp_freq=166
v3d_freq=166
gpu_freq=166
sdram_freq=166
sdram_schmoo=0x021e882c
over_voltage_sdram_p=5
over_voltage_sdram_i=3
over_voltage_sdram_c=-13
gpu_mem=16
3. added in /boot/cmdline.txt:
dwc_otg.microframe_schedule=0 dle=0 dwc_otg.nak_holdoff_enable=1 dwc_otg.fiq_fix_enable=0 dwc_otg.lpm_enable=0 smsc95xx.turbo_mode=N isolcpus=2,3
isolcpus is isolating two cpus only for mpd and works only on quadcore pi's
4. changed options in /lib/systemd/system/mpd.service, original value is uncommented:
#CPUSchedulingPolicy=other
CPUSchedulingPolicy=fifo
tried different, for me fifo sounds best.
#CPUSchedulingPriority=43
CPUSchedulingPriority=70
tried higher settings, but 70 is a good compromise
#Nice=-10
Nice=-15
also tried higher values, but -15 is a good compromise
#ExecStart=/usr/local/bin/mpd --no-daemon $MPDCONF
ExecStart=/usr/bin/taskset -c 2,3 /usr/local/bin/mpd --no-daemon $MPDCONF
this one is starting mpd using isolated cpus and no other processes are using those cpus.
My streaming is sounding as good, as never before and now it is clear for me, that underclocking cpus and ram is really great.
Thanks to anybody, who found out, how to "audiophilise" and "de-digitituslise" moOde
Maybe some of those tweaks (which are not making system unstable) can be implemented in moOde?
Nice tweaks - definately a more "organic" sound, runs too slow for DSD streams though - plays about 2 seconds stops 2 seconds more stops - etc etc.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
