PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 7th December 2017, 02:30 PM   #11611
perryni is offline perryni  United Kingdom
Hi Tim
I have just created Moode 4 Beta 11 and have the following issues (which I had in previous betas). I have Rpi3 + Piano 2.1 + Kali
I can only hear music if I set Sox resampling to 32/384?
Airplay doesnt wotk. I can see Moode on my devices but no sound then suddenly airplay dissapears?
Cheers for your help
Nick
Old 7th December 2017, 02:53 PM   #11612
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi Nick,
I'm not able to repro the resampling or Airplay issues. I have Pi3 + Piano 2.1 + Kali. My WiFi adapter is on a USB extension cable away from the Pi.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 7th December 2017, 04:39 PM   #11613
onionhead is offline onionhead  United States
Running beta11 on MAC and would like to enable UPNP so I can play music files in Audirvana +. Thanks to member yannig for letting me know this is possible.
I have turned on UPnP renderer. Is there another step in process to enable Audirvana to see the MoOde device?
Old 7th December 2017, 05:01 PM   #11614
timbarnes is online now timbarnes  United States
timbarnes's Avatar
Originally Posted by AndrewBrown View Post
I don't know if this is me, my card, or Moode 3.8, but it is unusable on a pi zero w with a justboom digi amp zero.
I use a pi zero w with the JustBoom DAC, and have no difficulties running Moode 3.8.4. I wonder if the amp generates more interference than the DAC and interferes with wireless transmission?
Is there a way to test the performance of the wireless link?
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Moode, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 7th December 2017, 05:05 PM   #11615
TheOldPresbyope is offline TheOldPresbyope  United States
Originally Posted by TimCurtis View Post
Hi Kent,
Most of the radio directory services including Community Radio Browser provide links to station logos of one sort or another. The images are of varying quality and some percentage of stations in these directories have no logo image link.
-Tim
Doh. You're right (of course). I went back and looked at Community Radio Browser and now see those tiny icons in the left column are actually scaled down presentations of reasonably sized image files. The files are not uniformly sized and, as you say, varying in quality if they are present at all.
Kent
Old 7th December 2017, 05:20 PM   #11616
Collie147 is offline Collie147
Default Error building moode 4 beta 11
Building on Raspberry Pi Zero W, after step 8 on reboot the pi didn't connect to Wifi. Seems to pause after "[OK] Started Raise Network Interfaces" and eventually boots and then goes to blank screen (how do I get a local login by the way?)
Stuck back on the wpa_supplicant.conf onto the boot directory and it seems to work so I'd say it was overwritten in step 8
FYI might need to pop that into the recipe
Old 7th December 2017, 08:47 PM   #11617
Skeistrup is offline Skeistrup  Norway
@onionhead
You need to select UPnP in Audirvana somewhere in settings. You of cause must be on 3.1 or something higher. If you cannot get it to work, head over to the Audirvana forum.
Old 7th December 2017, 09:02 PM   #11618
Originally Posted by Zootalaws View Post
Even if you stream the audio using airplay? Surely not?
I think you’re confusing source with transport. In theory, upnp, DNLA and airport should allow a source to link to a destination without affecting the content in any way.
If you have evidence that’s not the case, I’m sure Apple would be very interested to talk to you.
‘Much better’ is subjective. Audirvana changes the music, to me that’s not ‘much better’ or even ‘a bit better’. Besides, they change it inside the Apple computer environment, not on any attached external device.
Try playing the same track via upnp as directly attached via USB and you’ll get the idea
AirPlay will limit your stream to 16 bits.
Using Audirvana from your Mac over the air to RPi running mode and then out via your DAC of choice enables you to stream 24 bits and maybe even higher. Also give it a try with the integrated Tidal and stream some MQA files. Remote control via the A+ app on iPad, works like a charm.
And believe me it is “much better”
Old 8th December 2017, 12:19 AM   #11619
remy1961 is offline remy1961  Canada
Originally Posted by Skeistrup View Post
@onionhead
I also did not know it could be done. In moode you go to config, audio, renderers and activate upnp renderer. In audirvana 3.1 or later you go to settings, audio system, prefered audio device, change, and in the drop down menu you select moode upnp as you can see in the attached picture. Sound quality is as good as playing directly from moode. When you click play in audirvana, moode will start playing. It shows the artwork in the moode playback tab, and on my oled display it shows the artist and song name.
Remy
File Type: jpg Screen Shot 2017-12-07 at 7.04.13 PM.jpg (66.4 KB, 250 views)
Old 8th December 2017, 02:59 AM   #11620
TimCurtis's Avatar
Noted.
Manual build recipe for upcoming Beta 12 has been updated. The automated Image Builder preserves wpa_supplicant.conf if one was initially configured :-)
-Tim
Enjoy the Music!
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
