PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 13th February 2018, 10:45 AM   #13691
didiet78 is offline didiet78  Indonesia
Originally Posted by TimCurtis View Post
This param is used just for just for AP mode, correct?
nohook wpa_supplicant # don't call the wpa_supplicant hook
There must have been some change in dhcpcd from 9.1 to 9.3 Raspbian. I'll investigate.
-Tim
Correct.
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 13th February 2018, 11:00 AM   #13692
Mrpink200 is offline Mrpink200
Hi Alain,
The only renderers that show album art in moOde are Airplay and UPnP. Neither Bluetooth nor Squeezelite provide an album art API.
-Tim
So sad. Many thanks for the feedback Tim !!
Old 13th February 2018, 11:12 AM   #13693
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by didiet78 View Post
Correct.
Ok, added to the end.
interface wlan0
static ip_address=172.24.1.1/24
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 13th February 2018, 11:29 AM   #13694
streamerguy is offline streamerguy
First, thanks Tim for all the effort you put into Moode!
I have been using Moode 3.7 for several months without issues. I use a Marantz NA11S1 usb dac. When Moode 3.8 was released, I tried that version as well, but the Marantz dac was clicking a lot, so I went back to 3.7.
After I saw Moode 4.0 was released I gave it another try. Installing/building was successful but the Pi freezes random and I notice a click sometimes.
Tried already:
- new power supply (original PS)
- new SD card (brand)
- even a new RPI3
- used several kernels 4.9.x and 4.14.x
- underclocked RPI3 to 1000Mhz
This was all without success.
At one moment I saw an "Oops" message on the connected HDMI screen, but there is nothing in the log files because I need to power off/on the Pi after a freeze.
I really like to run 4.0 because I think it sounds better then 3.7.
Any idea's.
Old 13th February 2018, 11:36 AM   #13695
TimCurtis's Avatar
Hi @streamerguy,
System hang is not something that users are reporting with 4.0, so other than basic troubleshooting I can't really offer anything.
Reboot and post output from /var/log/moode.log and mosbrief cmd and I'll have a look.
-Tim
Enjoy the Music!
Old 13th February 2018, 11:51 AM   #13696
Hi Tim,
Here is the output. Looks ok to me.
pi@raspberrypi4:~ $ mosbrief
// STEP 2 - Direct build so no need to expand Root partition
// STEP 3A - Install core packages
// STEP 3B - Install core packages
// STEP 4 - Install enhanced networking
** Compile bluez-alsa
// STEP 5 - Install Rotary encoder driver
** Compile WiringPi
** Compile rotary encoder driver
// STEP 6 - Compile and install MPD
// STEP 7 - Create moOde runtime environment
// STEP 8 - Install moOde sources and configs
// STEP 9 - Alsaequal
** STEP 10 - Squashfs option not selected
** STEP 11 - Latest kernel option not selected
// STEP 12 - Launch and configure moOde!
// STEP 13 - Final prep for image
// COMPONENT 1 - MiniDLNA
// COMPONENT 2 - Auto-shuffle
// COMPONENT 3 - MPD Audio Scrobbler
// COMPONENT 4 - Shairport-sync
// COMPONENT 5 - Squeezelite
// COMPONENT 6 - Upmpdcli
** Compile Libupnp jfd5
** Compile Libupnpp
** Compile Upmpdcli
** Compile Upexplorer
// COMPONENT 7 - Optionally install gmusicapi
// COMPONENT 8 - Local UI display
// COMPONENT 9 - Allo Piano 2.1 Firmware
// END
pi@raspberrypi4:~ $ cat /var/log/moode.log
20180213 134755 worker: - Start
20180213 134756 worker: Successfully daemonized
20180213 134756 worker: - Init
20180213 134756 worker: Session loaded
20180213 134756 worker: Debug logging (off)
20180213 134757 worker: Host (raspberrypi4)
20180213 134757 worker: Hdwr (Pi-3B 1GB v1.2)
20180213 134757 worker: Arch (armv7l)
20180213 134757 worker: Kver (4.14.18-v7+)
20180213 134757 worker: Ktyp (Standard)
20180213 134757 worker: Gov (performance)
20180213 134757 worker: Rel (Moode 4.0 2018-01-26)
20180213 134757 worker: Upd (None)
20180213 134757 worker: MPD (0.20.17)
