PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 13th March 2018, 04:49 PM   #14441
redhot is offline redhot
Default Autoplay
Hi Tim, with Moode 4.0 I can't get Autoplay to work with my RPi2 when I physically remove power from the device. I'm trying to use it to autoplay a handful of songs stored locally on the SD card. Is this a bug or is there somewhere I can report it as an issue? Thanks.
Old 13th March 2018, 04:49 PM   #14442
randytsuch is offline randytsuch
Originally Posted by TimCurtis View Post
These are settings on System config. If u manually edit the file then moOde is broken.
So you can't add a line to config.txt without breaking moode?
Because then with a pi3 or pi zero w, you can't use bluetooth. Unless there is a trick I don't know about.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 13th March 2018, 05:31 PM   #14443
mikaella is offline mikaella  Romania
Are u referring to Pi Touch? Just turn it on in System config.
Hi Tim! Thanks for all your fantastic work! I really love moode!
Is the UI supposed to "just work" when flipped on? I installed the RPi Pixel gui and autostart Chromium in kiosk mode pointing to moode.local to get anything except the command line to show up on screen.
Am I missing Something?
2nd Issue: I cannot for the love of Moode get it to mount a share from my Synology Nas (which I know to be working well from OSMC)
Old 13th March 2018, 05:51 PM   #14444
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
I'm not able to repro this, either by Menu, Restart, Shutdown or by just pulling the plug.
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 13th March 2018, 05:57 PM   #14445
TimCurtis's Avatar
Randy
Hi Randy,
Many files including /boot/config.txt are managed via moOde UI and the underlying code. If they are manually modified then all bets are off and moOde will most likely malfunction and be broken.
In the case of the integrated WiFi and Bluetooth adapters, there are individual ON/OFF settings for these on the System config screen and thus there is no need to manually modify /boot/config.txt to disable either of them.
I use Bluetooth just fine on PI0 and 3B.
-Tim
Enjoy the Music!
Old 13th March 2018, 05:59 PM   #14446
TimCurtis's Avatar
I have no idea what u are trying to do with "Pixel gui".
Enjoy the Music!
Old 13th March 2018, 06:20 PM   #14447
Rucia1 is offline Rucia1
I have no idea what you mean by this.
Originally Posted by Rucia1 View Post
I have a problem with tidal. After entering the recommended playlist, the message "service login or communic"
Old 13th March 2018, 06:24 PM   #14448
How is the moOde Ui supposed to show up on the screen?
I installed the default Pixel desktop environment + chromium to have an environment to display moOde in. Raspbian Stretch Lite has no desktop environment (gui) by default as far as i know.
is there another way?
After installing moode all was working well remotely but flipping the "Local UI display" and applying does nothing. (looking at the CLI i can see it restarting chromium) but how can this run without an environment?
(sorry if it's not clear, i'm not an expert in this...)
Old 13th March 2018, 06:35 PM   #14449
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
Just use "Add to home screen" from IOS Safari. Then it will be an "App".
Wow awesome thank you... every day is good new...Tim 😇👍
Old 13th March 2018, 07:09 PM   #14450
User42 is offline User42
Default I need a magnifying glass
Hello Tim!
I wonder if it is possible to limit the dynamic text size. On Android with expanded keyboard all texts get to tiny, i can't read them anymore.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
