PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 20th May 2015, 02:29 PM   #111
soundcheck is offline soundcheck  Germany
Just figured that IRQ affinity can not be set on the Pi2.
Funny. You'll get 4 processors and you can't make full use them.
If anybody has a solution to it let me know.
I just wrote this little script:
Code:
root@moode:~# cat tune.sh
#!/bin/bash -x
chrt -f -p 80 $(pgrep mpd)
taskset -c -p 3 $(pgrep mpd)
IR=$(cat /proc/interrupts | grep ":usb" | awk '{print $1}' | cut -f 1 -d ":")
echo 2 >/proc/irq/$IR/smp_affinity
exit
The last echo gives I/O errors.
Cheers
Old 20th May 2015, 09:14 PM   #112
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by soundcheck View Post
Hi.
I'm just trying your solution on a Pi2. Worked out of the box. Very nice.
I hooked up my RME Fireface UCX (in class compliant mode).
Another working interface you can add to your DAC list.
A first glance comment:
It seems that just one processor out of 4 is used on the Pi2.
I'd recommend to change CPU affinity and task priority of mpd to e.g. CPU1
and assign the USB interrupt to another free CPU e.g CPU2.
Thx.
Thanks!
I'll add the RME audio device to the DAC list on tcmods.org and to the Audio De ice Description database in Moode
Will investigate CPU pinning, interesting.
TC
Old 20th May 2015, 10:21 PM   #113
superpat is offline superpat  United Kingdom
Default regarding cpu usage on Pi 2
Hi
If you run htop in a ssh terminal whilst pi is playing 192/24 flat, you will see Pi is running with almost No load.
One core shows about 5 per cent, other three cores 0 per cent.
however each core does appear to get a turn, as each time htop rescans, a different core is showing load
Cheers
Patrick
Old 21st May 2015, 08:04 AM   #114
Hi.
I have <1% load on my B+ (overclocked 950Mhz) with squeezelite.
I have currently 3-4% load on my Pi2 (no overclocking) with mpd.
Both on 24/44.1 flacs.
One huge advantage of squeezlite is the configurable processing buffer, which can have any size e.g. 200MB.
Basically you'll see a bulk load and bulk decoding of the flac in the first couple seconds (with higher load) and then the whole track is played back from the internal decoding buffer at minimum load. This avoids all interprocess/interthread bottlenecks that usually cause higher load.
BTW: Do you have MPD compiled with the rtopt patch in?
Cheers
Old 21st May 2015, 08:33 AM   #115
Hi.
It's me again. Reference to my earlier post:
Lifting up just the prority of mpd might cause XRUNS, especially if you load
data over the network. While the file gets loaded from my NFS mount I experience around 2s of initial XRUNS and after that its fine. I'd say the
USB-out overrules the ethernet-in. Once the buffer is initially filled the whole setting works ok.
Old 21st May 2015, 10:32 AM   #116
phofman is offline phofman  Czech Republic
I'd say the
USB-audio is isochronous, all samples available to be transfered to the endpoint will be put into each frame up to 90% of the frame capacity (by USB specifications, the kernel USB core should adhere). But 44/16x2 does not take much of the bandwidth even on 12Mbps fullspeed.
Perhaps the problem is USB1.2 audio mixed with USB2 ethernet, forcing the USB to 12Mbps?
Still the way to go would be to fill the input buffer first and then start the playback, like e.g. mplayer does it (-cache + -cache-min). Perhaps MPD can be configured a bit in that respect?
Old 21st May 2015, 02:47 PM   #117
Regarding CPU affinity.
Not only IRQ assignments didn't work. Task assignments didn't work either, even though "taskset" was reporting positive results.
One step further:
You need to isolate CPUs from CPU balancing first. All tasks are balanced between all CPUs on the PI2 by default.
By introducing a new parameter to /boot/cmdline.txt e.g.:
isolcpus=3
you would isolate the 4th CPU from balancing.
Basically all automatic loaded tasks will be then spread over CPU0 and 1,2. CPU3 can now exclusively be used. You can also add another CPU to the list.
With" taskset" you can now assign a dedicated task e.g. mpd to e.g. CPU3.
However. IRQ assignments are still giving errors.
Old 24th May 2015, 07:46 PM   #118
TimCurtis's Avatar
Just a couple quick announcements:
(1) There is a nice review of Moode in Part-Time Audiophile
Review: Raspberry Pi 2 as Music Streamer | Confessions of a Part-Time Audiophile
(2) tcmods.org web site has a new look as part of transition to new moodeaudio.org domain/email sometime in June.
(3) Several nice UPnP enhancements have tested out and should make it into release 1.9
- Album art displayed if URL provided by UPnP DB server
- Improved metadata handling for UPnP song files
- Play/pause handling for UPnP song files
tcmods.org
Moode on Twitter
TC
Old 25th May 2015, 05:34 AM   #119
DRONE7 is offline DRONE7  New Zealand
Congratulations Tim ! so well deserved.
Old 28th May 2015, 03:04 AM   #120
Buckapound is offline Buckapound  United States
I have a simple question, as I am having some trouble trying to get to the interface for this thing.
The "Readme" on the TCMods site says to go to "http://moode" when booted and connected to a network.
When I do this, depending on the browser I either get nothing at all, or the Moode college site (mode.com). The address for this device seems weird in that it has no .com, .org, etc. so I'm wondering if this is a typo or if there is something I am missing.
I really appreciate all the hard work on this project, but am frustrated that the instructions on the site don't seem to work for me. I do have it booted properly as near as I can tell, and it is showing up when I scan the network.
Any suggestions?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