20180213 134757 worker: USB boot enabled
20180213 134758 worker: File system expanded
20180213 134758 worker: HDMI port on
20180213 134758 worker: File check ok
20180213 134758 worker: - Network
20180213 134758 worker: eth0 exists
20180213 134758 worker: eth0 (192.168.2.41)
20180213 134758 worker: wlan0 exists
20180213 134758 worker: wlan0 SSID is blank
20180213 134758 worker: eth0 addr exists, AP mode not started
20180213 134758 worker: wlan0 address not assigned
20180213 134758 worker: - Audio
20180213 134758 worker: ALSA outputs unmuted
20180213 134758 worker: Audio output (USB audio device)
20180213 134758 worker: ALSA mixer name (PCM)
20180213 134758 worker: MPD volume control (disabled)
20180213 134758 worker: Hdwr volume controller exists
20180213 134758 worker: - Services
20180213 134801 worker: MPD started
20180213 134801 worker: MPD scheduler policy (time-share)
20180213 134801 worker: MPD output 1 ALSA default (on)
20180213 134801 worker: MPD output 2 ALSA crossfeed (off)
20180213 134801 worker: MPD output 3 ALSA parametric eq (off)
20180213 134801 worker: MPD output 4 ALSA graphic eq (off)
20180213 134801 worker: MPD crossfade (off)
20180213 134801 worker: UPnP renderer started
20180213 134801 worker: - Last
20180213 134801 worker: USB sources (none attached)
20180213 134801 worker: NAS sources (mountall initiated)
20180213 134801 worker: Volume level (0) restored
20180213 134801 worker: Maintenance interval (21600)
20180213 134801 worker: Watchdog started
20180213 134801 worker: Ready
pi@raspberrypi4:~ $
Old 13th February 2018, 11:56 AM   #13697
I was able to retrieve this also (running kernel 4.14.18 during one of my tests):
Feb 12 00:51:41 raspberrypi4 kernel: [84728.185551] Unable to handle kernel NULL pointer dereference at virtual address 000000c0
Feb 12 00:51:41 raspberrypi4 kernel: [84728.188159] pgd = b6bcc000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.189448] [000000c0] *pgd=36be5835, *pte=00000000, *ppte=00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.190894] Internal error: Oops: 17 [#1] SMP ARM
Feb 12 00:51:41 raspberrypi4 kernel: [84728.192238] Modules linked in: snd_usb_audio snd_hwdep snd_usbmidi_lib snd_rawmidi snd_seq_device brcmfmac brcmutil cfg80211 rfkill snd_soc_bcm2835_i2s snd_bcm2835(C) snd_soc_cor
e i2c_bcm2835 snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd uio_pdrv_genirq uio fixed ip_tables x_tables ipv6
Feb 12 00:51:41 raspberrypi4 kernel: [84728.198161] CPU: 0 PID: 754 Comm: io Tainted: G C 4.14.18-v7+ #1093
Feb 12 00:51:41 raspberrypi4 kernel: [84728.201242] Hardware name: BCM2835
Feb 12 00:51:41 raspberrypi4 kernel: [84728.202778] task: b9100000 task.stack: ae00a000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.204316] PC is at skb_release_head_state+0x48/0x140
Feb 12 00:51:41 raspberrypi4 kernel: [84728.205870] LR is at skb_release_all+0x1c/0x34
Feb 12 00:51:41 raspberrypi4 kernel: [84728.207408] pc : [<80655c58>] lr : [<80655d6c>] psr: 20000013
Feb 12 00:51:41 raspberrypi4 kernel: [84728.208985] sp : ae00be60 ip : ae00be78 fp : ae00be74
Feb 12 00:51:41 raspberrypi4 kernel: [84728.210555] r10: 00000008 r9 : af87a8e0 r8 : 00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.212127] r7 : 0010fe18 r6 : b93e86dc r5 : 00000000 r4 : b6bfdf00
Feb 12 00:51:41 raspberrypi4 kernel: [84728.213712] r3 : 000005b4 r2 : 01793316 r1 : bab53f94 r0 : 000000c0
Feb 12 00:51:41 raspberrypi4 kernel: [84728.215307] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Feb 12 00:51:41 raspberrypi4 kernel: [84728.216896] Control: 10c5383d Table: 36bcc06a DAC: 00000055
Feb 12 00:51:41 raspberrypi4 kernel: [84728.218450] Process io (pid: 754, stack limit = 0xae00a210)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.220029] Stack: (0xae00be60 to 0xae00c000)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.221584] be60: 000005b4 b6bfdf00 ae00be8c ae00be78 80655d6c 80655c1c 000005b4 b6bfdf00
