PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old Today, 05:18 AM   #11821
Mars67 is offline Mars67  South Africa
Originally Posted by koda59 View Post
Interesting. It could be a date/time issue.
Did you try to update kernel manually ?
I did the kernel update manually following the exact steps in the build recipe and it went through without an issue. When I boot it up it still does not broadcast the AP on wifi. When I connect to the RPI via LAN I can hit the moOde interface on my browser.
I will re-install the enhanced networking manually and see what happens.
Old Today, 05:44 AM   #11822
stuzog is offline stuzog  Canada
Hi Tim,
It's not working for me -- doesn't seem to be writing to the SD card after invoking mosbuild.sh. Here's the terminal output:
Code:
pi@raspberrypi:~ $ ls
mosbuild  mosbuild.sh
pi@raspberrypi:~ $ ls -al
total 40
drwxr-xr-x 3 pi   pi    4096 Dec 12 04:11 .
drwxr-xr-x 3 root root  4096 Nov 29 01:22 ..
-rw-r--r-- 1 pi   pi     220 Nov 29 01:22 .bash_logout
-rw-r--r-- 1 pi   pi    3523 Nov 29 01:22 .bashrc
drwxr-xr-x 2 root root  4096 Dec 12 04:10 mosbuild
-rwxr-xr-x 1 root root 12562 Dec  8 22:14 mosbuild.sh
-rw-r--r-- 1 pi   pi     675 Nov 29 01:22 .profile
pi@raspberrypi:~ $ ls -al mosbuild
total 1814540
drwxr-xr-x 2 root root       4096 Dec 12 04:10 .
drwxr-xr-x 3 pi   pi         4096 Dec 12 04:11 ..
-rw-r--r-- 1 root root 1858076672 Dec 12 04:10 2017-11-29-raspbian-stretch-lite.img
pi@raspberrypi:~ $ sudo chmod +x /home/pi/mosbuild.sh
pi@raspberrypi:~ $ sudo ./mosbuild.sh
**  Moode OS Image Builder v1.0
**  Welcome to the automated process for creating the wonderful
**  custom Linux OS that runs moOde audio player.
**  You will need a Raspberry Pi running Raspbian with SSH
**  enabled, at least 2.5GB free space on the boot SDCard and
**  a spare USB or USB-SDCard drive that the new OS will be
**  written to during the build process.
**  Be sure to backup the SDCard used to boot your Pi
// STEP 1 - Download Raspbian Lite and create a new, base image
** Check free disk space
** Do you have a backup of your boot SDCard (y/n)? y
** Unplug all USB storage devices from the Pi
** Are all USB storage devices unplugged (y/n)? y
** Plug in target USB drive for the new OS
** Is target USB drive plugged in (y/n)? y
** USB drive detected on /dev/sda
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
** Partitions unmounted on /dev/sda
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
** Option 1-5: use a proxy server for Internet access (y/n)? n
** Option 2-5: use a WiFi connection instead of Ethernet (y/n)? n
** Option 3-5: configure /var/www as squashfs (y/n)? y
** Option 4-5: install latest Linux Kernel (y/n)? y
** Option 5-5: Airplay, Ashuffle, LocalUI, Scrobbler, Squeezelite and UPnP/DLNA
** Install additional components (y/n)? y
** Ready for automated image build
** Proceed (y/n)? y
** Test Internet connection
** Download helper files
** Add options to properties file
** Load properties into env
** Base OS image was saved from previous build
** Use saved image to write to USB drive (y/n)? y
** Write image to USB drive on /dev/sda
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
dd: unrecognized operand ‘/dev/sdb’
Try 'dd --help' for more information.
** Flush cached disk writes
** New base OS image created
** Remove the USB drive and use it to boot a Raspberry Pi
** The build will automatically continue at STEP 2 after boot
** Save base OS img for additional builds (y/n)? dd--help
** Valid entries are y|n
** Save base OS img for additional builds (y/n)? y
I'm trying again with a freshly-FAT-formatted 32GB SD card. This time, the green light came on on reboot, but it seems to be stuck on with no flickering. Is that what is supposed to happen? How long is the writing wait time generally?
