PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 13th February 2018, 03:29 PM   #13701
Josepj Lin is offline Josepj Lin  United States
Originally Posted by TimCurtis View Post
The article "Linux Ate My RAM" has good info on how to interpret memory utilization.
Help! Linux ate my RAM!
Here is snapshot of Pi-0W memory usage with Bluetooth, Airplay, UPnP and DLNA server on, and MPD database rescan is running to create file caching.
Code:
pi@rp2:~ $ free -mh
              total        used        free      shared  buff/cache   available
Mem:           434M         58M         28M         38M        347M        288M
Swap:            0B          0B          0B
If you can provide a scenario that creates an out of memory condition I'll try and repro it.
-Tim
I am surprise to see you have such a low memory usage. This is my Zero W after boot up with all services turned on. If I turn on EQ, it will eat more memory and eventually hangs. But it is still on 4b12 and could be just bad a build. I'll try a new 4.0 build.
Old 13th February 2018, 04:12 PM   #13702
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Parametric or Graphic EQ?
It could be a memory leak in one of them :-0
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 13th February 2018, 04:17 PM   #13703
thisisvv is offline thisisvv  United States
SO the moode can see my dave... following command show dave is there..
cat /proc/asound/cards
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [Dave ]: USB-Audio - Dave
Chord Electronics Ltd Dave at usb-3f980000.usb-1.3, high speed
how do i select dave for output?
also even trying multiple-times moode can't see my nas. It doesnt bring it under browse section
Old 13th February 2018, 04:56 PM   #13704
kaspersone is offline kaspersone  Denmark
Default Webradio - song title
When playing radio some stream shows "song title - artist" - and some doesn't.
BBC 1 (AAC)
Frequence 3 (FLAC)
Frequence 3 (MP3) - added manually
SomaFM (MP3)
For some reason it seems that MP3 streams show metadata but FLAC and AAC doesn't.
I added the Frequence3 station manually just for test purpose, and the mp3 variant shows title and artist, the flac stream doesn't. Same radio. I have same results with other manually added radio stations.
Is it something with settings? or is it just the way the streams work?
Old 13th February 2018, 05:57 PM   #13705
polimich is offline polimich
Hi! Where can I find the last 3.8.x version to download it?
Thanks!
Old 13th February 2018, 05:59 PM   #13706
-Tim
It is EQ, but just a reminder that it is on 4b12 not official 4.0
Old 13th February 2018, 06:09 PM   #13707
TimCurtis's Avatar
BBC 1 (AAC)
Frequence 3 (FLAC)
SomaFM (MP3)
Its due to broadcaster not injecting metadata into their stream. Its not dependent on the audio format thats being used for example all the Soma FM streams included in moOde are all 128K AAC.
-Tim
Enjoy the Music!
Old 13th February 2018, 06:17 PM   #13708
TimCurtis's Avatar
Just a heads up that latest MPD 0.20.17 which is being planned for inclusion in moOde 4.1 update appears to have a regression in the "find modified-since" command which will cause the Library loader to return zero results :-0
Just need to get a repro to confirm the bug.
Good news is that there is a different command that can be used for the Library loader that works fine and appears to be significantly faster :-) A bit more testing needed tho.
-Tim
Enjoy the Music!
Old 13th February 2018, 07:50 PM   #13709
-Tim
It is Graphic EQ.
Old 13th February 2018, 08:13 PM   #13710
astropuppy is offline astropuppy
Thought Id share my office set-up:
Basically, I work in a cubicle farm starring at a computer screen. The company I work for pumps in white noise in an effort to drown out conversions in the fishbowl in which I work.
Last black Friday I picked up a pair of Bose QC25 noise cancelling headphones. Plugged them into my smartphone and no more white noise or conversations. One problem: I found the phone to be very fatiguing. About an hour is all I could handle without a rest. So I loaded up MooDe 3.8 on a PI Zero. Added a wi-fi dongle, Pimoroni PHAT dac and a 256TB usb drive loaded with Flac files. Sounds great. Im not a big Bose fan, but after trying many others, I truly think Bose has the best noise cancelling technology. At least at my price point.
Initially, I used the mooDe gui to control the zero; but, I wanted a way to navigate all the tags I tirelessly maintain in my collection. With a proper backup, I installed Minimserver on top of Moode and pointed it at the usb stick. Next, Bubbleupnp app was loaded on the phone. Now Bubbleupnp is used to navigate tags and using MooDe as a Upnp renderer. MooDe is also used to shut it down when go home time comes via the gui.
Music Nirvana at work. Thank you for a great product.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