Feb 12 00:51:41 raspberrypi4 kernel: [84728.224693] be80: ae00bea4 ae00be90 80655da0 80655d5c 000005b4 b93e8640 ae00bed4 ae00bea8
Feb 12 00:51:41 raspberrypi4 kernel: [84728.227809] bea0: 806c5d80 80655d90 00000008 806f0cc8 806f0c9c b93e8640 af87a8c0 b9df6110
Feb 12 00:51:41 raspberrypi4 kernel: [84728.230936] bec0: afbbd660 00000000 ae00beec ae00bed8 806f0cf0 806c5a60 af87a8c0 00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.234162] bee0: ae00bf04 ae00bef0 806499bc 806f0ca8 b9253000 af87a8e0 ae00bf14 ae00bf08
Feb 12 00:51:41 raspberrypi4 kernel: [84728.237572] bf00: 80649a64 80649998 ae00bf54 ae00bf18 8028b210 80649a54 00000000 00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.241177] bf20: 8028b3b4 b9253008 b9100528 00000000 b9100528 b9100000 b9100544 80c91dc4
Feb 12 00:51:41 raspberrypi4 kernel: [84728.244924] bf40: b9253000 00000000 ae00bf64 ae00bf58 8028b3cc 8028b180 ae00bf8c ae00bf68
Feb 12 00:51:41 raspberrypi4 kernel: [84728.248878] bf60: 8013b840 8028b3c0 ae00a000 ae00a010 80108224 ae00bfb0 80108224 ae00a000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.252906] bf80: ae00bfac ae00bf90 8010b830 8013b790 6eb08d58 0000000a 76f3198c 00000006
Feb 12 00:51:41 raspberrypi4 kernel: [84728.257055] bfa0: 00000000 ae00bfb0 801080b4 8010b770 00000000 7146a264 00000002 00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.261271] bfc0: 6eb08d58 0000000a 76f3198c 00000006 6eb00478 00000001 76f32048 00000000
Feb 12 00:51:41 raspberrypi4 kernel: [84728.265483] bfe0: 00000000 71469aa0 00000000 735b2474 80000010 0000000a 3abfa861 3abfac61
Feb 12 00:51:41 raspberrypi4 kernel: [84728.269703] [<80655c58>] (skb_release_head_state) from [<80655d6c>] (skb_release_all+0x1c/0x34)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.273937] [<80655d6c>] (skb_release_all) from [<80655da0>] (__kfree_skb+0x1c/0x28)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.278165] [<80655da0>] (__kfree_skb) from [<806c5d80>] (tcp_close+0x32c/0x4e0)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.282389] [<806c5d80>] (tcp_close) from [<806f0cf0>] (inet_release+0x54/0x80)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.284571] [<806f0cf0>] (inet_release) from [<806499bc>] (sock_release+0x30/0xbc)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.288768] [<806499bc>] (sock_release) from [<80649a64>] (sock_close+0x1c/0x24)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.292970] [<80649a64>] (sock_close) from [<8028b210>] (__fput+0x9c/0x1e8)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.295121] [<8028b210>] (__fput) from [<8028b3cc>] (____fput+0x18/0x1c)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.297251] [<8028b3cc>] (____fput) from [<8013b840>] (task_work_run+0xbc/0xe0)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.299366] [<8013b840>] (task_work_run) from [<8010b830>] (do_work_pending+0xcc/0xd0)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.303440] [<8010b830>] (do_work_pending) from [<801080b4>] (slow_work_pending+0xc/0x20)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.307521] Code: e3500000 0a000009 f57ff05b f590f000 (e1902f9f)
Feb 12 00:51:41 raspberrypi4 kernel: [84728.309668] ---[ end trace 6c3b04a14607fb09 ]---
Feb 12 00:52:11 raspberrypi4 upmpdcli[764]: :2:src/mpdcli.cxx:147::mpd_run_stop(M_CONN) failed: Timeout
Feb 12 00:52:11 raspberrypi4 upmpdcli[764]: :2:libupnpp/device/device.cxx:355::UpnpDevice: Action failed: Stop code -911
Feb 12 00:52:41 raspberrypi4 upmpdcli[764]: :2:src/mpdcli.cxx:147::MPDCli:penconn failed: Timeout
Feb 12 00:52:41 raspberrypi4 upmpdcli[764]: :2:src/mpdcli.cxx:191::MPDCli::updStatus: can't get status
Feb 12 00:52:41 raspberrypi4 upmpdcli[764]: :2:src/mpdcli.cxx:147::MPDCli::updStatus failed: Timeout
Old 13th February 2018, 12:55 PM   #13698
TimCurtis's Avatar
Hi @streamerguy,
moOde logs look ok but the kernel Oops which I believe is a page fault condition suggests a kernel bug or maybe bad OC/UC settings in config.txt.