BTW, an explanation of the y/n questions would be appreciated, or maybe just the better ones?
Stuart
Old Today, 08:02 AM   #11823
Serverbaboon is offline Serverbaboon  United Kingdom
Originally Posted by Gustav9 View Post
Tim, I have beta 12 which I made using the image builder.
Basic functions work fine, however, I have 2 problems.
1. The upnp renderer is set on but it is not showing in Bubble upnp or
when using a upnp device scanner.
2. I have standard kernel only with no option to install the advanced kernels.
Where have I gone wrong?
For upnp try
Sudo chmod 644 /etc/upmpdcli.conf
And reboot.
Old Today, 08:03 AM   #11824
lukivision is offline lukivision  Germany
Default MoOde and Foobar Upnp
Tim - I would very much like a solution for this issue: Your latest versions of moode all make a short break of about 4 seconds after 1 hour, 2 minutes and 8 seconds of continously playing a stream coming from my windows laptop with foobar as upnp server. This did not happen with earlier versions of moode. I cant remember when it occured the first time, but it really did not. Actually I´m using 3.8.4. It will stop playing in total, with moode playing in regular play mode, without continously playing mode. What can I do? The foobar settings were never changed.
Thanks in advance
Luki
Old Today, 08:03 AM   #11825
Collie147 is offline Collie147
Originally Posted by TimCurtis View Post
Noted.
Manual build recipe for upcoming Beta 12 has been updated. The automated Image Builder preserves wpa_supplicant.conf if one was initially configured :-)
-Tim
Thanks Tim. As always, stellar work!
Having a bit of an issue on build 11 with the pimoroni pHat DAC.
No Alsa device detected. I ran their curl script so I might need to hammer away at that for a while, although it most likely was something I did (or didn't do).
Old Today, 08:04 AM   #11826
BackinBlack is offline BackinBlack  England
BackinBlack's Avatar
Originally Posted by stuzog View Post
Hi Tim,
Code:
total 40
total 1814540
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
** Proceed (y/n)? y
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
Stuart
I have the same problem. Using RPi B+ (connected via LAN), the target micro SD card appears to have been written to, but when reinserted in the RPi both green and red lights just stay on for an hour. Can't ssh into RPi, although it appears as active on my network. When I look at the card it has become read only and cannot be formatted by SD Formattter.
Have tried about 6 times. Perhaps I'm not waiting long enough.
BTW, build recipe works OK.
Ian
Just listen, if it sounds good to you, enjoy it.
Old Today, 08:19 AM   #11827
rodthebod is online now rodthebod
Hi Guys
I am getting as far as shh to my Pi3 from my mac, I have a 8GB microsd card as boot but on using the auto build installer script I get not enough space 2.5GB required. Tried using the expand to 3GB from Tim's build recipe 2.2 rebooted, but still no joy.
Could koda59 please let us know how to expand the drive to accommodate the build as he kindly did for one of the others.
Thanks in advance
Rod
Old Today, 08:25 AM   #11828
koda59 is online now koda59  France
koda59's Avatar
Hi Tim,
Code:
total 40
total 1814540
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
** Proceed (y/n)? y
/dev/sdb
/dev/sdc
/dev/sdd
/dev/sde
Stuart
Well the detection of USB seems not working in your setup (5 devices detected, something has failed).
Could you, please, give us the result of :
ls -la /dev/disk/by-id
just before launching mosbuild.sh and after, when you cancel/quit mosbuild.sh ?
Another point, did you have any USB devices plugged on RPI's USB before launching mosbuild ?
Old Today, 08:38 AM   #11829
koda59's Avatar
Originally Posted by rodthebod View Post
Hi Guys
Thanks in advance
Rod
sudo raspi-config and choose expand
Look here :
raspi-config - Raspberry Pi Documentation
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2017 diyAudio
