PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 30th January 2018, 08:46 PM   #13031
koda59 is offline koda59  France
koda59's Avatar
Originally Posted by TimCurtis View Post
Very odd.
Zip up /home/pi/mosbuild.log and email it to me. I'll have a look.
-Tim
Tim, ask for step file content too
Old 30th January 2018, 08:51 PM   #13032
blackie333 is offline blackie333
Originally Posted by SanderG View Post
Yup, same here. I'm sure I formatted the SD card, and cleared my browser cache though.
I was following the recipe "Build Recipe v2.3, 2018-01-26" included in the "rel-stretch-r40.zip" which contains error, nearly also installed the beta12 version.
There are lines containing the link "http://moodeaudio.org/downloads/beta/rel-stretch-r40b12.zip" to the beta instead of the release.
The correct path is http://moodeaudio.org/downloads/prod...tretch-r40.zip
Old 30th January 2018, 09:09 PM   #13033
DRONE7 is offline DRONE7  New Zealand
Originally Posted by Botte View Post
Sound quality improvement over Beta12?
Yes.. ...some users had preferred the 3.8.4 series with the custom RT/LL kernels to the Beta series without.
From listening, MoOde 4 release appears to have better SQ than Betas and 3.8.4 with RT/LL ...
Old 30th January 2018, 10:40 PM   #13034
jrocker is offline jrocker
I find that 3.8.4 sound better than the 4.0 Betas UNTIL you disable the volume control in Betas, then becomes a matter of choice/preference...
Old 30th January 2018, 10:41 PM   #13035
tkr001 is offline tkr001  New Zealand
I had the same problem even after Tim said he had fixed the recipe. I did a fresh download (several times) and it still referred to beta12 in the build recipe 2.3.
I gave up and used the automated build without issue.
Old 30th January 2018, 10:47 PM   #13036
Big G is offline Big G  United States
Originally Posted by markstwin View Post
It can do either RTFM dude
** Write OS build directly to the boot SDCard (y/n)?
I may be wrong, but I think only the Pi3 will boot from a USB drive.....not 100% about the zero, but I know a Pi2 won't.
Old 30th January 2018, 10:51 PM   #13037
onionhead is offline onionhead  United States
Originally Posted by DRONE7 View Post
I can see we will need a separate thread where we post our customisations...
Winter sunrise from the dining room... PiB MoOde4
Lovely photo. I have been trying to add an image to MoOde. I select an image from my desktop and hit update. So far this has not worked for me. Would mind coming to the rescue.
Old 30th January 2018, 10:53 PM   #13038
TheOldPresbyope is offline TheOldPresbyope  United States
Originally Posted by Aboe View Post
Hi Tim
Thanks for a great new version. But I don't get the Tidal part, I have entered my login but then what?? - before I was using bubbleupnp at my Nas and Lumins Ipad app. But how does this work?
all best aboe
Hi, aboe
As Tim implied in his response, you still have to use a UPnP Control Point app. I happen use BubbleUPnP too. You have to tell it to use Moode UPnP [1] as the UPnP Renderer and Moode UPnP-mediaserver [1] as the UPnP Media Server (which BubbleUPnP confusingly calls Library). This arrangement has been working great for me with Tidal and Google Play Music since Tim added the feature.
Kent
[1] or whatever you changed the names to when you set up UPnP.
Old 30th January 2018, 11:02 PM   #13039
@onionhead
Have you tried reducing the alpha blend? At 1.0, the background image is totally obscured.
And I agree, the photo was quite lovely.
Kent
Old 30th January 2018, 11:02 PM   #13040
I had to resize my image ...it was too big and too big a file size.
It worked at 2580x1504 pixels and 296.4 kB. but that was a random resize and I think the file size was the most important parameter.
probably similar to album art (under 500kB ? does that sound right ?)
Kent is correct about reducing the alpha blend..about .35 is good, and once you update then refresh your browser page..
@ TheOldPresbyope
Thanks Kent, it was quite magical from the dining room window at breakfast...grabbed the camera and let the breakfast go cold.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