I definitely wouldn't bump to the 4.14.y kernel branch. It caused a lot of odd problems when I tested it out. It usually takes months for the bugs to be shaken out of a new branch.
Two things to try would be:
1. Revert to kernel 4.9.80
sudo PRUNE_MODULES=1 rpi-update 5c80565c5c0c7f820258c792a98b56f22db2dd03
sudo rm -rf /lib/modules.bak
sudo rm -rf /boot.bak
sudo apt-get clean
2. Remove all OC/UC or other hand entered settings from /boot/config.txt and revert it to default. Same for cmdline.txt
/boot/config.txt
disable_splash=1
hdmi_drive=2
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=audio=on
#dtoverlay=pi3-disable-wifi
#dtoverlay=pi3-disable-bt
/boot/cmdlint.txt (all on a single line)
NOTE the PARTUUID may differ in your file
net.ifnames=0 dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=37665771-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
-Tim
Enjoy the Music!
Old 13th February 2018, 02:08 PM   #13699
Josepj Lin is offline Josepj Lin  United States
Originally Posted by Diychip View Post
Hi Tim etc.
Can I add my voice to Mr190E (post 13674).
I used the automated build on 7th Feb for a Pi3 which built fine and still runs well (Stetch Lite downloaded 6th Feb, Pi3 using BT to speaker).
I tried to build a Pi Zero W image with automated builder on 8th of Feb to replace my test Pi3. This ran well before switching radio stations caused it to crash irreversibly. Imaged from back up and similar problem after 4-5hrs running.
Have now rebuilt with automated build 3 times on Pi zero W and although it starts up it fails when trying to confirm almost any change in the settings. I.e. the first time I try to make a setting change.
I have had it crash to unresponsive trying to confirm WiFi access, trying to request a search for BT devices and just trying to switch BT on. A reboot does not clear the problem. If anything it is worse after reboot as often won't load Web interface.
Was anything changed in the automated download between 7th and 8th Feb?
If we can fix this I will deffjnarely donate as I can see 3-4 of these on Pi zeros with BT or hats around the home.
Tried to post on this before but have narrowed the problem a little now.
Frank
I do not know if it will solve your problem but I found Moode uses a lot more memory in Pi Zero W than Pi 3 B. I had similar problems before, then I use htop to monitor processes in Pi Zero W then I found it ate all memory and trying to swapping memory from SD! It is not crashed but hangs there due to trashing. I then turned off almost every services: AirPlay, DLNA, ... and it became more stable. YMMV.
Old 13th February 2018, 02:49 PM   #13700
TimCurtis's Avatar
The article "Linux Ate My RAM" has good info on how to interpret memory utilization.
Help! Linux ate my RAM!
Here is snapshot of Pi-0W memory usage with Bluetooth, Airplay, UPnP and DLNA server on, and MPD database rescan is running to create file caching.
Code:
pi@rp2:~ $ free -mh
              total        used        free      shared  buff/cache   available
Mem:           434M         58M         28M         38M        347M        288M
Swap:            0B          0B          0B
If you can provide a scenario that creates an out of memory condition I'll try and repro it.
-Tim
Enjoy the Music!
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
